Those 3m headlight repair kits work!
Discussion in '1st Gen Tundras (2000-2006)' started by JTRCY, Nov 3, 2019.
  1. Nov 3, 2019 at 8:43 PM
    JTRCY
    JTRCY [OP] New Member
    Julian
    2006 4x4 Tundra Double Cab
    Tip - buy them one Ebay brand new for about $13-14 instead of the $25+ they want at autoparts stores
    Primalbryan, bmf4069, Ostrich and 6 others like this.
  2. Nov 3, 2019 at 8:57 PM
    JTRCY
    Julian
    One kit did both headlights and I polished up the foglights, marker lights and tailights with it too. Best $14 and 35min I ever spent. Was considering buying the Ebay replacement housing for about $100, but then I'd have to install, aim and obviously they probably wouldnt be the same quality, not to mention something rusty breaking in the process. Damn shit ass rusty steel and bolts and brackets everywhere in the engine compartment...
  3. Nov 3, 2019 at 8:59 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Nice job OP..considering on doing these to my commuter car.
  4. Nov 3, 2019 at 10:03 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Just an FYI. I would be saving up for new headlights. Those kits are a temporary fix. Your headlights will turn yellow and hazy again. And if you polish them again they will do it quicker because everytime you do it you are thinning out the plastic lens. I have never seen a headlight last past a year after being polished.
  5. Nov 3, 2019 at 10:37 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    I redo mine on my Sequoia about once a year. The 1st gens are really bad about it. I hit them with wet 2000 grit, then 3000, DA polisher with cutting compound, then DA again with wax. I pull them out when I do this so the polisher doesn't shake the mounts around. Probably takes about 15 minutes each light including removal and reinstall, I've got it down pretty fast now. I tried 2 different replacement lights on Amazon and they shook all around like crazy, just garbage lights. Go OEM or clean them.
    15whtrd, FrenchToasty and hammeron like this.
  6. Nov 4, 2019 at 5:35 AM
    JTRCY
    Julian
    perhaps so, but I'd bet it'd be a couple years until it'd get as bad as it was beforehand. Wonder if there's a miracle wax protectant that would alleviate the clouding? Some of their kits include a wax protectant of some sort - maybe that's the secret to a longer lasting restore.
    No need to take them out to use the 3M kit though - it's just a 3" wheel on a drill - no vibrations, just light smooth direct pressure.
  7. Nov 4, 2019 at 5:46 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    After restoring keeping them waxed helps keep them from clouding. Or you can use a plastic safe clear coat spray to stop the effects of the suns uv rays.
    speedtre and jtwags like this.
  8. Nov 4, 2019 at 6:08 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I was about to say the same thing. I did the 3M kit this past February and my headlights are already starting to discolor again. But it only cost me $11 and bought me some time while I figure out what I want to do next.
  9. Nov 4, 2019 at 6:15 AM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    The trick is to use the Sylvania kit..
    https://www.amazon.com/SYLVANIA-Hea...uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
    which includes a UV blocker clear coat as the final step and then install these..
    https://www.weathertech.com/lampgard/
    2 years out on my Wife's 2005 Mazda 3s and they are still perfectly clear.
    hth,
    B
    speedtre likes this.
  10. Nov 4, 2019 at 6:16 AM
    db52282
    db52282 New Member
    David
    Georgia
    2017 Silver Tundra Limited
    Agree ... had the very thing happen on a car I used to drive. Had to end up replacing the head lights with OEM. A friend at a body shop told me that some OEM headlights have a "clear coat" kind of material on them and when you sand it to remove the hazing you also remove that clear coat. So... I tried buying some "clear coat" in a can and reapplying it. Didn't work too well. I guess that is why I am not a painter. :)
  11. Nov 4, 2019 at 8:40 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Just an FYI - Sam's club will do this service for $39 and offers a 5 year warranty. I had them do my Chevy a few years back when they were only charging $25 for this service and it was money well spent.
    JimboSlice413 likes this.
  12. Nov 4, 2019 at 8:47 AM
    bvia
    bvia New Member
    None
    Wow..sounds like a good alternative!
    B
  13. Nov 4, 2019 at 8:53 AM
    SouthPaw
    2000 Limited 4x4 AC
    Especially when time is money. When I was younger, I had less money and more time so I would do it myself but now that I am older and have more money and less time; it's well worth it. I had a few friends take there's in and here are the results. Granite, his were pretty roached and I would have probably just replaced them but for what they started as, they cleaned up pretty damn well I would say.
    z-WZe-iDQw0hsCaDzivasQTMJJevMElwFKEtvq9A_4e6a2a233928f1c039864f3cf91e0fe9da755efb.jpg
    9pelEv2kf2dbKvsnMxVIxXoMSXXwrnV4KYCyCVUP_012ed9252688cb94d8dcf2994757c39a58f0d440.jpg
    nFV0uAuukDHAaoLPxj-2jcu5X0KK2Niau5Gtq302_e54d4b13c5ca80609a3fb145fdcb42207e5de46c.jpg
    jOY8GUvWBfGWyhwaUIEMhF8Sxyxk22zBNmifra-W_8940e626492966274836939539e8606a78b816ec.jpg
    uedUdIFwCQ3wVv3SoDgd0P6A5hzst4pUhMXlUm0d_cc8851fcfc1bc7c0a95dd835c50c45ec904f1c73.jpg
    lYyR5iEwURju1GSz_8mLYmtUyU52jpTCqunWjq3n_0082fe6a8ca3c19d971464b494037b6af79aadb3.jpg
    MS22 likes this.
  14. Nov 4, 2019 at 8:54 AM
    DireWolf
    DireWolf The Dark Lord - Tundra Owner
    North East Florida
    2016 Dark Gray Tundra SR5 (MGM)
    none
    The perfect solution already exists, and it was around for many many years, but manufacturers figured and are counting on the yellowing to simply sell new headlights. The solution is simple bring back glass headlights, done and over with. Am quite surprised as to why some third party vendor has not jumped on all over it.
  15. Nov 4, 2019 at 8:57 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
  16. Nov 5, 2019 at 6:34 AM
    JTRCY
    Julian
    I'm not sure whether I'd trust Sam's to properly mask off the adjacent sheet metal (2 layers tape, etc.) Having just done it myself, there's a fair amount of opportunity to toast the paint with the sanding pads or edge of the disc if you're not paying a lot of attention to avoid it.
  17. Nov 5, 2019 at 6:39 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Make sure you clear coat them after you’re done or they will go yellow and nasty real fast
    bvia likes this.
  18. Nov 5, 2019 at 8:10 AM
    SouthPaw
    2000 Limited 4x4 AC
    This is a picture I found on another forum of what they taped off. My truck is knocking on almost 20 years old and it has the body to prove it lol. Half the reason I have this truck is so I don't have to worry about it getting dents/dings and my Duramax can sit at home.
  19. Nov 10, 2019 at 5:12 PM
    Professional Hand Model
    Hand Protectors
    Polish is a one and done fix IMO. Trust me on this.
    Buy new ones and they’ll last another 10 years.
    As for the fogs assys. You can clean up the lens, do a light sand, and spray them with acrylic spray and they will look new again. The headlamps and side markers are a different story. Buy new.
    SouthPaw likes this.
  20. Nov 11, 2019 at 8:36 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    This is the way to go. If you're paying $20 every year to redo your foggy lights, the ROI on a new set will be a number of years but, they'll pay for them self and you won't have the labor of taping off and sanding and polishing every year.
  21. Nov 11, 2019 at 8:38 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yep. I did the 3M kit at the beginning on 2019 and my lights already look bad again. It's time for new ones but I'm not ready to fork out the cash just yet.
    @Professional Hand Model did you score your new assemblies off eBay?
  22. Nov 11, 2019 at 8:41 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Remove the freshly restored lights and speak with a 2k automotive clear. Use 2k clear it will last for years and years. You could do a few coats and wet sand in between and polish smooth. If you don't use some kind of UV protection varnish or 2k clear they will go back to looking like crap again very soon
    bvia and Professional Hand Model like this.
  23. Nov 11, 2019 at 9:03 AM
    Hand Protectors
    I’ve done mine in the past and followed the instructions using the 3M kit. They looked way better, but didn’t last. I hear you on the protective coating, but after cleaning they still didn’t have that fresh hot new model crispness that everyone wants. These new housings are fairly cheap at around $115 from Big Gurrl by Akkon.
    These come in a few darker shades just like all really really really good looking models should.
    bmf4069, SouthPaw and Pudge[QUOTED] like this.
