The Professional Hand Model Reinvestment ‘Build’: A Chronological Story.
Discussion in '1st Gen Builds (2000-2006)' started by Professional Hand Model, May 27, 2019.
Thread Status:
Not open for further replies.
  1. Jan 4, 2021 at 5:26 AM
    #241
    06tacomadc
    06tacomadc New Member
    Motor City
    Tundra
    Sorry for all questions... so stock coil and leafs, just bilsteins added?
    Again, thx!
  2. Jan 4, 2021 at 8:26 AM
    #242
    Professional Hand Model [OP] A.K.A ‘Golden Hands’
    Hand Protectors
    Yes. Stock ‘TRD Off Road Package’ Coils. Some of our trucks don’t have these Heavier Duty Coils, so you may get different results. Stock original rear leafs still, as well.
  3. Jan 8, 2021 at 4:14 AM
    #243
    Hand Protectors
    Picked up some items for the truck this week. Still waiting on some backordered HIR Reverse Bulbs to arrive.
    mcharfauros and TokerJoker like this.
  4. Jan 9, 2021 at 1:45 PM
    #244
    Hand Protectors
    Dali Llamas installed. Customized the headrest to fold over the back by poking holes in them. Super comfy!
  5. Jan 9, 2021 at 5:55 PM
    #245
    Hand Protectors
  6. Jan 10, 2021 at 8:05 AM
    #246
    Those look THICC
  7. Jan 10, 2021 at 8:31 AM
    #247
    Hand Protectors
    Yes. The fur pile is about 1” and then there is a rubber perforated backing on the skin side which helps the cover stay ‘glued’ in place. Very comfy. I opted for these as the are easy on/off for cleaning when needed. My old ones were custom and were a bear to remove. These cost $75 each. Customs are around $180.
    Might have to sew my own Arm Rest Covers out of some rugs in the same material/color.
    TokerJoker and FrenchToasty like this.
  8. Jan 15, 2021 at 8:00 AM
    #248
    theoregontrails
    theoregontrails New Member
    you got a link to the specific sheepskin covers? I like the look and simplicity of the cheaper version. Truck is amazing man!
  9. Jan 15, 2021 at 6:14 PM
    #249
    Hand Protectors
    Thank you. The price went up to $89 as of right now. They are super comfy. Stoked to have Sheep Skins again after many years without.
  10. Jan 16, 2021 at 6:46 AM
    #250
    Hand Protectors
    Been busy and haven’t messed around on the truck mechanically in a while. Checked the Oil Cap as this time of year the cold humid short driving on the Island creates Oil Puddin’. Since taking over the maintenance a few years ago, this is a normal occurrence. Pulled the PCV Valve and she was free and clear.
    mcharfauros, Voss and TokerJoker like this.
  11. Jan 16, 2021 at 8:11 AM
    #251
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Those seat covers sure do remind me of all the late '80's Lambo's. I do know your 1st gen drives way better than the Countach, though.
  12. Jan 21, 2021 at 4:25 AM
    #252
    Hand Protectors
    The HIR Bulbs Upgrade is working nicely. They provide enough light to get the job done. Could there be more light? Sure, but these are better than before and no need to add Aux Lights at additional cost/work ($100-300 depending).
    Total Cost of HIR Bulbs $17. Time to replace less than 30 minutes.
    TokerJoker likes this.
  13. Jan 24, 2021 at 4:50 PM
    #253
    Hand Protectors
    Started an experiment on the Original OEM Air Filter Box after watching another thread on Cold Air Intake ‘Stacks’. Didn’t want to spend any money on this so decided to keep with this ‘build’ threads Original Mandate to keep the truck as OEM as possible. Optimization is the key.
    Removed the Air Box for the first time ever and Feather Dusted underneath really well. Heated up the OEM Intake Tip with a Heat Gun and molded the tip a little larger with a little Flair. Also, ported off the squared off edges on both the inner and outer intake pipe.
    A few days later, I moved over to inside the MAF Inlet and Flaired that off. Had a little worry about Air Turbulence prior from study, but so far so good with 100+ miles and no CEL. Truck has gained extra low end power when on the throttle. It has a little extra at mid/high end.
    Never seen anyone else try this so its a first for me. I’ll measure MPG Calcs on the next fill up and if the are really bad I’ll buy a new/used box and revert back. So far the OBD looks good on temps, fuel trims, etc. Engine runs/idles as smoov as always. Feeling good about it.
    Truck Air Box is all OEM with a Toy Filter (experts say this keeps the turbulence down) with 17k miles.
    G_unit3000, mcharfauros, Voss and 2 others like this.
  14. Jan 29, 2021 at 5:40 AM
    #254
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Finally took some time to read through this insightful thread. T’was a very good read... Indeed.
    The attention to detail is nice, Fred.
  15. Jan 30, 2021 at 7:36 AM
    #255
    Hand Protectors
    Thank you. I’ve enjoyed your Build Thread, as well. You brought it back nicely. I never thought I’d have a near 20 year old vehicle that would still run as good as new.
    TokerJoker and N84434[QUOTED] like this.
  16. Jan 30, 2021 at 3:54 PM
    #256
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Absolutely true...
    Tundra2 likes this.
  17. Feb 4, 2021 at 7:11 AM
    #257
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Is this the thread we can use as a guide to bring our 20 year old trucks back to factory standards?
  18. Feb 4, 2021 at 2:35 PM
    #258
    Hand Protectors
    We’ll call it Factory Plus. :D
    Voss and FrenchToasty like this.
  19. Feb 4, 2021 at 2:36 PM
    #259
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    What's the monthly subscription fee for the "plus" features?
  20. Feb 4, 2021 at 6:54 PM
    #260
    Pucks18
    $69.69
    Tundra2[QUOTED] likes this.
  21. Feb 5, 2021 at 3:44 AM
    #261
    Hand Protectors
    We do monthly installment payments if needed.
    Tundra2 likes this.
  22. Feb 6, 2021 at 3:25 PM
    #262
    Hand Protectors
    Cleaned up this thing in the Driver Rear Tail Light Cavity.
  23. Feb 6, 2021 at 3:39 PM
    #263
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    What the hell is that anyways?
  24. Feb 6, 2021 at 3:52 PM
    #264
    Hand Protectors
    Good question. I didn’t snap a pic of the Part# on the cover for some reason. Can’t find the part on any of my Deep Searches. Might be one of those chyna Tracker Units Marbles used to talk about.
    Tundra2[QUOTED] and FrenchToasty like this.
  25. Feb 6, 2021 at 4:12 PM
    #265
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I was thinking it had something to do with a trailer harness given its location.
    I know when I installed the 4pin harness on my truck, it came with a "box." The wires come from factory plug, into "the box" and then into the 4 pin. Not sure why a "box" was necessary.
  26. Feb 6, 2021 at 4:16 PM
    #266
    MotoTundra
    MotoTundra The Ocho
    Don
    Nice detail hand model!
  27. Feb 7, 2021 at 5:01 AM
    #267
    Hand Protectors
    Ends up being a Towing Converter.
    Voss and Tundra2[QUOTED] like this.
  28. Feb 14, 2021 at 11:45 AM
    #268
    Hand Protectors
    Since acquisition of the OBD Dongle, this is my first winter monitoring temps. I’ve noticed (with the OEM Tow Cooler) my trans temps barely reach over 125° in moderate City driving for 20-30 minutes in 40° Ambient Temps.
    Thus, I’ve decided to add a Transmission Thermostatic Control Valve to raise the temps quicker on short drives and cooler Ambient Temps while maintaining them higher. The Valve ‘Bypasses’ the OEM Cooler and sends the fluid back to the transmission without cooling it in cold weather.
    In summer, or anytime the fluid raises above 180°, the Valve opens and allows full fluid flow and the temps maintain. From readings, the Valve always allows at least 10% Flow for Mojo purposes regardless of temps. As the temps rise at the Valve, it opens ever more. At 180° it a full flow.
    The Valve is solid Aluminum (heat sink) and acts as a Cooler in Summer in addition to the OEM Stacked Unit Cooler.
    From readings, many report like myself their fluid temps were in the 120-130° Range. After Valve install, their temps rose fast and then maintained in the 150-160° in winter (even thought the Valve is rated 180°).
    Some report Cooler temps in the Summer as the Valve Body acts as another heat sink.
    I’ll be installing this soon and will report back on findings. Made in USA.
  29. Feb 15, 2021 at 1:35 PM
    #269
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    My temps have been really low lately too. I'm excited to see if this works for you!
  30. Feb 15, 2021 at 4:25 PM
    #270
    Hand Protectors
    Was hoping to install this weekend, but lots of other business might keep me from it. Maybe next week sometime. I’ve everything fab’d up and fittings threads installed with gasket maker.
    FrenchToasty likes this.
Thread Status:
