THE FULL MONTY - HOOD BULDGE LED KIT $10
Discussion in '2.5 Gen Tundras (2014-2021)' started by pop's, Mar 28, 2019.
  1. Mar 28, 2019 at 7:50 PM
    pop's
    pop's [OP] 1794
    Michael
    North Aurora IL
    2017 Tundra 1794 Blue Pearl / 1995 T100 4x4 DX
    $7500 in upgrades
    That's right $10 puny dollars for a cool modern looking full frontal. Purchased on eBay - 2X 85CM Flex Tube LED 6000K White DRL Running Strip Light for Universal Auto Car. Waterproof, Not $1000 like... you know who. 1.25 hours of work gets you the $1000 look that you were saving up for.
    Finding your 10mm socket is the hardest part of this project.
    Remove the 3 hood bulge bolts with a 10mm socket
    Finesse the plastic push pins out of there holes one at a time until the grill pops off.
    Drill out the large plastic rivet at the top of the black grill. Then carefully pry the black grill out of the housing with a standard screwdriver.
    Use a handheld size of Clear silicone to tack down the first strip of LED's inside of the housing, Then Tack the second strip on top of the first so you now have 2 strips on top of each other. run a full bead on the bottom and the center of the strips silicone the black grill back where it came from the wire it up to the headlight circuit.
    IMG_2434.jpg fullsizeoutput_1ac6.jpg fullsizeoutput_1ac6.jpg IMG_2434.jpg Let the silicone firm up for a few hours and reassemble.
  2. Mar 28, 2019 at 7:53 PM
    AZTundra
    Paul
    Phoenix, AZ
    Any pics up close with the light off?
  3. Mar 28, 2019 at 7:57 PM
    pop's
    pop's [OP] 1794
    Michael
    North Aurora IL
    $7500 in upgrades
    I didn't think of that. But the lights are behind the grill and are hard to see
  4. Mar 28, 2019 at 7:59 PM
    AZTundra
    Paul
    Phoenix, AZ
    Got it. I was just trying to visualize the fitment. This is a great alternative.
    pop's[QUOTED][OP] likes this.
  5. Mar 28, 2019 at 8:00 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Wonder what the light output is for that vs the HR one?
  6. Mar 28, 2019 at 8:02 PM
    pop's
    pop's [OP] 1794
    Michael
    North Aurora IL
    $7500 in upgrades
    It's not for blazing a trail, It's legal and easy on the eyes
    texasrho83 likes this.
  7. Mar 28, 2019 at 8:04 PM
    Sas
    OKC, OK
    Eh, legality is going to be local. That's still illegal here in OK.
    B737 and Major like this.
  8. Mar 29, 2019 at 2:52 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    @pop's you kept the truck? What changed your mind? Looks good by the way.
    pop's[OP] likes this.
  9. Mar 29, 2019 at 4:33 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    Yeah looks good, thanks for taking the time to post up the pics.
  10. Mar 29, 2019 at 4:50 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Lol excellent! Thanks for the info!
  11. Mar 29, 2019 at 7:36 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Did you wire it directly to the DRL wiring or use the DRL wiring along with a relay?
    I'd also really like a pic of the housing without the lights on. Thanks for spending $10 more of my $$$!!!
