Thoughts on 7" lift?
Discussion in 'Suspension' started by Haroldgomez18, Jan 25, 2016.
  1. Jan 25, 2016 at 9:09 PM
    Haroldgomez18
    Haroldgomez18 [OP] New Member
    2013 toyota tundra platnium
    Im thinking about lifting my 2013 Toyota tundra crew max platinum and was wondering the best lift out there for my bucks i was thinking about 7 inches and also wondering if i run 22/12 with 7 inch lift with 35 or 33's
  2. Jan 25, 2016 at 10:29 PM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    I say 42's hell I'm running 35's with less then 2" of lift!
    zcarpenter92 likes this.
  3. Jan 26, 2016 at 5:52 PM
    Haroldgomez18
    but how wide could i run without having to do any trimming ?
  4. Jan 26, 2016 at 6:02 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    OP, nobody can help you unless you provide some specifics about tire width and wheel back spacing. 12" wide wheel means nothing without giving us the back spacing or offset.
    And as @jlee said, you can fit 33's and 35's on a stock truck, let alone 7" of lift. Both Jerry and I run a 35x12.5" tire with zero lift. I added preload to bring me up to right at 3" of lift up front and he added 2".
    Each to their own, but with 7" of lift, 33-35's gonna make your truck look like it skipped leg day. CenCal status.
    zcarpenter92, T-Rex266 and Black Wolf like this.
  5. Jan 26, 2016 at 6:12 PM
    Remember , You will need a way to somehow get into the cab too. And passengers, your dog, etc. Tire cost will exponentially go up drastically, unless you found a money tree that still eludes me so far.:headbang:
  6. Jan 27, 2016 at 8:45 PM
    Haroldgomez18
    well mainly i like the way it looks but i just bought my tundra in september last year and wanna start modding
  7. Apr 24, 2016 at 12:32 PM
    nathanhubbell
    nathanhubbell New Member
    Nathan
    2013 rundra trd sr5
    Alot
    I've got a 6" and 3" body, I had 37s and then dropped to 35s. It looks super ugly
    Black Wolf likes this.
  8. Apr 24, 2016 at 4:02 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Just my $.02, but most anything over 4" just looks like a bro truck. Certain guys are able to pull off a 5-6", but a lot of thought needs to go into making it look right.
    robie56, bandit and Black Wolf like this.
  9. Apr 25, 2016 at 6:30 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    I have a 7" lift with 20x10 -24 offset and 35x12.5 tires with trimming to the front bumper taken off but there is no rubbing and I'm very happy. I'm glad I had a competent shop do the install because I know others with similar setups (6" lift and same specs on wheels/tires) with tons of rubbing. Hopefully this can help.IMAG0921.jpg
  10. Apr 25, 2016 at 6:37 PM
    Rubbing will have to do with wheel offset as well.
  11. Apr 25, 2016 at 6:59 PM
    Most of the 6" + lifts that I've seen up close don't appear to be ideal at all when it comes to serious off roading. Looks cool as hell but thinking the ride sucks once you get off road (not a beach). In some cases maybe defeats the purpose. I've followed some super high lifted trucks up Moffat Road (google it) during hunting season and they were bouncing all over the place to the point of being ridiculous.
    robie56 likes this.
  12. Apr 25, 2016 at 7:01 PM
    XXX DITTO's
  13. Apr 25, 2016 at 7:08 PM
    42"'s may require a diff ratio upgrade I'm thinkin. (Axle upgrade too)
  14. Apr 25, 2016 at 7:48 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    I think the Tundra is a terrible truck to take off-roading, during hunting season on gravel roads I have to keep my truck in 4wd because the diff lock doesn't lock anything unless it detects slippage. Also, I don't like to take a 50k $ truck through brush and have more of a chance of putting dents into it. This is the only reason that I posted my truck for sale, I would be better off in a wrangler or tacoma with a beefed up suspension. I have a BDS installed on my Tundra and it comes with a life time warranty on all parts with no questions asked or reason of abuse.
  15. Apr 25, 2016 at 8:02 PM
    Any 4X4 can get scratched if you aren't afraid to take it off road no matter what size it is. The Tundra is an excellent truck to take off road. Every 4X4 has it's limitations. What's important is knowing yours. Many of us here are quite competent when it comes to 4 wheeling no matter what we are driving. You are clearly in the minority. There are literally millions of full size truck owners out there that spend big bucks , 60K+ or more and are not afraid of actually using it. Go to Oregon and see what the loggers do with their new full size trucks, including Tundras. IE: WORK TRUCK!!! There are a couple of options that you can do to improve 4X4 capability. Auburn limited slip, ARB Locker. No offense, but if you have to keep your Tundra in 4X4 on a gravel road with out losing control, then I might want to question your driving abilities. I've been wheeling for 42 years. But what do I know?? Wrangler??? Give me a break....... I'll be more than happy to take you to school.
    462Loadtoad and zcarpenter92 like this.
  16. Apr 25, 2016 at 8:07 PM
  17. Apr 25, 2016 at 8:11 PM
    Snap Happy.............Second Period bell just rang!! :headbang: (I forgot I'm 60, 44 years wheeling)
  18. Apr 25, 2016 at 8:17 PM
    You are better off with one one these. Cheaper than 50K and doesn't need gas and hard to scratch up if you don't take it out of your driveway:
  19. Apr 25, 2016 at 8:20 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    A wrangler or tacoma can go more places than a full size truck, mainly because of size. When I had a Wrangler I would drive around full size lifted diesels that were stuck in the mud and continue to my destinations. I'm aware that any 4x4 can get scratched but when I want to keep my 50k $ vehicle scratch free, it limits my areas that I can drive; or I can buy a 12k $ vehicle that can do more in the mountains that I'm interested in and not have to worry about more rock chips, scratches, and dents. I'm actually from Oregon and at the age of 35, I've been in the mountains since I've been young. A lot of the roads where I go hunting require at least a diff lock to make it through because of an up hill climb. Don't act like I don't know what I'm talking about.
  20. Apr 25, 2016 at 8:29 PM
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    I've got a rock warrior crewmax on 37's and full long travel. Easily cleared the 50k mark. whats wrong with putting scratches on it? Gives it character. I mean if you buy a 4x4 and have no intentions of using it or afraid to get it scratched then whats the point? That's like paying for a hooker to babysit your kids. And you don't even get a BJ out of it.
    veg hed, Black Wolf and zcarpenter92 like this.
  21. Apr 25, 2016 at 8:30 PM
    You don't. I lived in Oregon. Drain. Set chokers/landing chaser for 2 1/2 years. My first 4X4 was a 57 CJ5 that I totally rebuilt before you were born. Wranglers suck. Obviously a Jeep can go more places than a full size truck. I had a brand new 75 Ford reg cab w/360 V-8, no locker, stock bull shit tires and took it almost everywhere, even steep cat-made fire trails. Before you were born..
    bandit likes this.
  22. Apr 25, 2016 at 8:32 PM
    bandit
    bandit New Member
    Duh Tundra
    That moment when vet's start replying to sandy snatches rebuttal....Time to grab a tampon
  23. Apr 25, 2016 at 8:35 PM
    You pretty much summed it up. :thumbsup::thumbsup: (By the way, how much are hooker baby sitters going for?? ) heh heh:rofl::goingcrazy:
    bandit[QUOTED] likes this.
  24. Apr 25, 2016 at 8:38 PM
    bandit
    bandit New Member
    Duh Tundra
    Last I checked they were still on discount! they only charged me VD and a doctors visit to get it cleared up!
  25. Apr 25, 2016 at 8:41 PM
    bandit
    bandit New Member
    Duh Tundra
    I forgot I had to bring ketchup and conditioner too. so keep that near by.
  26. Apr 25, 2016 at 8:41 PM
    Rock Warrior with a SC?? Very cool. Be careful you might scratch it.
    bandit likes this.
  27. Apr 25, 2016 at 8:42 PM
    That really sucks.
  28. Apr 25, 2016 at 8:43 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Myrtle Point, "Obviously a Jeep can go more places than a full size truck" my whole reasoning for getting a Wrangler or Tacoma because of size. Wranglers suck because of why? I'm able to go down and up mud trails that a full size truck can't go through because of size.
  29. Apr 25, 2016 at 8:44 PM
    bandit
    bandit New Member
    Duh Tundra
    Could be worse....we could've joined the national guard....
  30. Apr 25, 2016 at 8:46 PM
    bandit
    bandit New Member
    Duh Tundra
    fineeeeee I'll just go park it in my vagina and keep it scratch free....oh wait there might still be sand in there from my last deployment :itllbuffout::tumbleweed:
