This what your truck looks like with the Air Dam deployed.
Discussion in '3rd Gen Tundras (2022+)' started by FALQN, May 13, 2022.
  1. May 13, 2022 at 5:59 PM
    FALQN
    FALQN [OP] New Member
    Midnight Black, 4x4 Crew, TRD Sport
    OEM Running Boards, Wheel Locks, Hard Cover, Home-made Kicker Sub
    Fooling around and experimenting. Looks pretty cool (beefier) with the air dam deployed at 40 mph. It is at the bottom with the square notches in it. Retracts at less than 40 mph.B254FB36-4AAC-4192-AE4C-5423AA2F6639.jpg
  2. May 13, 2022 at 6:01 PM
    AZBoatHauler
    So.Arizona
    And what happens when there is a tire tread in your lane during rush hour with traffic on both sides?
    :anonymous:
    It would be pretty sweet if the TSS could sense and raise it but I doubt we are there yet.
    Patriot, FirstGenVol, TK1979 and 3 others like this.
  3. May 13, 2022 at 6:03 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    How did you get it to come down while being stopped?? Is there some sort of override?
    AZBoatHauler likes this.
  4. May 13, 2022 at 6:07 PM
    FALQN
    Yes, there is an override which is needed to perform some maintenance. When you turn the truck off you must push up on the wiper “mist” option for two seconds and it will deploy manually, in order to perform maintenance as stated in the owners manual. To reset it you need to turn on the truck and put it into gear and it will return to the home position.
  5. May 13, 2022 at 6:08 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Try "Up, Up, Down, Down, Left, Right, Left, Right, B, A"
    If not this video explains:
    https://youtu.be/TM1UT2yZu8U?t=14
  6. May 13, 2022 at 6:11 PM
    FALQN
    I’m assuming it is installed on all models SR5 and above (but this is just a guess). I did not read that you could disable it, unless Techstream can turn it off. It is supposed to deploy for high speed stability.
  7. May 13, 2022 at 6:20 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    Interesting…and good to know if I ever buy a 3rd Gen.
    EDIT…it seems fairly open underneath in the video above. What maintenance is Toyota referring to?
  8. May 13, 2022 at 6:20 PM
    99ways2die
    99ways2die New Member
    I did my 1st oil change without deploying it for maintenance, but .......... let me get this straight wizards of engineering at Toyota:
    At 40+MPH I am now going to plow right into that poor opossum/etc, splatter its guts all over the front end and potentially break brings, instead of possibly rolling over the poor thing, without a scratch on him or my truck???
    Who will be the 1st to cut this stupid thing off, or otherwise disable it one way or another?
    I wish I were kidding, but I'm 100% serious here - how many times have you have a situation where you couldn't stop or swerve to avoid something in time (at speed), and the only choice was to go over that thing (animal/tire/box/you-name-it) hoping for the best.
    -99
    PS:
    The first jackass who tells me to drive more carefully or slower gets my airdam lowered over his head...at 40+MPH!
    :p
  9. May 13, 2022 at 6:42 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    ...Select, Start. That's how my brother and I started most Contra games :rofl:
    Beak01, Shall79, IslandStyle and 9 others like this.
  10. May 13, 2022 at 6:59 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Just lift your truck and run 37's for more clearance. :D
    Seriously though. I'm wandering if I could try removing the Air dam and leaving just the motor in.
    This truck is still new, so I'm hoping for a way to disable it in future. There apparently some offroad packages that doesn't come with air dam. I think only the SR5 TRD offroad packages doesn't come with Air Dam right now. Maybe TRD pro too. So a way to simulate that either with flash or some kind of plug in option for the connector once you remove the motor.
  11. May 13, 2022 at 7:03 PM
    99ways2die
    Same;
    If you get to it before I do, report back to us if you notice any difference at all on the highway/etc.
    Thanks.
    ScootARoot likes this.
  12. May 13, 2022 at 7:40 PM
    Swarley
    Swarley New Member
    I believe this feature is not available with TRD offroad packages.
    iforceAZ, BaldMenace and ChucklesToy like this.
  13. May 13, 2022 at 8:25 PM
    Most modern pickups and pickup based SUV’s have lower front air dams to aid in aerodynamic drag reduction to increase MPG’s. At least this one isn’t deployed at low speeds. They do nothing until wind resistance starts to create drag (around 55-60mph). My 2000 model has a lower air dam on it. All my Cheby’s did too. I’m not a fan of over complicated wizz bang tech like powered aero. I’d rather not have one on my truck just from a simplicity standpoint.
  14. May 13, 2022 at 8:31 PM
    Swarley
    Swarley New Member
    How much does it really help with mpg?
  15. May 13, 2022 at 8:36 PM
    think about all the threads on here about shitty MPG’s after leveling (raising the front end). This is a way to lower the front end and direct the airflow around the nose of the truck. It’s possibly good for 1-3mpg depending on speed. On a stock truck.
  16. May 13, 2022 at 8:43 PM
    Craigaz
    Craigaz New Member
    Craig
    2022 4x4 CrewMax Limited w/TRD offroad package
    My TRD OR has it.
  17. May 13, 2022 at 8:44 PM
    Saltyhero13
    I wouldn't expect more than +5%:
    https://ecomodder.com/wiki/Front_air_dam
    You have to keep in mind this is one of many MPG strats integrated into the car.
  18. May 13, 2022 at 9:47 PM
    xc_tc
    xc_tc New Member
    Can’t complain about fuel economy if you remove the spoiler. Purpose is 100% fuel economy but its active so it can be raised for off-roading. It doesn’t lower if you have H4 or L4 engaged.
  19. May 14, 2022 at 6:33 AM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    Canadian TRD OR do not have this air dam.
    Outbound and WAtundra4x4 like this.
  20. May 14, 2022 at 7:37 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    I hope there is a way to disable it if need be. I drive logging roads in Maine and easily go over 40 mph. A good bump or something in the road that I normally would clear seems like it would go right through that thing
    Tundra'25 likes this.
  21. May 14, 2022 at 7:54 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I’m in full agreement with you here. The fact that my 2015 lacks features that have been added to the the tundra each year after my purchase continually reminds me of why I am happier without these potential areas for failure. Some changes have been bonafide improvements that would have been nice. The list is short though; better head unit and lights, pretty much.
    WBW likes this.
  22. May 14, 2022 at 8:09 AM
    Jermajerm
    Jermajerm New Member
    Jeremy
    That’s because it only boosts MPGs. Liters/100 kilometer hot fix will be offered in a later update.
    Txrx, NORTHof54, Tundra'25 and 6 others like this.
  23. May 14, 2022 at 8:20 AM
    vosaeroplane
    vosaeroplane New Member
    2022 Tundra SR5
    5% at your stock configuration. But if you change that like lifting your truck off the ground higher wouldn’t that just cause significant drag instead?
  24. May 14, 2022 at 8:47 AM
    Saltyhero13
    Sure it can offset the gains of the airdam but it doesn't outright prevent the benefit of an airdam.
    Lifting creates at least two problems. First it may take the car out of the sweet spot zone; how much a car is from the surface of the road and its effect of MPGs. Lifting outside the zone will typically add more air pressure under the car and may also increase turbulence. By lifting you are also increasing the frontal area of the car which also increases drag.
    Ride height's impact on lift and drag:
    https://youtu.be/rN5nOCsLUUw
    ChiefG likes this.
  25. May 14, 2022 at 8:56 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Probably the same or similar thing that would happen if you were driving a standard height passenger car, like a Corolla or Camry. You're going to hear some noises and likely some damage.
    Black Wolf, Kagisexton and 22PlatWCP like this.
  26. May 14, 2022 at 10:08 AM
    AZBoatHauler
    So.Arizona
    Unfortunately I’ve had the experience on I-10 in Phoenix in a 300ZX. That’s why I drive SUVs and Trucks now (ones that don’t have drop down air dams to appease the EPA). A couple grand in damage from road debris is dumb.
    Wynnded[QUOTED] and 1lowlife like this.
  27. May 14, 2022 at 10:12 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    This thread for me is just another reason not to buy a 2022..:eek:
    That list is getting longer and longer every day..:D
  28. May 14, 2022 at 10:58 AM
    22PlatWCP
    22PlatWCP New Member
    Mississippi
    2022 WCP Platinum 4x4
    If an air dam is going to prevent you from buying one then I seriously doubt you’ll ever buy a Tundra newer than 2021.
    tundznoff, Dhust27, Henry1jg and 3 others like this.
  29. May 14, 2022 at 11:06 AM
    Outbound
    Aaron
    Northern Alberta
    Along with the other capabilities, the removal of the air dam is one of the biggest reasons I ponied up for the TRD OR.
    Yaboy[QUOTED] likes this.
  30. May 14, 2022 at 11:25 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I stated ANOTHER reason, not the only reason.
    I drive for a living and I see things daily in the road that would take that thing out.
    But you are right about one thing, I seriously doubt I'll ever buy a Tundra newer than 2021.
    I'll be considering another brand when it's time to buy another pickup.
    The 2022 Tundra is one of the ugliest trucks ever produced.
    Just my 2¢
