Thick Adhesive Removal
Discussion in 'Detailing' started by ZiaTundra, Dec 20, 2020.
  1. Dec 20, 2020 at 12:02 PM
    ZiaTundra
    ZiaTundra [OP] New Member
    I recently remote my 5.7ltr iFirce badges and have a bunch of thick adhesive left where they were. I tried a blow-dryer and nylon scraper but it's pretty thick.
    Anyone have some advice how to attack this thick adhesive without damaging paint?
    Thank you
  2. Dec 20, 2020 at 12:06 PM
    biebs96
    PA
    3m rubber eraser wheel.
    War Machine, ZiaTundra[OP] and Pudge like this.
  3. Dec 21, 2020 at 5:09 AM
    War Machine
    War Machine SSEM # 5 3MW
    This will do the trick, just be careful. It can possibly mar the paint of you don’t take it easy. Try Goo Gone first, then move to this if necessary.
    Black Wolf likes this.
  4. Dec 28, 2020 at 8:19 PM
    Eleventeen
    Eleventeen New Member
    Louis
    2016 Black CM Tundra
    goo gone and a blow dryer to heat it up. the 3m wheel works great but yes, don't get aggressive
  5. Jan 8, 2021 at 11:47 PM
    Freeezen
    Freeezen New Member
    Citrol 266 is a great adhesive remover.
  6. Jan 9, 2021 at 3:18 AM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    When I removed mine, I got most of it with just a hot gun and a nylon scrapper. Then, believe it or not, I got regular gasoline (yes gasoline) in a syringe and started putting drops on top. Little by little it got removed.
    Don’t forget to wash that area and reinstall your sealant, wax, or whatever you are using as a paint protector.
    jpink likes this.
  7. Jan 15, 2021 at 12:37 PM
    RX7
    RX7 New Member
    2021 Tundra TRD Pro
    I recently removed a LOT of adhesive from my Chevy. This wheel worked great if the adhesive was not not too thick. If it is really caked on, I found that the goo just ended up wrapping around the wheel. In my case I used adhesive remover and a soft scrapper to get the bulk off and then went down to the paint with the wheel. As others said be careful to not over rev it in one spot or you will mark the paint.
    biebs96[QUOTED] likes this.
  8. Jan 15, 2021 at 12:39 PM
    RX7
    RX7 New Member
    2021 Tundra TRD Pro
    A warm(er) and sunny day helped too. Just 15-20 degrees made HUGE difference.
