Thinking to add windshield banner to top of windshield.Question regarding blocking the sensor/cam
Discussion in '2.5 Gen Tundras (2014-2021)' started by CanTundra, Jan 6, 2022.
  1. Jan 6, 2022 at 4:32 PM
    CanTundra
    CanTundra [OP] New Member
    2021 Tundra TRD Off Road
    I like to add one for sun protections and I noticed sensor in glass . I am wondering if I run banner just above sensor if I will be ok or do i have to be for example 1" above the sensor?
    2021 trd off road
  2. Jan 6, 2022 at 4:37 PM
    2mchfun
    Curious about this as well.
  3. Jan 6, 2022 at 4:47 PM
    The tint shops will tint around it but it will look funny because the shaded area around the sensor will be below the tint strip. Someone on here has a pic of theirs.
    2mchfun likes this.
  4. Jan 6, 2022 at 4:51 PM
    CanTundra
    the way I do it on all my cars is outside banner which is not a tint but a satin flim
    2mchfun likes this.
  5. Jan 6, 2022 at 4:52 PM
    A guy at work did a vinyl strip on the outside and it looks like shit IMO.
    2mchfun likes this.
  6. Jan 6, 2022 at 4:54 PM
    Here is one that I found.
    2mchfun likes this.
  7. Jan 6, 2022 at 4:56 PM
    CanTundra
    thats tint from the inside I am doing it on the outside.
  8. Jan 6, 2022 at 4:57 PM
    2mchfun
    There are a few here in the forum with a tint brow. Thanks!
  9. Jan 6, 2022 at 5:00 PM
    2mchfun
    Kinda wanna do some graphic or maybe text. Just can't make a decision yet. Probably just leave it alone until It gets more usage.
  10. Jan 6, 2022 at 5:03 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    684EDEF0-EF5D-479F-B7E1-FED0F90BBEFC.jpg Were is the sensor located? Is it in the mirror and is it the auto darkening one? I have a letter banner and a dash cam shoved in mine and as long the sensor on mirror isn't with in 6mm of being blocked my auto darkening function works.
    You can always get a cheap sheet of tint from walmart or a parts store and cut a small piece and cover it to see if it will effect it before shelling out money to have a professional banner put in place.
    Hope this helps in someway or another. :)
    2mchfun likes this.
  11. Jan 6, 2022 at 5:04 PM
    It's referring to the Safety sense sensor that is only on the 2018 and newer.
  12. Jan 6, 2022 at 5:05 PM
    2mchfun
    I knew I had seen a Toytec banner here somewhere! Thanks for posting!
    NueveTundra[QUOTED] likes this.
  13. Jan 6, 2022 at 5:50 PM
    NueveTundra
    Planet Earth
    Since its the safety sense sensor I would measure from top dow to were it starts and if its past 4" down then just do a 4" banner or stop right above it if its a tint strip. Can't remember off the top of my head plus it varies from state to state on the allotted section of tint or banner on the front windshield. Seems the pic posted of the one with tint banner stops right above it.
  14. Jan 6, 2022 at 7:11 PM
    CanTundra
    thats what I am going to do. stop just on top of camera
    NueveTundra likes this.
  15. Jan 9, 2022 at 7:12 PM
    luckystiff
    luckystiff New Member
    Ken
    2016 XP in MGM
    You want to stay at least 1/2” above the top of the flat top triangle view window for the camera. I am an ADAS specialist diagnose the systems for a living.
  16. Jan 13, 2022 at 5:03 PM
    CanTundra
    so basically in line with the bottom of the dot matrix looks to be about 1/2"
  17. Jan 16, 2022 at 7:45 PM
    Buhockey22
    Buhockey22 New Member
    Marc
    20 Cement LTD CM
    AJT, Bed Lights, Tailgate Lock, Intake
    Tint shop put a 5 inch on mine, doesn’t bother it all.
    CanTundra[OP] likes this.
  18. Jan 16, 2022 at 8:03 PM
    CanTundra
    Tint or solid sticker
    Inside or outside ?
    post pic if you can
