Thread lock or not
Discussion in 'Suspension' started by tboone75, Aug 26, 2020.
  1. Aug 26, 2020 at 11:09 AM
    tboone75
    tboone75 [OP] New Member
    Tony
    2012 Tundra Platinum
    I am about to install new Coilovers and UCA’s on my 2012 CM. Watched lots of videos on doing this and see a lot of people using thread locker when installing. As I’ve tried to research this, I get conflicting info on using it. So, does anyone know from experience if it should be used or not, and if so what strength? Any help would be much appreciated as I plan on installing this weekend.
  2. Aug 26, 2020 at 11:29 AM
    mt95
    mt95 New Member
    Ohio
    2017 Tundra Crewmax-White
    Red thread locker is permanent--requires lots of heat to loosen up and remove with any success. Blue thread locker is removable and is what I would choose. Blue will hold tight, but still allows for removal at a later time.
    Often times , the use of the red will ruin threads at removal if lots of heat not used.
  3. Aug 26, 2020 at 11:34 AM
    X2 on the Blue.
  4. Aug 26, 2020 at 11:49 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I usually do a dab of blue for anything that gets shaken and beat on. Not trying to make it a bitch to come off, but enough to stop the nut or bolt vibrating loose.
  5. Aug 26, 2020 at 12:56 PM
    It shouldn't come loose if its torqued.
  6. Aug 26, 2020 at 1:04 PM
    snivilous
    SW UT
    Shouldn't, but it's easy and cheap insurance is my philosophy.
    Tundra234[QUOTED] likes this.
