testing fuel pressure with crank, no start condition
Discussion in '2nd Gen Tundras (2007-2013)' started by Jollyshame, Jul 23, 2024.
  1. Jul 23, 2024 at 9:57 PM
    Jollyshame
    Jollyshame [OP] New Member
    2012, v8, 5.7L
    Hi,
    I have a 2012 5.7L. It cranks, but won't start. I hooked up a fuel pressure tester. When I cranked the ignition I get 42psi, but when I stopped cranking it drops 10 psi. Then stays at that pressure for 5 minutes.
    I don't know how to interpret this data? Is the fuel pump good or bad? All the procedures I've come across is testing while vehicle is running. Should have 42-44psi, drops some while running, should hold pressure for 5minutes after engine shut off.
