Thanks for all your indepth info! I'm greatful!
Discussion in 'Lighting' started by KyToy79, Jan 10, 2023.
  1. Jan 10, 2023 at 12:55 AM
    KyToy79
    KyToy79 [OP] New Member
    2007 White Crewmax
    2.5in lev kit, Rough country shocks, Bullbar, BFG AT, Add on Fog lights, .....more to come
    I've been tio alot of toyota pages over the years, yet this group seems to be the very best yet, Thanks you all!
    RainMan_PNW and Taco-Spike like this.
  2. Jan 10, 2023 at 4:43 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Taco-Spike likes this.
  3. Jan 10, 2023 at 6:15 AM
    Taco-Spike
    Two Trucks
    Welcome!
  4. Jan 10, 2023 at 6:17 AM
    waynescaggs
    waynescaggs No more of that .
    Wayne
    Idaho
    2019 tundra Crewmax Limited
    Welcome from Idaho
  5. Jan 17, 2023 at 5:54 PM
    KyToy79
    2007 White Crewmax
    ok. I'm using a 4 pin switch. yellow, red1,red2,black
    ....my yellow (pin1)should go to direct 12v power
    ....my red2 and red3 are tied together, and going to acc in fuse box.
    my blk (pin4) to ground near fuse box at 10mm bolt.
    ... I used a light blue wire and a green wire under the dash, but something is wrong
  6. Jan 17, 2023 at 5:55 PM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Hmm we're going to need some more info. What are you trying to do??
  7. Jan 17, 2023 at 5:58 PM
    I saw in a different post that he is looking for fog light wiring under the dash to add an aftermarket switch.... :notsure:
  8. Jan 17, 2023 at 8:56 PM
    KyToy79
    2007 White Crewmax
    sorry you all, I thought was responding to my own message.
    ..yes, I'm having a hard time with adding foglights using the factory 07 Tundra sr5 wires.
    ( I have the led fog lights with the ring, that I'll incorporate somehow.)
    ....thank you for your advice!
  9. Jan 17, 2023 at 9:11 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Let’s start with a picture of this switch and the pigtail or connector it’s using. Need to understand better what exactly we’re looking at for connections. Typically you’ve got the switch circuit (2 wires) and backlight/illumination (2 wires).
    Will the lights themselves be plugging into factory wiring in the front bumper? Is there factory wiring there? What sort of kit do you have for the fogs - some more specific details will be helpful.
    There isn’t a switch that will handle the load of powering the lights themselves directly, so you’re looking at needing a relay. If you’re using factory wiring, then need to determine if the truck has the relay or not (or the wiring at all - it’s been a while since I dig into the 2007 specifically).
  10. Jan 17, 2023 at 9:18 PM
    KyToy79
    2007 White Crewmax
    I've got a relay, and yes sir, it does have the factory wiring, I do have Power at the backlit switch but foglights still do not work.
    I'll get a pic or two of what I did and that might help. Also, I'll get few close up pics of the wires and switch
    thanks again
