The Best Switch Unit on the Market
Discussion in 'Electrical' started by Baja Designs, Oct 13, 2022.
  1. Oct 13, 2022 at 4:00 PM
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    4x4 sPOD
    Hey Everyone, Our in-house sister company 4x4 sPOD brings the best alternative option to any AUX switch setup on the market. With a fully integrated Canbus system for your accessories for anything with a battery, 12 or 24 volts. They have been the leading Switch module developer since 2005 and always provide satisfaction with their products. Eliminate the rat's nest of wiring with a sleek design that will have just one wire running into your vehicle. The SourceLT powers an extensive 100 amps per unit utilizing 6 30 amp switch terminals. If you’re in the market for a new switch module or are tired of extensively fishing cables around your vehicle consider 4x4 sPOD as your number-one
    source of quality-made products.
    PPQvO306hTGetNxbsH8dPJcHJR5SPjSvFFnHH3L2_2e06050974c086aa589aff844f595b015259e6d8.jpg
    4x4 sPOD SourceLT Mini6:https://www.4x4spod.com/sourcelt_w_mini6_universal_fit
    The SourceLT offers two options upon purchase: the Mini 6 option seen in the images above as well as a Rocker Switch panel option. Both options will come with the sPOD downloadable phone app allowing you to incorporate a wide variety of features from strobe, dimming, momentary, and switch linking. These features will allow you to have full control via Bluetooth from outside your vehicle whenever desired. These features will be limited to the app itself.
    WNTlpL7OehCostiJlWkLl_AZsOTrxKtIQsM6maay_a024f534ebeadcc3e52abbf37399343726996160.jpg
    x9Lme_ay2cNpLvMUHOcBSk6n-M9sVItVMJWMKxGu_98d263c6a9aaf76d7bbc5b3bb60b759068b07d16.jpg
    For any extensive build, 4x4 sPOD also offers the BantamX. The BantamX powers an extensive 100 amps per unit utilizing 8 30 amp switch terminals with the capability to chain in 3 additional units allowing up to 32 fully programable switches.
    4x4 sPOD BantamX w/ Touch Screen:
    https://www.4x4spod.com/bantamx_w_touchscreen_universal
    4x4 sPOD BantamX w/ HD:https://www.4x4spod.com/bantamx_w_hd_universal
    For any inquiries regarding 4x4 sPOD see the listed contacts below
  2. Oct 14, 2022 at 3:40 PM
    4x4WarriorOfRocks
    4x4WarriorOfRocks New Member
    2010 Tundra 4x4 Rock Warrior
    Does the bantam have an option for rocker switches including 3-way (on-off-on) switches? Thanks!
  3. Oct 14, 2022 at 3:53 PM
    Baja Designs
    Bill
    San Marcos, CA
    Hey 4x4WarriorofRocks, With the rocker switch it will only be a two-position switch. You can utilize a three-position switch on both the Touchscreen option as well as the HD panel offered with the BantamX.
    Best,
    Brandon
  4. Oct 14, 2022 at 4:50 PM
    Use the @ symbol in front of the username so that they get a notification. Most of the replies won't be seen unless they come back and read through the whole thread. :thumbsup:
  5. Oct 29, 2022 at 9:45 AM
    4x4WarriorOfRocks
    @Baja Designs How does the HD controller work for lights such as your LP9s which require a 3-position switch? I can't find any info or videos on this. Thanks!
    Baja Designs[OP] likes this.
  6. Oct 31, 2022 at 9:57 AM
    Baja Designs
    Bill
    San Marcos, CA
    Hey @4x4WarriorOfRocks, You can either set the light up to two switches to utilize the high-low function or program just one switch to dim the high beam to whatever output is preferred. The dimming option is a bit more common due to the single-button usage.
    Best,
    Brandon
  7. Jan 4, 2024 at 4:40 PM
    4x4WarriorOfRocks
    Hi Brandon (@Baja Designs),
    Sorry to bring up an old thread, but I am still a little confused. Will the HD controller operate both the LP9 low beams and high beams on one switch? Or would you have to use 2 of the HD switches separately? Thanks!
  8. Jan 5, 2024 at 11:36 AM
    Baja Designs
    Bill
    San Marcos, CA
    No worries at all! With using the HD controller, you will want to put the High/Low functions on separate switches, as well as utilize our upfitter lock-out harness. This will allow you to run one feature at a time so that way you will not blow the board. If you have any other questions please feel free to contact me at bill@bajadesigns.com.
    Best,
    Bill
    Bill Sonevongxay | Forum Sales & Support 
    Email: Bill@bajadesigns.comPhone: (760)560-2252
    4x4WarriorOfRocks likes this.
  9. Jan 5, 2024 at 12:50 PM
    4x4WarriorOfRocks
    Thanks for the info!
