The never ending tyre fitment debate
Discussion in 'Wheels & Tires' started by Jonesey, Sep 3, 2020.
  1. Sep 3, 2020 at 4:04 PM
    Jonesey
    Jonesey [OP] New Member
    Robin
    Tundra TRD PRO 2019
    None
    Hi All
    i have a 2019 TRD PRO and the tyres I am investigating are Goodrich KOC A/T 275/70/R18 as I have the stock BBS 18” rims. As I am keeping the Tundra stock at this time and do not want to cut or alter or lift anything at this stage, will they fit and run with no issues?? Also is this the biggest tyre I can fit without cutting etc or is there a larger size I can use. Appreciate some advice because Toyota are unsure and so is the 4X4 shop,
    Regards J
  2. Sep 3, 2020 at 4:06 PM
    Welcome from Colorado. Did you try the search feature first?
    BlackSheep and 14burrito like this.
  3. Sep 3, 2020 at 4:07 PM
    timsp8
    NY
  4. Sep 3, 2020 at 4:13 PM
    Blueknights75
    Ron
    Clayton, NC
    295/70/18 is about the biggest you can go with no modifications....
  5. Sep 3, 2020 at 4:14 PM
    Jonesey
    Robin
    Tundra TRD PRO 2019
    None
    Thanks, indeed I did find that thread which was useful, however some tyres of the A/T range at that size have not fitted without some small alterations, and the 285 “may“ need cutting. Just wanted to know if the Goodrich KOC have been fitted to a similar year and model and what was the result.
    Black Wolf likes this.
  6. Sep 3, 2020 at 5:40 PM
    Belated welcome from NY.
  7. Sep 3, 2020 at 6:19 PM
    SteveCanyon
    SteveCanyon New Member
    I DA HO
    2020 TRD Sport
    I have no idea what a tyre is.
  8. Sep 3, 2020 at 6:49 PM
    Brit?
  9. Sep 3, 2020 at 6:50 PM
    Robin...where are you located?
