Thoughts on SPYDER headlights?
Discussion in 'Lighting' started by tbeeemer, Aug 13, 2018.
  1. Aug 13, 2018 at 9:51 AM
    tbeeemer
    tbeeemer [OP] New Member
    Tony
    2011 Black Tundra Limited
    2" level, Firestone air bags, and 33 wheels and tires
    Are the LED highlights (SPYDER) better than the stock headlights as far as night vision? What are the best out there?
    I've read a thread about being able to swap the leveling motor to the Spyder headlights, but is that for them all or just one specific model?
  2. Aug 13, 2018 at 11:13 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    They are better when you add an HID kit to them.
    2018 led headlight are better , way better. Lights can be bought at local dealer or @Roman and you'll need a harness from @iHacker. You won't regret it. For a couple hundred more than spyders
    619Tundra, Roman and PMG like this.
  3. Aug 13, 2018 at 11:14 AM
    Pudge
    CT
    Oops. I see you have a 2011. So spyders may be the way to go with an hid kit.
    You'll need 2018 sequoia lights and ahatness from @xrunnerdude67 and it's very costly. Like 1400 bucks or so I think.
    Fiestee23 likes this.
  4. Aug 13, 2018 at 11:24 AM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
  5. Aug 13, 2018 at 11:33 AM
    Or new Sequoia headlights would be nice
  6. Aug 13, 2018 at 11:42 AM
    TheBeast The Beach
    my understanding is if you burn the LED light on the 2018 headlights, you need to change the whole assembly. That could be very costly if you went with the Sequoia.
    the Spyder gen 2 with LED/HID lights might be your best bet for a gen 2.
  7. Aug 13, 2018 at 1:21 PM
    Pudge
    CT
    I have heard of 2 cases with a high beam going out. If this continues, I'd assume Toyota will jump in and do a tsb or increase the warranty. They made these to last a lifetime and I'd assume they'll honor that
    TheBeast[QUOTED] likes this.
  8. Aug 15, 2018 at 4:08 PM
    tbeeemer
    Tony
    Do the spyder lights have a lit side marker light like stock lights or just a reflector?
    I'm mainly shopping because my lens are fogged and the light is crap.
  9. Aug 15, 2018 at 7:35 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Is there a way to rewire the drl bar to stay ON, like factory?
    Pudge likes this.
  10. Aug 15, 2018 at 7:36 PM
    Pudge
    CT
    Yes there is. I think someone did a write up on here. It's not too hard, just a jumper wire I believe.
  11. Aug 15, 2018 at 8:40 PM
    Ryooo
    Ryooo New Member
    Boynton Beach FL
    2014 CM SC Platinum
    TRD Supercharger 4.5 BDS lift 20” Method Standards sitting on 35 Nitto Grapplers Rigid grill top and bottom with lights AMP running boards Fender flares Magnum rear bumper Rear LED bar Air bags with onboard compressor Brake controller Alpine Navi Alpine amps x 2 Focal Separates front and rear 2 x JL 13s in a stealth box behind the back seat LTE cellular booster Rear seat under locked storage Dynamat from ceiling to floor LEDs all over Bed liner Bed rails Paint protector covering nearly the entire front end and more
    I agree and I did the 2018 upgrade through @Roman with @iHacker s plug, it was incredibly easy.
    619Tundra, Roman and Pudge[QUOTED] like this.
  12. Aug 16, 2018 at 6:46 PM
    PlickNPluck625
    PlickNPluck625 New Member
    Zak
    2015 Tundra Double Cab
    None as of now Level kit, bigger tires, new headlights, tinted windows all in the works
    So I bought and had the spyder headlights installed. They look awesome but is it just me or is the light output/brightness ten times worse than the stock headlights? I got these to improve my night visibility not decrease it lol. Is there a way to adjust these or anything? Any info is greatly appreciated!
  13. Aug 16, 2018 at 6:53 PM
    Frozentundra12
    Frozentundra12 New Member
    Josh
    Sylva, NC
    2012 silver tundra
    6’ fabtech lift, 20’ fuel wheels on 35s. Bed cover. Flowmaster outlaw exhaust.
    83A32189-35B4-4BE4-B1F9-6EA0C13631BD.jpg B9A620E2-1D4E-414A-B34F-904C9B9A2F93.jpg
    I’m still trying to get them adjusted correctly. Kind of a pain in the butt. Do they look great? Yes. Do I think I had better lighting with the factory’s. Yes.
    Mountun Goat, Rica25 and trdprobped17 like this.
  14. Aug 16, 2018 at 6:54 PM
    Frozentundra12
    Josh
    Sylva, NC
    2012 silver tundra
    I’m working the same thing! Kind of frustrating. Kinda wish I just got a led or hid kit for the factory setup
  15. Aug 16, 2018 at 6:58 PM
    Rica25
    Ricardo
    Tulare
    Yes I agree also I added LEDs and is much better than the ones they came with but not as good as my stock assembly's with LEDs
  16. Aug 16, 2018 at 7:15 PM
    PlickNPluck625
    Zak
    Well crap. If the stock eith LEDs are brighter than I might as well save myself $400 and keep those with LEDs instead of having the spyder. I was really only looking for more night visibility. Thanks for the replies gentlemen!
  17. Aug 16, 2018 at 7:16 PM
    Rica25
    Ricardo
    Tulare
    I did mine yo give truck different look and I dont regret it
  18. Aug 16, 2018 at 7:53 PM
    Pudge
    CT
    Get an HID kit for the spyders. Several reviews saying they do much better with HIDs than LEDs.
    Rica25 likes this.
  19. Aug 16, 2018 at 8:00 PM
    Rica25
    Ricardo
    Tulare
    I've heard the same
    Pudge[QUOTED] likes this.
  20. Aug 16, 2018 at 8:16 PM
    Rica25
    Ricardo
    Tulare
    I might be going that route
