Thinking I should get better brakes
Discussion in '2.5 Gen Tundras (2014-2021)' started by Shadowfax1, Feb 11, 2022.
  1. Feb 11, 2022 at 8:58 AM
    Shadowfax1
    Shadowfax1 [OP] New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    The stopping power of the OEM pads and rotors seems pretty pathetic. And a tad worrisome for hauling big trailers.
    Looking for recommendations for better pads and rotors. I’ve never done anything but OEM brakes on my previous cars but this is the first one I’ve had where I feel like the factory brakes aren’t nearly as good as they should or could be.
    BecauseRacecar likes this.
  2. Feb 11, 2022 at 9:20 AM
    Stoptech Sport cryo treated, slotted only rotors and pads.
  3. Feb 13, 2022 at 9:47 AM
    a522467
    a522467 Life’s short. Live now.
    Michelle
    Ohio
    2020 Black Tundra Doublecab 4X4 SR5 with SX pkg
    Rear spring upgrade, rear shock upgrade, front & rear sway bars, bed step, bed mat, console organizer & tray, black lug nut covers, rear underseat storage box, black seat covers, Bluetooth CarPlay adapter, LED fogs, blue footwell lighting, LED cargo, reverse, tail, and stop bulbs, tinted tail and 3rd stop/cargo lights, tinted glass all around, tinted front emblem, matte black tailgate emblem inserts, retractable tonneau cover w/trac system and load bars, front facing camera, 8” exhaust upgrade, LED bed lights, 8-ball shifter knob, shifter boot, LED headlights, custom wheel center caps, 3”x30’ tow recovery strap, bed rail clamps, LED puddle lights, phone mount, OBD2 scanner, touchscreen glass protector/overlay, trailer hitch lock, tire traction aid, tinted license plate cover, power relay module, 6-way fuse block with cover, stainless mesh cowl screens, LT265/70R18 A/T tires, driver’s side swing case toolbox, dual air horn kit, rear Husky Liner, cat converter theft deterrent covers, front & rear dash cam, LED tail light bar, trailer plug wiring harness, locking fuel door, matte black interior door handles, glovebox & fuel door keyhole decals, TUNDRA sill plates decals, chalk bag cup holder / trash can, HD Roadmaster active suspension kit, HD front struts, Backlit window control panel, tailgate gap cover, matte black radio surround. https://www.tundras.com/threads/740-yota-2020-sr5-4x4-dc-w-sx-pkg.79742/
    What pads? Posi Quiet ceramic?
  4. Feb 13, 2022 at 9:59 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    EBC yellow pads will completely change/improve your braking distance. They're also dusty AF but the dust is worth the confidence they provide. They eat rotors so some guys I know just run OEM rotors with the EBC yellow for cost savings
  5. Feb 13, 2022 at 10:11 AM
    2mchfun
    Stoptech cryo slotted rotors and EBC yellow stuff pads. Great solution! 20220201_121256.jpg
    dpast88 and Shadowfax1[OP] like this.
  6. Feb 13, 2022 at 11:12 AM
    bryan s
    bryan s New Member
    NEPA
    2016 202 tundra crew cab
    3 1/2 rough country lift 295/60/20
  7. Feb 13, 2022 at 12:18 PM
    timsp8
    NY
    Another vote for stoptech cryo slotted rotors and ebc yellow pads. Skip powerstop. There’s a lot of threads with powerstop issues. Mine only lasted about 10k.
    eccracer104 and Shadowfax1[OP] like this.
  8. Feb 13, 2022 at 12:46 PM
    bryan s
    bryan s New Member
    NEPA
    I must have got a good set then.. Ill have to try the Stoptech then thank
    Shadowfax1[OP] likes this.
  9. Feb 13, 2022 at 4:20 PM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    Are you sure you have factory rotors and pads?
    I and many others find them to be some of the best brakes on any vehicle around.
    Mine sure feel great, and I just replaced them on the front 2 weeks ago (OEM rotors and OEM pads), they are strong like brand new again.
    At many dealers it seems you have to specifically ask for factory pads or they give you cheaper lower quality ones, at least in my areas that's what they all pushed unless I nailed them down on it.
    Brings you back more often for brakes so they make money probably, idk.
    I don't really tow yet tbh but I can't see ever needing aftermarket brakes for normal use.
    Good luck and let us know how they do over time.
  10. Feb 13, 2022 at 4:47 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    What about the EBC USR slotted rotors and yellowstuff pads? Are EBC rotors just not any good or is a cost thing? 68B65D44-7A7B-4837-9C34-3FECB8ED95F6.jpg
    agrestic1 and Shadowfax1[OP] like this.
  11. Feb 13, 2022 at 5:02 PM
    Jchetty
    Jchetty New Member
    I would look at more aggressive pads and checking your brake fluid. Rotors main purpose is to act as a heat sink. I will say that Stoptech makes an awesome product.
    Brake fluid is often overlooked. It may look fine at the master cylinder but could be boiling at the calipers. During my unsuccessful auto-x days, I would do a caliper bleed before and after each event.
    The last thing I can say is to check your tongue weight.
    HulkSmurf14 and Shadowfax1[OP] like this.
  12. Feb 13, 2022 at 7:11 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Trailer should have its own brakes. Heck my truck stops faster with trailer as its brakes are so good it slows the truck down.
    Jaypown, 17inferno and Shadowfax1[OP] like this.
  13. Feb 13, 2022 at 10:28 PM
    Shadowfax1
    Hmm. Well, I don’t know that I can be sure. I just bought the truck on New Year’s Eve. Only had 27K on the odometer and it clearly hadn’t been used as a work truck, so I assume the pads and rotors are original.
    That said, I find the stopping power to be pretty bad. I came to the truck from a 4Runner which had phenomenal braking power and its Toyota pads and rotors lasted me - no joke - 113,000 miles even though I’m quite hard on my cars. The truck is heavier etc. - of course it’ll take longer to stop. But I don’t find it very good, and certainly not in comparison to the other trucks I test drove. FWIW, Consumer Reports also for the 2018 model year rated the Tundra’s brakes to be one of its worst marks.
  14. Feb 13, 2022 at 10:32 PM
    Shadowfax1
    Agreed. I’m not actually towing yet, except twice a small utility trailer. Wanted to get used to the truck before towing any major trailers, especially having never driven a land yacht before getting this truck.
    I’ve only had it for a month and a half. My observations on the truck’s braking distance are based solely on the truck alone without trailer.
  15. Feb 13, 2022 at 10:33 PM
    Shadowfax1
    Good point to check the brake fluid. Hard to imagine it’d be a big problem at 27K miles, but it’s not impossible. Toyota Certified, so theoretically they did that before selling it to me…theoretically.
  16. Feb 14, 2022 at 5:10 AM
    timsp8
    NY
    They probably didn’t change the fluid if it looked good to save them time and money even though it doesn’t take long. It’s just maybe 30 pumps of the brake for the rear and less for the front. Might be 2 quarts or so. I’d say change it when you do your pads and rotors. I’ve read that it’s easy to get condensation in it and that’ll hurt your braking power.
    https://www.tundras.com/threads/tundra-maintenance-guide.315/#post-4466
    • Replace brake fluid every 2 to 3 years or 24,000 - 36,000 miles.
  17. Feb 14, 2022 at 7:01 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    I would also say to replace your rubber brake lines to SS lines.
    huntertn and Shadowfax1[OP] like this.
  18. Feb 14, 2022 at 10:32 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    My thought, as well. Many people think our trucks have crap brakes, but they’re still capable of activating the ABS when you put the wood to them. Maybe going away from the more pliable rubber lines and moving to stainless hoses would help. I sure know I had way less spongy feel in my old quads when I would go to braided lines…. Lose that flex and transfer the pressure more effectively.
  19. Feb 23, 2022 at 3:12 AM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
  20. Feb 23, 2022 at 4:16 AM
    pearlpower
    pearlpower New Member
    2014 CrewMax in Radiant Red
    Stoptech cryo, yellow pads, change brake fluid if needed. Done. Every other option is less. Been there.
  21. Mar 13, 2022 at 10:01 PM
    TexMexR1
    TexMexR1 New Member
    Jesus
    DFW
    2016 Tundra Limited
    3" Lift Leveling Kit 20" TSS (Silver&Machined) Wheels Low profile Tonneau Bed Cover
    I have done much research on forums about this topic and still need some advice
    Went in for an Oil change and was told I need to replace my Rotors(they are warp) and Brakes, I'm almost at 60K.....
    Do I need to go OEM all around or Cyro slotted rotors/ NOT with OEM Pads? Where is the best place to get Stoptech Cyro Rotors?
    Thanks
    16 Limited Tundra, 3 inch leveling kit w/ 20" TSS wheels
  22. Mar 14, 2022 at 4:57 AM
    timsp8
    NY
    I ordered my stop tech rotors from tire rack, but just search online for the best price.
  23. Mar 14, 2022 at 9:59 AM
    oh_really
    oh_really New Member
    NoVa
    2019 Tundra CrewMax Limited Cement
    What is the part# for the EBC yellow pads? Where are you all getting them from?
  24. Mar 14, 2022 at 10:48 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    @memario1214
    memario1214 likes this.
  25. Mar 14, 2022 at 10:51 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Are you looking for just pads?
  26. Mar 14, 2022 at 11:37 AM
    adamreinhardt
    adamreinhardt Blk 17 Platinum 4x4
    Seattle
    2017 Platinum in Midnight Black Metallic
    I love my PowerStop Severe Duty Truck/Tow, have rotors and pads on front and back. Felt like a great upgrade over OEM. Only about 3k miles in so no clue about how they’ll last, but another great thing is I got both sets nearly half price off Amazon. I barely paid over $400
    TexMexR1 likes this.
  27. Mar 14, 2022 at 8:01 PM
    04rktaco
    04rktaco New Member
    Lee
    California City
    2014 SR5 TRD crewmax 4x4
    All-pro rocksliders RCI aluminum skidplates TRD pro suspension TRD pro exhaust coachman 1inch lift shackles cooper tires
    I like the stock brakes too just put new oem rotors and pads on the front and still running original rears with 90k on truck.
  28. Mar 14, 2022 at 8:16 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Any experience with slotted and drilled? Just wondering why you suggest slotted only.
  29. Mar 15, 2022 at 3:42 AM
    Tundrafan23
    Tundrafan23 New Member
    Wow, I'm surprised to hear this, my 2020 has a bed topper and stuff in the bed at all times which adds up to around 500 pounds and it stops on a dime with the stock brakes.
  30. Mar 15, 2022 at 4:52 AM
    Slotted and drilled are more prone to pulsation. I had slotted and drilled before my StopTechs.
    Baja Mike[QUOTED] likes this.
