Thoughts on this 4Runner
Discussion in 'Other Toyota Vehicles' started by Atomic City Tundra, Jan 27, 2019.
  1. Jan 27, 2019 at 5:59 PM
    Atomic City Tundra
    Atomic City Tundra [OP] Cam Tower Leak Addict
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Hey guys -
    I made a post a while back about a 2nd gen 4Runner that my boss owns. I didn't want to resurrect that thread because Connor replied a lot in it, and well....it makes me sad. My boss let me take it for a few days yesterday. I have driven it around a bit, and it drives really well. Definitely seems to be pretty nice for it's age. It is a 1995 4Runner with a 22re engine and a manual transmission. It has 244,600 miles on it! Clutch was replaced at 180,000. There are several oil leaks that I can see (which I would expect for a vehicle this age - not like my Tundra which has sprung two oil leaks in it's 74,000 miles), but nothing appears to really be dripping onto the ground.
    Definitely needs a little love, but seems to be pretty solid. Only one spot on the body that has some surface rust back near the driver's side rear wheel. Undercarriage only has surface rust except for the tailpipe. Compression test looks good. Each cylinder was with the range of 150 +/- 3 psi after 4 cranks.
    Anyway here are a couple of pics. Thinking of getting this for my son to learn to drive in. Any thoughts would be appreciated.
    Y0TA PR0, 4RunnerKid, BestGen and 4 others like this.
  2. Jan 27, 2019 at 6:10 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I think it is a great truck for the kid. The fact you're buying from a seller you know helps to justify the higher miles... at least it's your boss and not some beat-the-shit-out-of-it douchebag. You are going to have maintenance at that age truck no matter what, but it seems you expect that too. My only concern for the 22re @~250k is was the timing chain ever done? (I have one btw for that motor, mine blew up @246k milesb before I got to change it.
  3. Jan 28, 2019 at 5:26 AM
    Atomic City Tundra
    Devin
    New Mexico
    Bump for more thoughts from the morning crew.
  4. Jan 28, 2019 at 5:30 AM
    00Tyler10
    00Tyler10 WETT Expeditions
    Tyler
    Bowling Green, Ky
    2020 MGM Tundra Plat 4x4
    PTM Mirror Caps Spray in Bed Liner Window Tint XD Buck 20x9 Wheels 275/65/20 BFG K02s Bamf 10" exhaust
    I have a 92'. Mine was 3.0 I did the 3.4 swap on. However several buddies with the 22re. Depending on price I would grab it. 22re manuals are famous for a reason and depending on your knowledge level pulling that engine and rebuilding it is easy. Plus it's white......
  5. Jan 28, 2019 at 6:35 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    The main issue with the timing chain is the plastic guides that eventually wear out. The chain itself is stout. It shouldn't need replacing at this stage. I've got ~235K miles on mine. Doesn't leak at all. All I've ever done is replace the alternator and the idler pulley. You can run 33/10s on the stock rims without a lift. I did for years. I added a ball joint spacer for a little more clearance. I also swapped gears and front axle from a '93 with the factory 4.88 gears. Look for axle code G144. W56 trans is pretty much bulletproof behind the 22RE.
  6. Jan 28, 2019 at 6:36 AM
    SpacecoastHusker
    SpacecoastHusker New Member
    Brevard County, FL
    2014 Toyota Tundra Limited CM
    A solid vehicle from a trusted source. If it's a reasonable price, that would be a great first vehicle for a kid to drive.... and learn to drive a stick. Shoot, he might be the only one of his classmates that can drive one.
  7. Jan 28, 2019 at 6:40 AM
    Atomic City Tundra
    Devin
    New Mexico
    My goal is to have all of our kids learn to drive a manual. My oldest daughter (who is 17), drives a 2001 Nissan Xterra with a manual. Hoping to teach my boy and my younger daughter as well.
  8. Jan 28, 2019 at 6:48 AM
    BestGen
    BestGen New Member
    Paul
    These are the last gen of 4Runners that had a tailgate. Before they went to a minivan hatch!
    Real trucks have tailgates!
    One other thing is get yourself some vacuum line and replace all the small rubber lines on the engine. After all this time they start to get hard and crack.
  9. Jan 28, 2019 at 7:03 AM
    SpacecoastHusker
    Brevard County, FL
    That's awesome. More kids should be learning how. I personally think that learning to drive a stick makes you a better safer driver. You are more in-tune with the vehicle. It's too bad that it's getting so hard to find a newer vehicle with a MT.
  10. Jan 28, 2019 at 7:10 AM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    Loved my 95’. Took it everywhere and it never let me down. Sold it with 289,000 miles 5 years ago and I still see it driving around. All I ever did was routine maintenance and a timing belt
    Toyotoholic likes this.
  11. Jan 28, 2019 at 11:15 AM
    Atomic City Tundra
    Devin
    New Mexico
    Ok, so the boss doesn't recall the timing chain ever being done. He purchased the 4Runner with about 140K on the clock. In doing some research, it looks like a fairly substantial job to replace it, and is often accompanied by removal of the head (although I have read that it can be done with the head left on. I am wondering if I decide to buy this, and am going to dig in that far to replace the timing chain anyway, should I just yank the whole engine and rebuild it? 245K is a lot of miles.
    Not sure what I am going to do. I spoke a bit with my boss and I think I might be able to get it for about $800-$900. Would be a great learning experience for myself and my son. I am not a stranger to working on vehicles and engines, but haven't ever tore into a Toyota engine before. My son won't be driving for another 2.5 years or so, so I would have some time to get things in order.
    Just thinking out loud here.
    Y0TA PR0 likes this.
  12. Jan 28, 2019 at 11:32 AM
    00Tyler10
    Tyler
    Bowling Green, Ky
    For that price DO IT! Learning experience and you get an awesome truck you learn everything about. I'm telling you now it's worth it and yotatech.com will have all the info you need. White, 22re, MT from a friend at that price don't come around often if hardly ever.
  13. Jan 28, 2019 at 11:36 AM
    00Tyler10
    Tyler
    Bowling Green, Ky
    Just to show you I don't speak without experience.C7BECE66-4373-4B54-81AC-A4F92E819F25.jpg
  14. Jan 28, 2019 at 11:38 AM
    Atomic City Tundra
    Devin
    New Mexico
    God I wish I had a shop like that.
  15. Jan 28, 2019 at 12:01 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    That’s almost 400,000km! Hell ya! I say go for it! I’m sure you and your son will enjoy this nice 4Runner together
