Thermostat not opening
Discussion in 'General Tundra Discussion' started by JRes1, Jan 9, 2020.
  1. Jan 9, 2020 at 7:49 AM
    JRes1
    JRes1 [OP] New Member
    2004 Tundra SR5
    none
    completed timing belt change, new waterpump etc. truck starts up and runs great. I am not getting the thermostat to open is my guess. I put a new one in and when that did not work , put the old one back, same issue. bottom radiator hose stays cold, truck temp rises and not hot air through the heater. any suggestions would be great
  2. Jan 9, 2020 at 8:19 AM
    15whtrd
    15whtrd Mr. Blonde
    Sounds like you’ve still got air in the system. Have you turned the heater on in the truck while the engine is running to try to burp out any air with your radiator cap off? Also squeezing the upper and lower radiator hoses.
    Jrharvey02 likes this.
  3. Jan 9, 2020 at 8:23 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Throw the thermostat in some boiling water and check if it opens..
    15whtrd likes this.
  4. Jan 9, 2020 at 8:31 AM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    I suspect it has something to do with the pump. Is there a possibility you routed the belt wrong and it's turning the pump backwards???
  5. Jan 9, 2020 at 8:43 AM
    JRes1
    2004 Tundra SR5
    none
    figured it out, air in system needed purging
    15whtrd and Tiamat like this.
  6. Jan 9, 2020 at 8:52 AM
    JRes1
    2004 Tundra SR5
    none
    thanks for all the responses.
