Thanks for having me
Discussion in 'New Member Introductions' started by cprog, Jul 14, 2021.
  1. Jul 14, 2021 at 11:50 AM
    cprog
    cprog [OP] New Member
    I joined the forum because of the rust issue that I have with my 2006 Tundra Crew cab. I love the vehicle but at 109000 mi. I have significant rust issues with the underbody of the truck( I don't live near a coastal area). I took it in to the dealer as a part of the recall and the dealer coated the frame that was visible. It wasn't until I had to mount the spare tire 3 years later that I discovered he didn't even drop the tire to coat the portion of the frame it covered! (He fixed this) I found out that the recall didn't cover the axles and in particular the differential housing. My mechanic got a replacement from a yard but it was in worse shape than my axle. At this point I'm going to try to flex seal the housing in the hopes that it will give me a couple of more years of life on the vehicle. Its a little comforting to know that there are other owners that are having the same issues and I'm looking forward to seeing what solutions they come up with.
    Thanks for letting me rant a little.
  2. Jul 14, 2021 at 11:57 AM
    Where are you located? Sorry to hear the rust monster is ruining your truck. Did you buy it new?
  3. Jul 14, 2021 at 12:04 PM
    cprog
    I'm located in the center of Long Island New York. And yes I bought the truck new. Thanks for the reply.
  4. Jul 14, 2021 at 12:05 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Welcome. Scrape of that rubberized protectorant, wirebrush off the rust with a powered wire wheel and apply POR-15 to help protect from further rust damage.
    Wear scrap clothes, gloves and something to cover your hair as that stuff gets everywhere and doesn’t come off in the wash. Use a tarp to keep from having it spill on your driveway.
    After that just worry about occasional touch up every few years and monitor inside the boxed portion of the frame rails as they will rust inside out.
  5. Jul 14, 2021 at 12:09 PM
    Salty roads in your area have done your truck in. Coating the frame has worsened the situation for some. It traps the moisture beneath the coating and accelerates the rusting process. Rusting is occurring inside the frame rails also and is not coated. Several threads in here about diff cover repairs that you may have already read. Seems the slap some goo on it to patch it or cut it off and weld a new one on are most popular. Generally speaking, oiling the frame and components helps to keep the moisture out. Just spraying the exposed metal parts with PB blaster has worked for many to keep rusting at bay. Or at least minimize it.
  6. Jul 14, 2021 at 12:47 PM
    cprog
    Thanks for that advice I appreciate all the help I can get on this issue.
  7. Jul 14, 2021 at 1:00 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  8. Jul 14, 2021 at 1:06 PM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    Welcome from Delaware
    Good luck
    Thank you for your Service for Us!
  9. Jul 14, 2021 at 1:12 PM
    cprog
    Thank You!
  10. Jul 14, 2021 at 1:22 PM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Welcome!
  11. Jul 14, 2021 at 1:24 PM
    Welcome neighbor.
  12. Jul 14, 2021 at 1:24 PM
    As you may have read on some of the other threads, pics of the problem help greatly. Also picks of your truck in general is appreciated.
    Jack McCarthy, bmf4069 and BubbaW like this.
  13. Jul 14, 2021 at 1:36 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    and adding Vehicle Description to Personal Details page helps alot also IMHO !
    Personal Details | Toyota Tundra Forum (tundras.com)
    abcinv and KNABORES[QUOTED] like this.
  14. Jul 14, 2021 at 3:42 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Welcome from SoCal
  15. Jul 14, 2021 at 3:46 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Welcome and thank you for your service! :cheers::oldglory::cheers:
  16. Jul 14, 2021 at 4:00 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I concur. We like pics. Like, a lot.
    BubbaW likes this.
  17. Jul 14, 2021 at 4:02 PM
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR10
    Greetings from Georgia
  18. Jul 14, 2021 at 4:16 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania, thank you for your service
  19. Jul 14, 2021 at 7:36 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! I hate to hear about such a bad experience, and thank you for sharing. I do hope your truck lasts as long as you want it to, even with the rust issues.
  20. Jul 14, 2021 at 9:32 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  21. Jul 15, 2021 at 12:54 AM
    AZTundra
    Paul
    Phoenix, AZ
    Welcome from AZ.
  22. Jul 15, 2021 at 1:01 AM
  23. Jul 15, 2021 at 2:45 AM
    Welcome from Ohio
