Thoughts On This Frame
Discussion in '1st Gen Tundras (2000-2006)' started by Mintcandy1, Apr 17, 2024.
  1. Apr 17, 2024 at 4:52 PM
    Mintcandy1
    Mintcandy1 [OP] New Member
    Hey guys, is this frame good or has it been undercoated to hide rust? Thanks
  2. Apr 17, 2024 at 4:59 PM
    shifty` I'm having daydreams about night things
    The rear diff is going to spring a leak any day now, and the transmission crossmember looks fucked. The spare tire is installed upside down, so it could collect water, and gives a pretty accurate idea of what you can expect to find inside the framerails if you had a borescope/snake cam. I wouldn't personally buy that truck. It's definitely been coated. But it definitely had rust before it was coated.
    To boot, the rear brakes are likely fucked, or braking as a whole. Looking at how much slack is in that parking brake cable, I'm sure they're soft, and I suspect they can't be dialed in. If this truck isn't going for $6k or less, I wouldn't buy it.
    PROTERRA likes this.
  3. Apr 17, 2024 at 5:01 PM
    One other thought: It's possible this frame was replaced. Because the longer rails and a few other spots - like the "X" shaped crossmember over the spare tire - don't show the same amount of corrosion as the rear diff, and a few other bolt-on parts. Still ... even if replaced, I wouldn't buy it. But if it was replaced, it should show up in the service history at the Toyota Owners website, if you setup an account and plug in the VIN.
  4. Apr 17, 2024 at 5:03 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    There’s so much rust on the backing plates, the coating has already flaked off in areas on the passenger rear
  5. Apr 17, 2024 at 5:03 PM
    Aerindel
    Aerindel New Member
    Montana
    I'd be pretty suspicious given how terrible the other parts look. I would look up the history of it for sure and see if its been replaced...because everything else metal that hasn't been coated looks awful, if the frame is just as bad, but under the paint, run away
  6. Apr 17, 2024 at 5:26 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Lots of black cover-up spray of some kind -- you can see the overspray. The body rust looks pretty bad. I wouldn't buy it.
  7. Apr 17, 2024 at 5:31 PM
    Mintcandy1
    The leaf spring looked like it was sprayed so I was wondering. Thanks for your responses everybody.
  8. Apr 17, 2024 at 5:59 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    That spare tire is a dead giveaway!
    and also these brackets have deep delaminating rust. I would steer well clear of that truck.
  9. Apr 18, 2024 at 4:35 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    That transfer case skid plate is atrocious. 3 different pipes on the exhaust, and that exhaust hanger looks one good bump away from snapping. Not the worst truck we've seen, but pretty close.
