Thoughts on tube steps?
Discussion in 'General Tundra Discussion' started by cfred70, Dec 3, 2017.
  1. Dec 3, 2017 at 8:20 PM
    cfred70
    cfred70 [OP] New Member
    Craig
    Ohio
    2018 Tundra SR5 Crewmax
    Extang Solid Fold 2.0, 20% Tint, Black Emblem Overlays
    Probably going to need to add steps for my daughters to get in the backseat, but I'm not a big fan of them. I've seen a few that sit pretty snug to the body of the truck and I like these a little better than the basic tubes that sit down from the body. Alot of the steps look great on trucks that are lifted, but mine will be sitting stock. Any idea on a type of step i should look at? I'd also love to see some pics of your trucks with steps if you are running stock suspension and stock wheels/tires (not hating on you lifted tundra guys), but I already know yours look good.
  2. Dec 3, 2017 at 8:28 PM
    hartebreak
    hartebreak New Member
    2017 Tundra Doublecab
    I got the nerf steps from N-Fab. They have like 4 different types of steps. Give them a look.
  3. Dec 3, 2017 at 8:38 PM
    Tundra9831
    Tundra9831 New Member
    I bought my truck from the dealership with the Toyota Predator Drop Steps. They were useful to get in the truck, but I hated the way they looked and I'm assuming they would hit the ground even with some very mild offroad driving.
    I sold the drop steps and installed some SDHQ sliders. These are bolted to the frame instead of body and are steel instead of aluminum. They can support the weight of the truck, shouldn't hit the ground and if they do, then they will likely be needed to prevent body damage, and I use them as steps daily, but my kids are also able to use them as steps to get in the truck. These are a lot more expensive and quite a bit of work to install, but I would make the same decision again.
  4. Dec 3, 2017 at 8:50 PM
    ScottsBad
    ScottsBad New Member
    Scott
    Free Idaho, escaped Commiefornian
    2018 TRD Limited
    Just a Bed Rug, Soft Topper, Console Safe
    The thing I like about the SDHQ sliders is that they are protective and can be used as a step. Nice.
    OP, personally I have the same step as the first picture above. Thats the way my truck came. The steps aren't too bad, but something like the SDHQ sliders are much better because they give you a step all along the side not just in a specific place. The downside of the SDHQ slider is that it is a little expensive and the step height is high.
    Sunnier likes this.
  5. Dec 3, 2017 at 8:57 PM
    Tundra9831
    the step height on the SDHQ isn't high at all (at least on a stock height truck). My 5 year old can use the slider to get in without much trouble. They are even more useful as steps than I thought they would be. Oh, they might also protect from door dings in parking lots (hopefully).
  6. Dec 4, 2017 at 12:00 AM
    Sunnier
    Sunny
    San Diego, CA
    Would you be willing to snap a pic from just in front of your rear tire looking forward, so I can see how far the SDHQ sliders extend out from the bottom edge of your truck? Or from the back of your front tire looking back?
    I love everything I've read about how strong the SDHQ sliders are for the weight, that they bolt to existing holes, extend to the cab mount at the front, and also curve up somehow to protect the lower edge of the truck-- but I cannot picture this, and haven't seen a photo anywhere that shows it. I'd like the most recessed sliders available that offer full protection.
  7. Dec 4, 2017 at 5:35 AM
    Tundra9831
    Sunnier likes this.
  8. Dec 4, 2017 at 6:10 AM
    Nfabs? Or Amp Research?
    geno0506 likes this.
  9. Dec 4, 2017 at 6:26 AM
    Sunnier
    Sunny
    San Diego, CA
    Thank you!!! Sdhq sliders
  10. Dec 4, 2017 at 6:31 AM
    Nice..but I'm not a sliders fan
    Sunnier[QUOTED] likes this.
  11. Dec 4, 2017 at 7:11 AM
    Sunnier
    Sunny
    San Diego, CA
    Well, like you, I prefer that single step under the rear door. But I have plans to transform mine into an overlander eventually, so good sliders will offer much-needed protection. But, because I don't like the look, I'm researching for the strongest, least obtrusive. So far, these SDHQ.
  12. Dec 5, 2017 at 12:03 AM
    stetsonvalleytrd
    stetsonvalleytrd New Member
    I installed some run of the mill nerf bars. I actually like the way they look and they make getting in and out of the truck much easier for the entire fam. That said if I plane to do any even semi serious off roading I would opt for something else
  13. Dec 8, 2017 at 11:38 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    If anyone wants to get rid of the oem predator steps please let me know! I’m in Cali, thanks! :hijack off:
  14. Dec 8, 2017 at 12:31 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    The SDHQ sliders work well for there intended use and as a step. I (and lots of others) have added skateboard grip tape to make them safer as a step when weather is bad. I only wish I had installed them before I damaged my truck. In the picture, you can see both the slider with the grip tape and the dent...
  15. Dec 8, 2017 at 12:44 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    How much are guys paying for the sliders?
  16. Dec 8, 2017 at 2:02 PM
    Sunnier
    Sunny
    San Diego, CA
    I liked that you posted a pic of your SDHQ slider, wrapped with skateboard tape. Sad about your dent though.... :(
    gosolo[QUOTED] likes this.
  17. Jun 9, 2020 at 9:48 AM
    sillydadztrksR4momz
    sillydadztrksR4momz New Member
    I have the tube slides from Toyota and the top of it where I step is starting to crack I think it’s some kind of plastic on that part not sure the material but any suggestions??
