Thoughts on Royal Purple fuel cleaners..
Discussion in 'Performance and Tuning' started by Spvrtan, Sep 13, 2016.
  1. Sep 13, 2016 at 2:18 AM
    Spvrtan
    Spvrtan [OP] Amateur fabricator
    Kris
    San Diego, CA
  2. Sep 13, 2016 at 5:48 AM
    VA10
    VA10 New Member
    2020 Tundra Limited TRD Off-Road
    I have been curious on this as well. I typically by the Cheveron Techtron. If I am feeling cheap or see a good deal I buy the Gumout fuel system cleaner. Both seem to work well for what they are. I have used
    11722 Max-Clean Fuel System Cleaner and Stabilizer. I did not find enough evidence from just driving around/idle it did anything......
    ChrisFix on youtube does some great test/analysis videos of some of the well known fuel systems/injectors cleaners out there.
    davesnothere likes this.
  3. Sep 13, 2016 at 8:20 AM
  4. Sep 13, 2016 at 9:26 AM
    TheBeast The Beach
    I usually fill up with quality gas like Chevron ,Shell and even the Costco brand one which is actually pretty good.
    Once in a while I'll empty a bottle of Techron.
  5. Sep 13, 2016 at 9:45 AM
    dtrucksis
    dtrucksis New Member
    David
    2005 Toyota Tundra Limited
    K&N cold air intake
    Personally, I use Marvel Mystery Oil additive at each fill up. It helps with the fact that most of us are limited to using a 10% ethanol fuel. Our Race Trac does have straight gasoline with no ethanol. Too expensive though.
  6. Sep 13, 2016 at 6:26 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    I think any of the nice brand name additives will be just fine. Honestly, changing the oil regularly, cleaning the air filter and throttle body regularly and putting good fuel in is what keeps an engine running good;)
    T-Rex266 likes this.
