This may be a stupid tire question...
Discussion in 'Wheels & Tires' started by 14TundraSR, May 13, 2019.
  1. May 13, 2019 at 9:46 AM
    14TundraSR
    14TundraSR [OP] New Member
    Kevin
    2014 Tundra Double Cab SR
    This may be a stupid question, and I think the answer is no, but I will ask anyways. I have a set up 275/70r18 BF Goodrich All Terrain KO2's on my 14' Tundra. Tires are currently white wall out. I probably have around 35-40% tread left. A couple of the tires have started wearing or "cupping" pretty bad on the outside edge, even with rotations every 5,000 miles. So here is my question: Can I have the tires remounted with the black wall out putting the worn edges on the inside? I know it CAN be done, I guess the question really is, does that screw anything up?
  2. May 13, 2019 at 10:14 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    The question is if you are having problems with your tires do you really want to risk your life or someone elses because you dont want to correct the problem?
    Can it be done? Yes
    Should it be done? NO
  3. May 13, 2019 at 10:16 AM
    Blueknights75
    Ron
    Clayton, NC
    Yes and Yes
  4. May 13, 2019 at 10:20 AM
    I agree with @Gotyour6. Once tires are cupped that bad, they are done. With that low of a tread remaining, I wouldn't risk it. I would get new tires, alignment, and any other replacement items required.
    Black Wolf likes this.
  5. May 13, 2019 at 10:27 AM
    14TundraSR
    Kevin
    Thanks for the input. I'll just plan on a new set of skins. Also going to add some 5100's when I replace the tires.
  6. May 13, 2019 at 10:34 AM
    Smart decision, especially from the safety perspective. :thumbsup:
  7. May 13, 2019 at 10:45 AM
    n2deep
    n2deep Pavement Princess
    Naww you can still run those without any safety issues. Have done it for years
  8. May 13, 2019 at 10:52 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    With the new tires have someone look at it to stop the issue with them wearing.
  9. May 13, 2019 at 10:57 AM
    ...yep.....alignment check.
