Thoughts on a 2014 DC
Discussion in '2.5 Gen Tundras (2014-2021)' started by Str8up50, Feb 3, 2019.
  1. Feb 3, 2019 at 3:56 PM
    Str8up50
    Str8up50 [OP] New Member
    WL
    S Louisiana “Chasin Redfish”
    2016 Tundra DC
    6FEC89E2-FFB8-4123-AF2F-F4212C7EC933.jpg so I found this one about 150 miles away. It's the color and engine size I've been searching for. 40k miles / $27942 certified. Any issues with the 2014's. How many more miles can I get out of this one. I've never purchased used before so I'm not accustomed to wiggle room ref price drop. Money is tight and I'm looking for under 30k.
  2. Feb 3, 2019 at 4:04 PM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    It’s a Toyota if you take care of her she will last forever.
    Trooper2 and Blueknights75 like this.
  3. Feb 3, 2019 at 4:26 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Should be in good shape with low milage. Check carfax and compare values on NADA and or Kelly Blue book.
    good luck!
    Blueknights75 likes this.
  4. Feb 3, 2019 at 4:27 PM
    Blueknights75
    Ron
    Clayton, NC
    Should be able to easily get about 300k more miles before having to do any major maintenance.
    Buildn and Trooper2 like this.
  5. Feb 3, 2019 at 4:47 PM
    Tundramaniac
    Tundramaniac New Member
    14 tundra limited dc
    That's a decent price man. I bought mine a year ago with 77k, a limited trd for 28000. No major issues and lots of upgrades since. I would check in Carfax if it had camtower leaks fixed, water pump. Those are the most common issues that you could be up against
  6. Feb 3, 2019 at 4:57 PM
    Str8up50
    WL
    2016 Tundra DC
    How can you tell via Carfax bout,those.issues
  7. Feb 3, 2019 at 5:03 PM
    Heeler13
    Heeler13 21MGM
    Eastern NC
    2021 Sr5 XP
    Bilstein 5100 Front @ middle setting Bilstein 5100 Rear @ stock height Oem older Pro wheels 285/75/18 Maxxis Razr a/t
    Check for cam tower leaks if you go look at it, (if its a 5.7) Not uncommon with that mileage. Would be covered under warranty if its actually a "leak" and not a "seep". There is a whole thread on this. Some people care about it, some dont. My 2015 was seeping before i sold it. Never bothered me much tho.
  8. Feb 3, 2019 at 6:14 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Welcome from Northeast Connecticut.
  9. Feb 3, 2019 at 6:17 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Welcome from SE PA!
  10. Feb 3, 2019 at 6:28 PM
    Tundramaniac
    It doesn't look like it's been done. Looks like it's been pretty problem free. Looks like the ecu was reprogrammed, other then that just maintenance oil changes etc.. you can look through the wheel wells , you would seen it if it's leaking.
  11. Feb 3, 2019 at 6:29 PM
    Tundramaniac
    My bad, it was the PCM module reprogrammed. That's what it says
