Thinking about removing leveling kit....crazy?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Hammy68, Oct 26, 2018.
  1. Oct 26, 2018 at 7:53 PM
    Hammy68
    Hammy68 [OP] Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    I just got my 18 TRD Crewmax less than than weeks ago and had 275/70 18 Ridge Grapplers put on in deal. Truck looked super sharp and tough and I assumed, as I always leveled my Tacos, that it would look even better with the nose lifted a little. I went with a 1.5” spacer from RockTrix as I had read that 2” would make it look nose high, which I do not like whatsoever. After having the 1.5” installed 2 days ago, I am not ecstatic about the look and lines of the truck. I have looked at all angles, parked everywhere, and feel it looks just weaker, or the tires appear too small- something I just don’t like 100% about it- sometimes parked it looks fine, other times, nose high...depends what angle etc....so I’m constantly looking to see if I like it, then I’m disappointed. I do like some rake, but don’t want bigger tires or to chase the front height by going higher in the back. Sorry about the long post, but I’m regretting now jumping into the level and thinking about going back stock with the 285/70s and will look like a moron for wasting money at the shop and having to have them removed and alignment again. Any thoughts?
  2. Oct 26, 2018 at 8:21 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Have you considered new shackles in the rear? 1 - 1.5 I'm would add a little rake back to it. relatively cheap.
  3. Oct 26, 2018 at 8:23 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    :popcorn:Tuning in... leveling kit is on my future project list.
    You should post some pics so we can see what you’re describing.
    Sunnier and Hammy68[OP] like this.
  4. Oct 26, 2018 at 8:46 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    You need to do what makes you happy as long as you can afford it.
    People get divorced all the time, that costs way more money.
    You thought the grass would be greener and it wasn't.
    JoshuaA, T-Rex266, Black Wolf and 3 others like this.
  5. Oct 26, 2018 at 8:47 PM
    Hammy68
    New Hampshire
    Stock in first two pics. Looks good sometimes dead on from side, other than that it looks high from other angles. Worried adding height to rear will make the tires look even worse.
    0BF9D59D-D784-4C44-8A8D-9E96DD21A6A9.jpgA4AE3CF5-BD32-4394-B38D-DAD4A33A45E7.jpg 363CB2F7-6560-44F5-862E-CE95FBC710F5.jpg 66C53238-2DF7-4181-A497-87A2E0E26D25.jpg 393CFEF8-AE94-43F8-8657-A792EF829BFE.jpg
    RLHULK likes this.
  6. Oct 26, 2018 at 8:52 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Completely agree with you. It’s the gap between the wheel and the fender. With stock wheels it just flat out looks worse leveled. I would just raise the rear and get bigger tires. If not, I’d put it back to stock.
  7. Oct 26, 2018 at 8:55 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I'd ditch the leveling kit but that's just me.
    Maybe adding wheel spacers will give you the illusion of larger tires?
    Nice truck btw. Always loved that color
    JoshuaA, Black Wolf, Sunnier and 2 others like this.
  8. Oct 26, 2018 at 8:56 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I agree with Joon. Bigger tires and wheel spacers would help too.
    4x4_Angel, Hammy68[OP] and joonbug like this.
  9. Oct 26, 2018 at 9:11 PM
    Hammy68
    New Hampshire
    Thanks all for the opinions so far. Was thinking I’m crazy. Must be the Tundra’s lines and shape I’m not used to. Always had tacos and they looked mean with a slight level. My gut just keeps telling me I don’t like this look. I’ll figure something out, but didn’t want to spring for bigger tires, have to start cutting possibly etc. I’m a closer to stock more minimalist look kind, usually. Just like I beefier stance and tires.
  10. Oct 26, 2018 at 9:24 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    Its all in what you like. No fault for trying something and it not feeling quite right. I bought mine with the original 32 inch Michelin's. When those wore out I went one size up to what you have. first with no lift... They fit, well enough with no rub, but I wanted the leveling kit, coil overs, which picked it up 2 inches... I liked the leveling but missed the rake, the ride is a bit more firm. My mileage went down 10% with the added weight of 10 ply. I ordered the 1 inch lift for the rear that is getting installed Monday... I swear this is where it ends... same place where I started with better shocks and just a little more clearance and options for the future. It was a great truck as I got it and still is, thought my wallet is thinner LOL, but I say, do what makes you happy :) Too many things in life are unpredictable. These trucks, as I have discovered, are pure pleasure. You get exactly what you put into it, and it stays there waiting for you the next day, just as you left it. I am happy to have a grin on my face every morning when I start it up and head off for my office job, and I have the same grin when I drive back home. And that, for me, makes whatever else that happens, well worth the few bucks I spend, or misspend. I don't mean to get too philosophical on you, but if it captures you attention and makes you happy,,, do it, and when you are ready for something else, change it. Enjoy the ride.
    with the leveling done... no rear lift
  11. Oct 26, 2018 at 9:29 PM
    15whtrd
    15whtrd Mr. Blonde
    I think it looks great on the 33s! Thats the size I want.
    groverdill and RLHULK like this.
  12. Oct 27, 2018 at 5:42 AM
    Hammy68
    New Hampshire
    What size are those tires? I do have the Ridge Grapplers 275/70 on the stock wheels.
  13. Oct 27, 2018 at 5:51 AM
    Hammy68
    New Hampshire
    Thanks man, great words of wisdom and nice truck! I do enjoy changing it up and have loved doing mods on this so far. I was thinking I should have had the dealership put 285s on and that would have filled the wheels wells better, however the nose high thing wou have still been an issue. Can you post pics as soon as you add the 1 inch? What did you go with for a the 1”?
  14. Oct 27, 2018 at 6:01 AM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    you may want to drive it for a few weeks . being so new it will settle at bit . I put a 2.5" leveling kit and thought it was too high at first.
    RedRegCab and Hammy68[OP] like this.
  15. Oct 27, 2018 at 6:02 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Agreed.
    I leveled mine by lowering the rear to match the factory front height on 32" tires.
    An Air-Lift system in the rear allows me to add rake if I want/need it.
    4x4_Angel and Hammy68[OP] like this.
  16. Oct 27, 2018 at 6:03 AM
    Maybe go with the 285s and ToyTec shackles in the rear
    bigzrs01 and Hammy68[QUOTED][OP] like this.
  17. Oct 27, 2018 at 6:35 AM
    Hammy68
    New Hampshire
    You think a spacer level will actually settle? I was thinking Bilsteins May, but spacer lift probably would not.
  18. Oct 27, 2018 at 7:10 AM
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    I've just purchased a set of 275/70r18 for the stock offroad rims, and I'm wanting to rise the front just a tad as well. The 2" spacer gets sh*t on, but since I do mostly highway I can understand the financial upside, but as Hammy said, I too dont want to chase the level to the back end. If money werent an issue, I think the Bilsteins 6112's at the 1.3 (second lowest setting) would be the perfect rise, and I've been reading that the lower setting give a very nice ride. Anyone have any experience with the 6112's at the 1.3 setting? Other options that doesnt just improve the look but also the ride?
    Hammy68[OP] likes this.
  19. Oct 27, 2018 at 7:21 AM
    ^^^^^ applies to all matters in life. Couldn’t have said it any better.
  20. Oct 27, 2018 at 7:28 AM
    Professional Hand Model
    Hand Protectors
    Do add some forward rake back into it. It looks good IMO.
    I’d go with your gut and go back to stock by removing the spacer. Then, just take some time and mull over what tire options you should do when the ones you have wear out.
  21. Oct 27, 2018 at 10:27 AM
    Scpringle
    Jackson MS
    not the spacer (lift) but the springs /shocks should settle after some miles .
  22. Oct 27, 2018 at 11:36 AM
    clemelmer29
    clemelmer29 New Member
    Didn’t like it then don’t like it now, how much you take for it man?
  23. Oct 27, 2018 at 2:35 PM
    Hammy68
    New Hampshire
    You want to buy the truck with the lift in, or out?? :)
    15whtrd likes this.
  24. Oct 27, 2018 at 4:35 PM
    clemelmer29
    I can’t really make up my mind which I like better, not sure whether to level mine either. Would like to try the 5100’s on my 2013RW, probably do some more research before commit.
  25. Oct 27, 2018 at 4:41 PM
    clemelmer29
    Oh and btw I don’t think you hurt the appearance of your truck at all, I would keep it and experiment with tire sizes.
  26. Oct 27, 2018 at 4:42 PM
    15whtrd
    15whtrd Mr. Blonde
    I still can’t believe some of you don’t like the look of a lifted tundra. Level in the front and people are saying it looks bad? That’s weird to me. Of course giant tires look awesome but a lot of times they’re very unnecessary as the ones you chose will do a fine job. And in my opinion your truck looks good. If you are going to tow maybe lift the rear a little bit or some airbags. I mean if you really wanted to know what it would’ve looked like lifted, just put the jack underneath the front before you did all that work LOL
    Seriously not trying to come off as an ass but I think your truck looks great and you should leave it alone.
  27. Oct 27, 2018 at 5:13 PM
    hudrock
    hudrock New Members only jacket
    So Cal
    25 MGM Limited
    I think it looks good as is also..the 5th pic in the snow is perfect IMO
  28. Oct 27, 2018 at 5:34 PM
    Hammy68
    New Hampshire
    LOL, you’re not coming off as an ass- that’s why I posted my internal dilemma, so I could get others’ opinions. As I suspected, it’s subjective and just as I feel, I’ve got opinions ranging from it’s great to I should remove the spacers! BTW, I did try jacking it up and that’s what made me send back a 2” kit and go with 1.5”- it looked great in the driveway that day and didn’t seem as high. They look awesome to me lifted, if done right- I just gotta find the right balance for my liking.
    15whtrd[QUOTED] likes this.
  29. Oct 27, 2018 at 6:00 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    It’s your truck. Make it yours.
  30. Oct 27, 2018 at 6:57 PM
    tmart
    tmart New Member
    Travis
    I have learned that tundras need 37s. With how big the truck is 37s make it look perfect no matter how you do it. So long travel it and throw em on or do a 6 inch lift. Sorry I’m no help, just planting the seed for you ;)
