TheBoy's 2013 Sequoia Build Thread
Discussion in 'Sequoia Builds' started by theboy12, Jun 21, 2017.
  1. Jun 21, 2017 at 11:07 PM
    theboy12
    theboy12 [OP] New Member
    Jon
    2013 Sequoia
    It begins...
    The Taco is gone... Time to start my Soccer mom build, the third kid is on the way! I have to say I like the 5.7 it pulls.
    As it sits on Day one a 2013 SR5 package 4wd w/50k on it.
    Mountun Goat, DVYota, CJ21 and 6 others like this.
  2. Jun 21, 2017 at 11:07 PM
    theboy12
    Jon
    2013 Sequoia
    My Tacoma, I'll own one again. Or maybe an FJ. I miss it, I had a lot of good times in this rig on trails in NorCal.
    Mountun Goat, Krezz, DVYota and 2 others like this.
  3. Jun 21, 2017 at 11:07 PM
    theboy12
    Jon
    2013 Sequoia
    And after 10 days:
    5100s all around for now.
    3/2 lift
    BMF 17x8.5 wheels +6 offset (5 inches backspacing)
    285/70/17 MTRs (35 Toyo RTs later after this set is toast)
    K&N
    Exhaust next Thursday.
  4. Jun 21, 2017 at 11:07 PM
    theboy12
    Jon
    2013 Sequoia
  5. Jun 22, 2017 at 5:55 AM
    payyourtoll
    payyourtoll New Member
    Tampa, FL
    my 3rd is on his/her way too, congrats man
    what plans do you have for it?
    theboy12[OP] likes this.
  6. Jun 22, 2017 at 6:56 AM
    theboy12
    Jon
    2013 Sequoia
    Congratulations on the little one!
    I enjoyed modding the heck out of my Tacoma. For now I'm working on UCAs, 3 inch lift up front and 2 in the rear. 35 inch mts. I will end up with Icon or Kings up front at some point, but the rear needs a lot of research. Right now, I can't find any info on aftermarket springs to firm up the back or remote resi's made for that application. It looks like the back only has 5.56 or so inches of travel. So for now 5100s and a rear shock extender.
    After that is done I want to look at front bumpers that are winch ready.
    Ultimate plan, is to make it into a family overland rig that can still DD.
    Cheers,
    -Jon
    payyourtoll[QUOTED] likes this.
  7. Jun 22, 2017 at 9:12 AM
    TheBeast The Beach
    sequoia are very nice and comfy
  8. Jun 22, 2017 at 9:24 AM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Subscribed
  9. Jun 29, 2017 at 3:46 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Hmmmmm:popcorn:
  10. Jul 3, 2017 at 10:29 AM
    Flboarder
    Flboarder New Member
    Charlie
    Granby, CO
    2011 Toyota Sequoia
    Nice looking rig! How are you getting the 3/2 inch lift from the 5100's?
  11. Jul 3, 2017 at 10:40 AM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
  12. Jul 3, 2017 at 10:57 AM
    theboy12
    Jon
    2013 Sequoia
    Hattori is correct. I set the shocks to zero to keep the travel, and limit spring preload, then used an steel spacer puck lift on the top. The ride isn't bad to be honest. I'll still go to beefer aftermarket coilovers later. This will work for the time being.
    -Jon
    Hattori likes this.
  13. Jul 3, 2017 at 6:40 PM
    Flboarder
    Charlie
    Granby, CO
    2011 Toyota Sequoia
    What spacers did you use for the rear? Thinking about going with the ome shocks and springs for the front lift on mine. Trying to figure out what to do for the rears. Also what exhaust did you end up going with?
  14. Jul 3, 2017 at 7:27 PM
    theboy12
    Jon
    2013 Sequoia
    I used the 2inch spacers off of eBay. I believe the supplier/branding was Blitz. They were 55 bucks. I want to get some custom springs bent for 2.5 inches of lift down the road, but I will be waiting until I have a better idea on the weight of the rear bumper w/tire swing out.
    Exhaust goes on Wednesday. It's a manga flow 50 series. I'll post up some pictures and a sound bite. It is the only direct fit weld in that I could get with the two in one out setup. Flow masters are all directional. I also don't want it too loud or raspy since I have little one. At any rate that was the best route I could find without a whole system cat back solution or a lot of rerouting of the pipes. The cat back systems all started around $550 more than this option before install.
    Hope this helps.
    -Jon
    Flboarder[QUOTED] likes this.
  15. Jul 3, 2017 at 8:31 PM
    Flboarder
    Charlie
    Granby, CO
    2011 Toyota Sequoia
    That helps a lot, thanks. I look forward to hearing the sound clip. And possibly seeing a rear bumper in the future.
  16. Jul 6, 2017 at 7:54 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Are rear spacers the only option to lift the rears on these? They look good lifted!
  17. Jul 6, 2017 at 10:45 PM
    theboy12
    Jon
    2013 Sequoia
    No you can have custom springs bent up to probably three inches, after that you'd need to extend the rear axles and a few other things.
    There are no kits for the rear other than spacers though that I could find that were plug and play like the tundras or 4runners. Rear shock options are limited as well.
    -Jon
    BlueBottle[QUOTED] likes this.
  18. Jul 6, 2017 at 10:55 PM
    theboy12
    Jon
    2013 Sequoia
    Here is the exhaust. We were able to find a flowmaster 44 series that was a correct directional two in one out application. I'll post the part number for
  19. Jul 7, 2017 at 10:22 AM
    Flboarder
    Charlie
    Granby, CO
    2011 Toyota Sequoia
    What have you found in your research for getting custom springs made?
  20. Jul 7, 2017 at 10:50 AM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
  21. Jul 7, 2017 at 6:47 PM
    theboy12
    Jon
    2013 Sequoia
  22. Jul 7, 2017 at 10:28 PM
    theboy12
    Jon
    2013 Sequoia
    There are a lot of places that do it. I have heard good things about these guys, and they are in California.
    http://www.bettsspring.com/coil-springs
    There are several others though that do this.
    -Jon
  23. Jul 8, 2017 at 11:15 PM
    theboy12
    Jon
    2013 Sequoia
  24. Jul 9, 2017 at 8:08 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Loved my Tacos......ABSOLUTELY ADORE MY TUNDRA!!! If you like the 5.7 on the sequoia then take that to the next truck.
    Sequoia is looking awesome already, bud! Thanks for sharing your builds with us. Looking forward to what you have in store
    theboy12[QUOTED][OP] likes this.
  25. Jul 21, 2017 at 10:51 AM
    theboy12
    Jon
    2013 Sequoia
    Ya, I like the 5.7 and they just released a turbo for the flex fuel so...
  26. Aug 13, 2017 at 10:30 PM
    theboy12
    Jon
    2013 Sequoia
    Update:
    Dobinsons springs makes an off the shelf +45mm 1.8 inch of lift spring set for the rear. I'm still looking into a custom set as I want 2.25 for an aftermarket rear bumper.
    I picked up a set of Fox 2.5 remote Resi's for $400 bucks, and it looks like I'll be out about $650.00 with the rebuild, $780 with new #650 rate springs. I'm super stoked.
    -Jon
    dcsleeper408 and Hattori like this.
  27. Aug 14, 2017 at 11:23 AM
    Flboarder
    Charlie
    Granby, CO
    2011 Toyota Sequoia
    Did you get a price for the off the shelf vs custom price? I am still looking into front coilovers I want kings but I might have to settle for old man emu
  28. Aug 14, 2017 at 1:26 PM
    Flboarder
    Charlie
    Granby, CO
    2011 Toyota Sequoia
    I couldn't wait the curiosity got the best of me. Called up Dobinson and they said $250 for the 1.8" springs and that they were going to contact the engineer to see if it would be possible/ worth while to make 2.5" springs. How do we round up enough people to get them to design new springs for us select few sequoia people?
  29. Aug 14, 2017 at 10:36 PM
    theboy12
    Jon
    2013 Sequoia
    I don't know, but I'd be in at a 2.25-2.5 inch lift spring. -Jon
  30. Aug 14, 2017 at 10:38 PM
    theboy12
    Jon
    2013 Sequoia
    We could tell them that they would have the market cornered and put them in contact with SDHQ, Downsouthmotorsports, and Wheelers. None of those guys have any off the shelf options that I have been able to find.
    -Jon
