The dreaded trifecta of error codes/ fuel pump related
Discussion in 'General Tundra Discussion' started by B.Ross, Jan 15, 2020.
  1. Jan 15, 2020 at 9:51 AM
    B.Ross
    B.Ross [OP] New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    After 2 hard/ rich starts this past couple of weeks my truck threw the 4lo, check engine& Trac control lights this morning as I pulled into work. Tundra heads into dealer on Friday. Most likely fuel pump related which was replaced last February. So it's at least under warranty. If they pull it I'm getting a transfer flow 48g put in to save on the labor. So there's that....
    See my previous 2 posts to check my sentiment regarding FFV Tundras.
    Not winning.
  2. Jan 17, 2020 at 3:34 PM
    B.Ross
    Southern Utah
    FYI:
    If any of you have had fuel pumps replaced on your FFV Tundras in recent history you may want to get your truck in and checked.
    My 2012 is now part of the recall. Might be a couple of months to get a pump.
    Free rental cars are being offered btw.
    Looks like a 46g TransferFlo tank is in my future.
  3. Jan 17, 2020 at 3:50 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    You still use your own fuel pump with the transferflow...
  4. Jan 17, 2020 at 5:57 PM
    B.Ross
    Southern Utah
  5. Jan 17, 2020 at 6:02 PM
    Jrharvey02
    ah, I think I misunderstood your first post, my bad, I thought you were suggesting fuel pump issues and wanted to correct this w a new tank. You just want them to install TF tank since they’ve got it off, will they do that? Good luck.
  6. Jan 17, 2020 at 6:09 PM
    B.Ross
    Southern Utah
    They will do it. I get a new Toyota pump per recall installed free by my dealership. I pay for the tank full retail(from dealer). There may be some more discounts in it for me ( dealer service coupons).
  7. Jan 17, 2020 at 6:11 PM
    Jrharvey02
    Lucky. Sort of.
    TheBeast likes this.
  8. Jan 17, 2020 at 6:15 PM
    B.Ross
    Southern Utah
    Yeah, wasn't thrilled to spend $1700 on the Tundra. The pump is probably a month or so out. Trying to save on labor.
  9. Jan 17, 2020 at 6:18 PM
    TheBeast The Beach
    did you get a letter stating yours was part of the recall ?
  10. Jan 17, 2020 at 6:50 PM
    B.Ross
    Southern Utah
    Whatever codes my truck threw at the dealer points to my fuel pump which is the same pump that's being recalled. My fuel pump was replaced a year ago after having similar issues.:(
    Toyota has probably known about this problem for a bit.....
    No letter, sorry.
  11. Jan 18, 2020 at 3:49 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Sorry about your truck man. :annoyed:
  12. Apr 8, 2020 at 8:04 AM
    B.Ross
    Southern Utah
    Well after almost 3 months my fuel pump has arrived. Transferflo tank will be here in 10days, woo hoo !
    Good news for any off you recall guys. Looks like the pumps are starting to trickle in.
