Thinking about LED's but unsure what's available
Discussion in 'Lighting' started by nnane, Sep 7, 2017.
  1. Sep 7, 2017 at 8:41 PM
    nnane
    nnane [OP] New Member
    Alan
    2017 Qicksand SR5 Crewmax
    The OEM headlights are acceptable, but just barely.
    The OEM fog lights on 2017 SR5 are a joke. I don't drive in much fog, but living in the country, I'd rather have super-bright lights to blast ahead when needed, so my first thought would be to replace the fog lights with something BRIGHT— especially if the switch is right there on the turn signal.
    I don't want a light bar unless it looks styled somehow for the truck. The ones that look like a bolted-on lego brick are certainly bright, but because I'm not flushing vigilantes for border patrol, I thought I would see what's new and cool in the world of truck lights.
    Any ideas? Thanks!
  2. Sep 7, 2017 at 8:43 PM
    Vleds.com also BajaDesigns.com also Rough Country has a 30" single row led light bar that mounts in space above license plate
    nnane[OP] likes this.
  3. Sep 7, 2017 at 8:46 PM
    ubserved
    ubserved New Member
    Michael
    2017 Toytota Tundra Platinum Crewmax
    Grillguard, front LED light bar, Leer Tonneau cover, rear LED bars
    This is what I did for the front and bck of my truck for the extra light when needed.
    nnane[QUOTED][OP] likes this.
  4. Sep 7, 2017 at 8:53 PM
    That a ranch hand grille gaurd?
  5. Sep 7, 2017 at 8:58 PM
    PermaFrostTRD
    Northern NY
    You can nab the morimoto xb fog lights for about $160. Great upgrade
    There's also a "how to" mount a double row 30"-42" lightbar in the valence above the license plate on a different forum. I did it and it's great.
  6. Sep 7, 2017 at 9:05 PM
    I cut mesh screen out on mine
    Eclipsed & Floating likes this.
  7. Sep 7, 2017 at 9:07 PM
    nnane
    Alan
  8. Sep 7, 2017 at 9:11 PM
    Troynjade
    Troynjade Beast mode 5.7
    Troy
    Wa
    2008 Toyota Tundra
    7" procomp lift, 3" body lift. Amp research powerstep, 22" fuel rims, 38" nitto tires, Custom leather seat covers black with red stiching, alpine inz928 deck, 2x10" subs, 1500 watt alpine amp, 400watt amp for door speakers. Procomp Traction bars, fuel grille, Black headlight housing with 6000k hid, rear airbags, rear and front camera, k&n air intake, 40" light bar. Rear under bumper led light bar. Prodigy trailer brakes. 5.29 Nitro Gears. Auburn Posi Rear End. Dirty Deeds Budget Dump.
    I know what your saying. I have HID's for my headights and fog lights which are very bright but. On country roads I have a light bar like some other posts thats somewhat hidden. Its a great way to add light when you need it 20170907_210748.jpg
    Les7311 and nnane[OP] like this.
  9. Sep 7, 2017 at 9:39 PM
    ubserved
    ubserved New Member
    Michael
    No. It's the Wranglerguard from GoRhino.
  10. Sep 7, 2017 at 9:40 PM
    ubserved
    ubserved New Member
    Michael
    I like the mesh. It prevents anything from going through your grill or radiator...such as protestors. 8)
  11. Sep 8, 2017 at 12:06 AM
    reimord
    reimord New Member
    The Rigid fog lights are great also. They are just a little bit pricey.
  12. Sep 8, 2017 at 2:09 AM
    Not-required
    Not-required New Member
    Kawehi
    2016 MGM Crewmax 4x4 Tundra
    Thule racks, Philips LED headlights and fogs, TRD pro grill and hood buldge, front window tint 35%, ESP under seat storage.
    Baja designs fog lights are really bright. I have the sport but if you need crazy bright you can step up to the pro series. 00455af81ecd37fd7acfe371ec6cadf6_66ae75731330b417d2f7b1e724257f101266372d.jpg
  13. Sep 8, 2017 at 5:09 AM
    nowayout
    nowayout New Member
    NY
    17 CM
    @Not-required is the the wide/cornering beam in the squadron sport?
  14. Sep 8, 2017 at 6:42 AM
    Not-required
    Kawehi
    Yes and yes.
  15. Sep 8, 2017 at 7:00 PM
    MMichaelJJ
    MMichaelJJ New Member
    14 Platinum CM
    I wish Baja Designs would make a DOT fog like Rigid. I'm sure theirs would be brighter and A LOT EASIER to install and aim.
  16. Sep 8, 2017 at 7:28 PM
    Not-required
    Kawehi
    I'm not sure how strict your inspections are but I haven't been flashed when using my BD fogs.
  17. Sep 8, 2017 at 8:40 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Troy
    Why you had to go do that????? Now you fugging wid mah muneeeyyy.
    That is a sweet set up and have been toying with ideas on some bars.
    Nysssss whip!!
    Troynjade[QUOTED] likes this.
  18. Sep 8, 2017 at 8:43 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    :rofl::rofl::thumbsup::thumbsup:
  19. Sep 8, 2017 at 8:45 PM
    Eclipsed & Floating
    Voluptuous Whitey
    The pros are stupid bright!! Sports are good enough in my opinion
