The Professional Hand Model Reinvestment ‘Build’: A Chronological Story.
Discussion in '1st Gen Builds (2000-2006)' started by Professional Hand Model, May 27, 2019.
Thread Status:
Not open for further replies.
  1. Jun 29, 2019 at 8:28 AM
    Professional Hand Model [OP] A.K.A ‘Golden Hands’
    Hand Protectors
    Added some TuRD patches to the headrests. They are iron on types, but currently holding strong in the picture with double sided tape. Adds some flair.
  2. Jun 29, 2019 at 8:36 AM
    Hand Protectors
    Customized a grease tip to pump the 4wd propellor zerks/joints which are difficult to access compared to the rear propellor.
    Pictured is a regular grease tip with a portion grinded off the side so that it allows a superior connection for grease pumping.
  3. Jun 29, 2019 at 8:37 AM
    Hand Protectors
    Hangin’ by the dock of the bay.
  4. Jun 29, 2019 at 8:44 AM
    Hand Protectors
    Sound proofing the smart low cost way using butyl rubber big box window/door tape and repurposed Heller Fresh food insulation that actually is a close OEM match up. Makes a pretty good difference is sound reduction. Or, my hearing is going bad? What?
  5. Jun 29, 2019 at 9:08 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I've been thinking seriously about grabbing a roll of the sound control stuff my company makes for flooring, and using it for this myself. :thumbsup:
    90 mil-thick bitumen will knock down that road noise!
  6. Jun 29, 2019 at 9:14 AM
    Hand Protectors
    I’m familiar with the flooring deadener and that is actually better than the butyl rubber I used. Its heavy and a little harder (I would think) to work with but your product is probably more superior. Your sound system will sound better once you do the doors. Mine does.
    Racingjohndeere55 likes this.
  7. Jun 29, 2019 at 9:18 AM
    Squatting Pigeon
    Holden
    North Texas
    That's what I'm hoping for!
    When it comes time that's what I'll try since I can get it for next to nothing. This stuff is very dense, a roll of 225 sf is damned heavy! It's not nearly as sticky as protecto or actual sound deadening products, so I'll have to prime the metal first, but that'll be easy.
  8. Jun 30, 2019 at 2:56 PM
    Hand Protectors
    The Michelin 285/75/r16 ‘Defenders’ are very good sand tires. Excellent on the road, as well.
    TokerJoker, georgiey22, Pudge and 4 others like this.
  9. Jun 30, 2019 at 3:18 PM
    TylerDurden311
    TylerDurden311 Paper Street
    2018 Tundra CM
    This is one of the best posts I have read... it was like a book, I kept wanting to see what was next!
  10. Jun 30, 2019 at 4:13 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    beautiful. Can't wait for my tundra to show a little age. Really like a fine wine.
  11. Jul 1, 2019 at 8:19 AM
    Sunnier
    Sunny
    San Diego, CA
    This re"build" thread is great! Since I'm not that familiar with various components and locations of each, I'm a big fan of your line drawing labels that help me "see" what all comprises each "system". I say "system" because I also appreciate that you maintain and retrofit one system at a time. Great learner thread for the rest of us. This'll be where I send other 1st gen owners as they sign up to the forum.
    Thank you for spending your time to chronical your work @Professional Hand Model!!
  12. Jul 12, 2019 at 4:39 AM
    Hand Protectors
    Toyed around with going yellow on the fogs. I like to change things up, but the crystal look seems better for some reason. This pic was taken on an ‘Island Hopping’ day.
    Voss and CmdrDaniels like this.
  13. Jul 12, 2019 at 4:49 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Or you could try these. I have em on my truck. But eventually I also added the lamin-x yellow covers.
    https://www.amazon.com/Optilux-HELL...ocphy=1026181&hvtargid=pla-435823007001&psc=1
  14. Jul 12, 2019 at 2:42 PM
    Hand Protectors
    If I did decide to go yeller, I’d try that film you recco’d. My PerfectFit LED’s Fogs Bulbs are brand new and not into buying new bulbs. This film, I assume, can be easily removed?
  15. Jul 12, 2019 at 2:58 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    It should yes.
  16. Jul 27, 2019 at 7:22 AM
    Hand Protectors
    This week in the Chronology: Inspected the ‘V’ belt and it was slightly deteriorated with about 50k miles since replacement. Bought a new one and it took about 30 minutes to install. Only had to remove the A/C line bracket to move that hose ever so slightly.
    Also, removed the bed liner and sprayed Rustoleum liner and re-installed the factory plastic liner which got sprayed, as well. The Rustoleum slightly firms up and rigidifies everything from a structural standpoint. Greased up all the pivot points on the gate and handles.
    TokerJoker, georgiey22 and 00TundraZ like this.
  17. Jul 27, 2019 at 8:30 AM
    Hand Protectors
    The end of day results after clay bar, polish, and waxing. A typical Fantasy Island sunset.
    Pearl-snap, BobTTundra, Voss and 8 others like this.
  18. Oct 25, 2019 at 7:33 PM
    Seina_Yamada
    Seina_Yamada New Member
    2003 Toyoda Tundra SR5
    With your headlights I understand you use katana 9003 For your headlights, but for my fogs I do not see a set for 9005's. Also do you have some sort of resistors and if so what are they?
  19. Oct 25, 2019 at 8:07 PM
    #49
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    You've done awesome things with your truck. Looks great
  20. Oct 30, 2019 at 9:59 AM
    #50
    Hand Protectors
    My fogs are PerfectFits from Headlight Revolution. No resistors on the fogs or the Katanas.
    PerfectFits are not available anymore, but their replacements (under a different name) look the same and have the same specs/LED chip and are probably made at the same factory and branded differently.
    https://headlightrevolution.com/gtr-lighting-csp-mini-led-headlights-9005-9145-bulbs/
    Tundra2 likes this.
  21. Oct 31, 2019 at 5:14 AM
    #51
    Hand Protectors
    Painted up the scratched/dinged up tailgate using 1D6 Lacquer color match and gloss clear coat. Turned out nice, but the new clear coat isn’t as glossy as the factory resulting in a slight matte finish. Also, painted up the rear bumper black plastic with bed liner. Before and after pics.
  22. Oct 31, 2019 at 5:32 AM
    #52
    Hand Protectors
    Some various maintenance and repair items performed recently.
    Rear cab corner leak source fixed. Used Fuze caulk to seal this entry point after a clean up.
    New rear driver bearing time. Finally fixed after 5 years of wha wha wha noise in the cab.
    SeaFoamed the throttle/manifold with their Spray and changed the spark plugs.
    TokerJoker and CmdrDaniels like this.
  23. Oct 31, 2019 at 5:37 AM
    #53
    Hand Protectors
    A mid summer modeling pic from back when things were steamy and creamy.
  24. Nov 3, 2019 at 8:10 AM
    #54
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
  25. Nov 3, 2019 at 8:18 AM
    #55
    Hand Protectors
    Thank you. Pass the knowledge along. This place has taught me mucho.
    Tundra2 and TundraDude18[QUOTED] like this.
  26. Nov 8, 2019 at 7:57 PM
    #56
    JustGotDuals
    JustGotDuals New Member
    So clean and different look without the storage boxes in the bed! Your build is actually making me back track on my decisions on my truck. After riding in my dad's pretty much stock (1st notch on billies) 2000 tundra,...billies at the 4th notch right now kind of really suck to me! Im thinking maybe moving down to the 2nd notch and removing the 1 inch block I put in the rear.
  27. Nov 10, 2019 at 5:32 PM
    #57
    Hand Protectors
    Thank you.
    Do it. These trucks don’t require that extra height for basic off-roading. If you are street driving, then that height is actually even more detrimental to your suspension/drive train components.
    Just my opinion. Not knocking anyone with lifts, spacers, yuge tires, etc.
    I think my next move in 4-5 years, if I still own this truck, will be the Billy 6120’s up front and new 5100’s in rear.
  28. Nov 11, 2019 at 4:59 AM
    #58
    Hand Protectors
    Added some OEM Toy Running Boards scored from a junk yard for $125. Cleaned and painted them up.
  29. Nov 11, 2019 at 8:07 AM
    #59
    Hand Protectors
    Hoopty crook Coon huntin’ with Mama.
    Tundruh and TundraDude18 like this.
  30. Nov 11, 2019 at 8:09 AM
    #60
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Those running boards compliment the truck nicely. Good score.
Thread Status:
