Thoughts on rotors
Discussion in 'General Tundra Discussion' started by Prostar 190, Feb 1, 2018.
  1. Feb 1, 2018 at 6:51 PM
    What do you guys think about the Power Stop drilled and slotted rotors with the evolution brakes.
    boostedtrdpro likes this.
  2. Feb 1, 2018 at 6:54 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2019 SC TRD Pro CM 040 2020 Sequoia TRD Pro 040
    Put them on my big body Audi A8 with the EBC red stuff pads and man, what a difference! I highly recommend them.
  3. Feb 1, 2018 at 7:01 PM
    Thanks
    boostedtrdpro[QUOTED] likes this.
  4. Feb 1, 2018 at 7:19 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Well hold on a second...ok, BUT...an Audi A8 is about 1200lbs lighter than a Tundra and has 15 inch rotors up front as compared to Tundra's 13.9 inch rotors...not even same ball park...maybe someone has a Tundra related experience?
  5. Feb 1, 2018 at 7:23 PM
    boostedtrdpro
    Jeremy
  6. Feb 1, 2018 at 7:27 PM
    Crunch527
    Iowa
    no maybes about it...totally different situation...I'm not saying they didn't improve your Audi, but to suggest that the Tundra would have the same benefits is a stretch...
    Prostar 190[OP] likes this.
  7. Feb 1, 2018 at 7:35 PM
    Upgrayedd
    Upgrayedd Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
  8. Feb 1, 2018 at 7:37 PM
    boostedtrdpro
    Jeremy
    I was saying maybe, regarding you saying "maybe some has Tundra related experience?" I was merely posting up my experience with the rotors.
  9. Feb 1, 2018 at 7:42 PM
    Upgrayedd
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    More than likely the pads are what improved the braking performance. The rotors will just allow you to maintain that performance longer as the temps increase.
  10. Feb 1, 2018 at 7:44 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Had them on my last tundra with the drilled rotors. They looked nice and worked fine, but no noticeable improvement in braking (no worse either) besides replacing a worn set.
  11. Feb 1, 2018 at 7:46 PM
    LML 3500HD
    If I were to get anything, it would be a slotted rotor for wet performance only. Other than that, just give me a premium rotor and some good pads.
    I put some cross drilled/slotted rotors on my Tundra. No scientific data, but in wet conditions, the truck seemed to stop better. No difference towing or street driving that I could “feel”.
    Now on my IS350...different story. These are force cooled by ducts. Premium pads and rotors only.
    If I was to play devils advocate, my Corvette had one of the best braking systems I have ever been in. I could bruise my chest with the seat belt shoulder strap. Those were all cross drilled rotors and 6 piston front/4 piston calipers in the rear.
  12. Feb 1, 2018 at 7:52 PM
    BIGUGLY
    Paul
    2018 Limited
    Those worked well on my previous sequoia.
  13. Feb 2, 2018 at 2:39 AM
    Morning bump to the top.
  14. Feb 2, 2018 at 2:42 AM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    I put them on my '10, no complaints, they do not seem any better than the oem brakes, I also put on their ceramic pads.
  15. Feb 2, 2018 at 2:45 AM
    Did you ever get the warped rotor feel again once you put them on .
  16. Feb 2, 2018 at 2:48 AM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    No, they have been fine, nice and smooth.
  17. Feb 2, 2018 at 2:50 AM
    Thanks.
  18. Feb 2, 2018 at 5:54 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I decided to change out my rotors and pads when I changed my tires at 35k miles. I went with the powerstop cross drilled and slotted rotors. At first they didn't seem to stop as well. But after they broke in they seem to be smoother than stock. They have a cool look but I liked the performance of my duralast black rotors and pads on my previous 2015 Tundra better. I would prefer the 6 piston big brake kit upgrade but they're crazy expensive!
    Les7311 and Prostar 190[OP] like this.
  19. Feb 2, 2018 at 6:06 AM
    Do you feel they stop as good or any better than the stock one's.
  20. Feb 2, 2018 at 6:12 AM
    1UPPER
    TEXAS
    Flux capacitor!
    Not IMO. They are smoother but they don't seem to bit down as hard as the stock rotors and pads. I was told by others that the pads that came with the power stop rotors in a set may not be as good of pads. I bought different pads but I never got around to trying to have them installed yet.
  21. Feb 2, 2018 at 6:26 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2008 Nautical Blue Tundra SR5 CM 4x4 Beauty
    Toytec Boss coilover, Ray10’s ,Ridge Grapplers,Bilstein 5100,BAM 8”,TRD sway,
    I just changed my rotors for the first time at 97K. Previous owner had them turned at 89K. Went with oem for the longevity. Paid 120 on eBay for the set of two. Peace. D
  22. Feb 2, 2018 at 6:35 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    I put them on my DD which is a 2014 Durango. They stop better than the oem setup. However, they do make a funny noise (akin to baseball cards stuck in the spokes of a bicycle). The noise isn't annoying or very loud. I don't even think you will be able to hear it in the Tundra because the tire & engine noise will drown that out. They squeak when cold on the first application of the brakes (I mean when the temp is below 20 degrees F). This just develops in the wintertime and goes away when temperatures are higher. I've done brakes on all my past vehicles, so I'm pretty sure it is not an installation issue. It may be the formulation of the pads and the hardware that just doesn't like cold temps. If the price is the same between these and oem, I'd use oem. But nothing wrong with the powerstop drilled and slotted. They look cool.
  23. Feb 2, 2018 at 7:20 AM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    I bought mine from Brakemotive on eBay, around $200 for 4 new rotors and pads, they do not list them as Power Stop but they have Power Stop part numbers on them, here are a couple pictures from when I received them in Sept of '15.
  24. Feb 2, 2018 at 12:22 PM
    Thanks for all the replies guys.
    1UPPER likes this.
  25. Feb 6, 2018 at 10:53 AM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    I put these (Powerstop Z 36 Truck and Tow Kit) on my 2004 at 190k last year and there was a noticeable improvement over OEM. I then installed the stainless brake lines front and rear and it really stops well now
  26. Feb 6, 2018 at 12:32 PM
    NorthWoodsTundra
    NorthWoodsTundra Hehehe, you said 'member'...hehehe
    2021 GMC 3500 SRW Gasser
    No Tundra experience, but I put the Power Stop/Evo on my Sienna as they were the same price as OEM. Slotted and cross drilled look kinda silly on a minivan but I dont care. I followed the break-in procedure per the instructions and have been very pleased with them. After 10k miles there is still no discernable wear and not a hint of warpping and I’m not exactly easy on brakes. Performance wise, there is a huge difference over the OEM. Combined with some new Michelin Premier LTX’s and crikey does that thing stop NOW. It’s not hard to get into the anti-lock even on dry pavement. The one con about them, and it’s nothing really, is that they are somewhat noisy, particularly when cold.
