Thoughts on this system configuration?
Discussion in 'Audio & Video' started by Black Forest Tundra, Mar 5, 2021.
  1. Mar 5, 2021 at 8:06 AM
    Black Forest Tundra
    Black Forest Tundra [OP] New Member
    Bill
    Black Forest, CO
    2021 Cement Tundra Limited
    7" BDS Coilovers, 37x12.50x18's on Fuel wheels. AMP Research Powersteps, (2) JL Audio 10W3's , Focal components front and back, JL Audio power.
    This is my first post to the forum (outside of the introductory post), and am seeking everyone's thoughts / input. I just purchased a 2021 Limited Crewmax, and like everyone else, am not at all impressed with the JBL sound system. That brings me to where I am at now - I visited a local shop recommended by several locals, and have scheduled an install next week to pretty much replace everything except the head unit. The proposed components are below, but can change it up before my install next week. Thoughts on this configuration? I listen to literally everything, except rap / hip hop.
    HU: Stock
    Rockford DSR1 8 Channel Processor
    JL Audio XD600/6 to power the door speakers
    JL Audio XD600/1 to power the sub
    JL Audio TW3 Single 10" in JL Audio Thin Wedge Box
    JL Audio Bass Knob
    Hertz DSK 165.3 components for front and rear doors
    Thoughts? Anything I may want to consider swapping out?
    JerryH likes this.
  2. Mar 5, 2021 at 8:16 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    shit, looks pretty good to me!
    My only question is with the 6ch.....if you are only running two sets of components (using the passive crossovers), you really only need 4 channels. If you are running the fronts actively (and the rears passively) then you are good. If you only need 4 channels, just get a 5-ch amp to keep it simpler.
    You might want to ask the shop about how much it would cost to throw some sound deadening in the doors and rear plate.
  3. Mar 5, 2021 at 11:07 AM
    SloppyJ
    SloppyJ New Member
    NW Arkansas
    2023 Black SR5 Crewmax Long Bed
    Looks solid. That sub should blend well but I wouldn't imagine it will be beating the block down. If you have time and are somewhat handy, you can tackle this yourself and save a BUNCH of cash. I just did my install last week and posted the thread. Not sure how much the processor is (I assume it functions as a LOC) but if it were anywhere close to the cost of a new headunit, I'd go that route.
    I chose the XD400/4 to power my front components and rear coax speakers and it works great. If you want to save some cash, you could just go with coax speakers in the back. Typically rear speakers are just for fill and people either omit them completely or run coax speakers, speakers with the tweeters built in, back there. Based on my experience, I wouldn't omit the speakers in the back but the cost/reward ratio just isn't there IMO for sticking a nice component set back there.
    Maybe get coax speakers and use the savings to put towards some sound deadening.
  4. Mar 5, 2021 at 12:10 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    I like it. You have the 8ch coming out of the dsr1. Might as well use them all
  5. Mar 5, 2021 at 1:41 PM
    Black Forest Tundra
    Bill
    Black Forest, CO
    Thanks everyone, the sound deadening is already planned and scheduled. I guess my main concern, is whether the single JL 10 sub driven by 500-600 watts would be enough, or if a 2nd one would be needed.
  6. Mar 5, 2021 at 1:45 PM
    AZBoatHauler
    So.Arizona
    Given the genres of music you excluded, I think running one TW3 will be good. What part of AZ are you located? I’m running 2 W0 10” subs and would be happy to let you hear what that sounds like but I’m down in Pima County NW of Tucson.
  7. Mar 5, 2021 at 2:07 PM
    Black Forest Tundra
    Bill
    Black Forest, CO
    Thanks! I am in Chandler, so a bit far from you but I appreciate the offer!
  8. Mar 5, 2021 at 2:28 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Did you end up going through KarTunes or what shop are you using?
  9. Mar 5, 2021 at 2:50 PM
    Black Forest Tundra
    Bill
    Black Forest, CO
    Yes, I am going through Kartunes - scheduled to drop off the Tundra Wednesday morning
    TRDFerguson[QUOTED] likes this.
  10. Mar 5, 2021 at 6:10 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    I would get a slightly bigger amp for 2 tw3 s. I would go 800w to 1000w, (but that s just me).
  11. Mar 5, 2021 at 6:32 PM
    Danimal86
    Daniel
    Sacramento, CA
    I had the tw3's in a sealed box (jl stealth box) and now tw3's in a ported.
    I would go with two in a ported box.
  12. Mar 5, 2021 at 6:36 PM
    Danimal86
    Daniel
    Sacramento, CA
    Just FYI, I think there may be a known issue with the dsr1 and 2020+ tundras
  13. Mar 5, 2021 at 6:40 PM
    Brownsfanhere
    Brownsfanhere New Member
    2015 Crew Max
    how much does a system like OPs set up run? Factory system really stinks. But want to smart about a audio upgrade. Clueless on this matter. Will pay for somebody to install.
  14. Mar 6, 2021 at 6:33 AM
    SloppyJ
    SloppyJ New Member
    NW Arkansas
    No clue to what OP is paying or how much they charge for install. I'm about $1,200 in for a new head unit, speakers, amp, sound deadening, and all of the extras. You could do it a lot cheaper but I didn't. I imagine I'll be in about $2,000 ro $2,200 by the time I add two subs, a box, and another amp. Again, it can be done for much cheaper.
    Brownsfanhere[QUOTED] likes this.
  15. Mar 6, 2021 at 6:37 AM
    coTony
    Tony
    Montrose, CO
    Trust what James recommends to you. He normally asks what you want out of the upgrade and will suggest based on your answer. He is awesome at what he does
  16. Mar 6, 2021 at 5:59 PM
    Black Forest Tundra
    Bill
    Black Forest, CO
    Thanks guys, I am looking at just north of $3k with this upgrade, excluding the sound deadening. Pricing will vary greatly based upon hardware selection and who you have do it. I have heard great things about the shop I am using, so far me, any extra costs are worth it to know it is done right.
    James scheppelmann and 619Tundra like this.
  17. Mar 6, 2021 at 6:29 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Scratch the DSR 1 and get a quality aftermarket headunit. You have top quality Ferrari equipment and you’re feeding it with a civic motor from 1999.
  18. Mar 6, 2021 at 8:25 PM
    Caritaman1
    Caritaman1 New Member
    Charles
    2012 Tundra Crewmax 5.7 Texas Edition
    The only thing I can think of are some focal speakers. You can't go wrong with these. I'm only saying it cause that's what I got.
  19. Mar 6, 2021 at 8:43 PM
    Danimal86
    Daniel
    Sacramento, CA
    Why the 6ch amp?
  20. Mar 8, 2021 at 12:28 PM
    Black Forest Tundra
    Bill
    Black Forest, CO
    The 6 Channel amp is for both sets of doors, as well as power options for the dash speakers. I changed out the Hertz components for the Focal component kit. Thanks for everyone's input!
  21. Mar 8, 2021 at 12:43 PM
    AZBoatHauler
    So.Arizona
    I think everyone agrees running front components AND amplified dash speakers will generally make your highs too bright. People tend to either a) pull the dash speakers completely b) keep/upgrade the dash speakers but run them off HU power or c) install front door component tweeters in dash speaker location rather than in the door.
    Imo, it would be better use of the 6 channel to run active in the front channels as suggested above and either ditch the dash speakers or run them off HU power so they are very subtle.
  22. Mar 8, 2021 at 12:49 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Why not run a separate amp for the dash speakers so that way you can adjust the gains accordingly so the dash isn’t too bright. That’s the ideal setup. Costs a little more but would be worlds better
  23. Mar 8, 2021 at 1:22 PM
    Black Forest Tundra
    Bill
    Black Forest, CO
    This may be what the shop is doing, I am not sure.
  24. Mar 8, 2021 at 1:48 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    I don t know about anyone else, but if I had a shop do something like this I would know exactly what the plan is before I dropped off the truck, and i d get it in writing. There are some horror stories out there.
  25. Mar 8, 2021 at 1:55 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    Nope. Do not amp-power the dash speakers as it will OVERPOWER the audio in your system. They will be WAY TOO BRIGHT. Even the engineers at Toyota saw this and chose not to amp-power the dash (Tundra OEM dash speakers are powered by the H/U only and the crap, under-seat amp powers the doors and crap sub in the back). Most of us simply delete the dash speakers and run components in the doors and subs in the back, powered by either a 5 channel amp OR, two amp setup (4chan for doors and mono for subs). The latter is how I did mine and it sounds absolutely amazing. The dash speakers are overkill anyway.
  26. Mar 8, 2021 at 1:57 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    For what it's worth, the audio shop that OP is at is very well regarded in the local Tundra group. I'd say they know what they are doing, but we don't have all the information either.
  27. Mar 9, 2021 at 5:30 AM
    SloppyJ
    SloppyJ New Member
    NW Arkansas
    You could always adjust the gain on the channel for the dash tweeters to get them to fit into the sound stage. I think it's a great idea. You just want to make sure you have enough sub there to help balance it out because that will be a lot of highs.
  28. Mar 12, 2021 at 7:36 AM
    Black Forest Tundra
    Bill
    Black Forest, CO
    I picked up my Tundra from the local shop (KarTunes) yesterday afternoon and it sounds amazing. They used all 6 channels on the JL 600/6 to power the 2 dash speakers (turned down quite a bit), and the Focal components in all 4 doors. The JL 10TW3 sub does great for a single 10". Overall I am very happy with their recommendation and install. No problems whatsoever with the DSR1 (yet) regarding the carplay / siri / etc.... The imaging that was created through all 8 channels of the DSR1 is amazing. Thanks to those of you who chimed in. Have a great weekend!
  29. Apr 28, 2021 at 4:03 PM
    Black Forest Tundra
    Bill
    Black Forest, CO
    After having this initial upgrade, I decided to go back in and add a 2nd JL 10" TW3. It sounds fantastic, and has plenty of high's, mid, and now bass. The imaging created by the use of all available speakers through separate channels on the amps was a good choice by the local shop.
    James scheppelmann likes this.
  30. Apr 20, 2022 at 6:23 PM
    James scheppelmann
    James scheppelmann New Member
    Scheppelmann
    2017 inferno crewmax
    7in bds, 35x12.5r20 compustar remote start, aftermarket auto lights , front and side view cameras , dashcam, ditch lights,
    First Thank you for writing this although im no longer at kartunes. a lot of you guys are not understanding I have to use the dsr1 for his factory headunit so I can ditch the factory amp as this vehicle has jbl. And I can't run the dash off the headunit . about the dash speakers. Part of the reason I wanted a 6 channel amp to run the dash separately from the doors. the dsr1 can control them independently being a dsp.
    It was a fun build thank you for posting love seeing this kind of thing.
