This look torn or normal?
Discussion in '1st Gen Tundras (2000-2006)' started by fighthedude, Apr 11, 2021.
  1. Apr 11, 2021 at 8:25 PM
    fighthedude
    fighthedude [OP] New Member
  2. Apr 11, 2021 at 8:34 PM
    vfrkent
    vfrkent New Member
    Kent
    2004 Tundra AC S/C
    Model:'04 IS Tundra AC. Power train :V8 4x4, TRD S/C, IPT valvebody, TRD dual exaust, TRD LSD, JBA Ti headers. Interior: TRD boost gauge, TRD Floor mats, Blackwood dash kit, Suspension :TRD off road pkg, Bilstein 5100 shocks, TRD 18x9 wheels, Michelin 275/60-18, Urathane frt swaybar & rack bushings, Helwig 1.125" rear swaybar. Body: Hollandia 790 Sunroof, Muth heated signal mirrors, PopNlock tailgate auto lock, TRD skidplate, Bedrug, Bed extender, Red clear LED tail lamps & 3rd brake light. Brakes: 5th Gen 4Runner Calipers and 338mm x 32mm rotors, Oreilly's Brake Best Select Ceramic pads.
    Looks normal!
    Regards,
    Kent
  3. Apr 11, 2021 at 8:36 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    The top piece is basically just a boot that is a press fit over the bottom portion of the joint to retain the grease. Looking at the pic, it looks pretty worn, I would check those for sure.
  4. Apr 11, 2021 at 8:46 PM
    fighthedude
    So it looks normal and it looks worn. Perfect.
  5. Apr 11, 2021 at 8:57 PM
    TILLY
    Massachusetts
    Take the weight off the tire and check for any excessive play, side to side, and up and down in the joint.
    peanut likes this.
  6. Apr 12, 2021 at 5:38 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Normal.
    Grease bladders plump full with minor film leakage at the steering knuckle contact surface. As long as the joint has grease, no worries. Drive it until replacement required; i.e. no grease in bladder and/or discernable wear in the joint, whichever comes first.
    Life will depend on service, but for normal driving, I've observed old-school Toyota tie rod ends go ~200K miles without replacement.
    BubbaW likes this.
  7. Apr 12, 2021 at 9:51 PM
    Torn or normal? Boot looks normal in the angles provided. Joint could be worn, can't tell by looking at them. If the truck drives normal, no worries. If you're having issues, then investigate. Play in the joint means time to replace.
  8. Apr 13, 2021 at 2:00 PM
    Beefnbread
    Beefnbread Electric Soup
    Oregon
    2000 SR5 Tundra 4x4
    Not too much grease coming out so I say it looks like average wear. I saw grease coming out on mine the other day so I think you’re good :rolleyes:
