Terrible squeak! 2014 tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by Zeb8806, Jul 31, 2018.
  1. Jul 31, 2018 at 5:54 PM
    Zeb8806
    Zeb8806 [OP] New Member
    2014 Tundra Crewmax Limited
    Hey all, I’ve developed a terrible squeak that I can’t for the life of me pin point. It is loud enough outside the truck that I can hear it inside the cabin with the radio on. Frankly it’s embarassing driving down the street. It seems to be coming from the front end somewhere but I’m really not sure. It only happens on bumpy sections of the road. A large bump may not trigger it but lots of small bumps certainly will. Really looking for some help on different things to check. Thanks!
  2. Jul 31, 2018 at 5:56 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Skid plate?
    NewImprovedRon, joonbug and TheBeast like this.
  3. Jul 31, 2018 at 5:59 PM
    Anyway to audio record when u drive by or video it when ya drive by? Just straight away, turns, braking?
  4. Jul 31, 2018 at 6:03 PM
    TheBeast The Beach
    any recent mods to front suspension ? or alignment or new tires ?
  5. Jul 31, 2018 at 6:10 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Check your HVAC condenser bushings
  6. Jul 31, 2018 at 6:14 PM
    Zeb8806
    No skid plate on the truck.
    Braking has no effect.
    Not confident enough to say turning has no impact.
    No new mods.
    I lubed the condenser bushings with a silicon spray lube, if you watch the videos pointing to that squeak it sounds just like that. Maybe I should try white lithium grease?
    I will try and capture audio of the sound.
    NewImprovedRon likes this.
  7. Jul 31, 2018 at 6:23 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Didnt notice any videos posted
    I cant remember what I used, but maybe just some wd40 would work - if thats rhe issue .
    Edit: I think I used dry tephlon
  8. Jul 31, 2018 at 6:29 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    UCAs?
  9. Jul 31, 2018 at 8:04 PM
    Darren509
    Darren509 New Member
    Darren
    Dayton NV
    2016 White Tundra TRD
    Mine had a horrible noise over small bumps and at idle . It was the main wire harness that goes to the pcm. In the engine bay the harness is hooked on with a plastic clip. I ran a big zip tie through it and cinched it up. Maybe same as yours?
  10. Jul 31, 2018 at 8:20 PM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    Is it from right or left side of the the truck, can u pinpoint that?
  11. Aug 1, 2018 at 3:53 PM
    TundraRunner481
    TundraRunner481 Kinda New Kinda Not
    SB
    So. Oregon
    2018 Cement SR5 CrewMax
    That's what mine was, super annoying...did it when shutting doors too.
    14burrito[QUOTED] likes this.
  12. Aug 2, 2018 at 3:07 PM
    Zeb8806
    I tried lubing the condensor bushings again, it seemed to greatly reduce the squeak. I think I will try again with some white lithium grease and continue to monitor.
  13. Aug 2, 2018 at 3:51 PM
    1999cutiger
    1999cutiger Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    I’ve got the exact same squeaking sounds on my 2017 CM. Can easily hear on moderately rough roads....and also when closing the doors. Definitely coming from the engine area.
    If someone could post some pics of what to lubricate I would greatly appreciate it.
  14. Aug 2, 2018 at 4:18 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    MotoTundra likes this.
  15. Aug 2, 2018 at 4:54 PM
    1999cutiger
  16. Aug 2, 2018 at 6:48 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I have no idea what your sound is, but I had a squeak/rattle in the front of my truck that I would describe like yours. It turned out to be the the front bumper rebar. The bolts were not tight enough. Its a long shot, but easy enough to give the bolts a check.
  17. Aug 5, 2018 at 1:02 PM
    Zeb8806
    Where can I host video, it won’t let me attach the file. I think it’s coming from the front right but it has me thourghoughly pissed off. If I can’t get rid of this squeak soon I’m going to trade it in:mad::mad::mad:. It is time to replace brake pads but I’ve never experienced a squeak like this from brakes!?
  18. Aug 5, 2018 at 2:04 PM
    Zeb8806
  19. Aug 6, 2018 at 1:59 PM
    Zeb8806
  20. Aug 6, 2018 at 2:00 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Squeak
  21. Aug 6, 2018 at 2:04 PM
    15whtrd
    15whtrd Mr. Blonde
    :rofl::rofl:
  22. Aug 6, 2018 at 2:06 PM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Carrier bearing?
    15whtrd likes this.
  23. Aug 6, 2018 at 2:06 PM
    15whtrd
    15whtrd Mr. Blonde
    Have you looked at all the squeak threads around here? Some have a problem with the skid plate squeaking, some with the ECM squeaking and some have the AC condenser squeaking.
    14burrito likes this.
  24. Aug 6, 2018 at 2:07 PM
    15whtrd
    15whtrd Mr. Blonde
    Really hard to tell in your video. Will it squeak when sitting still and just revving the engine?
  25. Aug 6, 2018 at 2:16 PM
    Zeb8806
    No skid plate on the truck, condensor bushings are lubed well and not the culprit. Haven’t seen the ECM thread., will have to dig that one up.
    Only squeaks when moving, reving the engine has no effect.
    15whtrd likes this.
  26. Aug 6, 2018 at 2:19 PM
    15whtrd
    15whtrd Mr. Blonde
  27. Aug 6, 2018 at 2:21 PM
    Zeb8806
    Damn I should have used the forum search not google. I’m going to check my carrier bearing for play. That would make some sense as the squeak doesn’t seem to be directly related to suspension travel.
    Jerry311SD and 15whtrd like this.
  28. Aug 18, 2018 at 6:09 PM
    Zeb8806
    Updating for future searches. I got it corrected!!! I’m pretty sure it was driver side front bumper bracket, someone mentioned those and sure enough several nuts had worked their way loose. I tightened them up, and haven’t heard a squeak in 3 days. I can’t say for certain that’s what it was because I tightened all my running board bolts (lock washers were still closed but all could be torques farther) and fooled with the shocks on the same day. I’m just glad the squeak is gone.
    ChrisTRDPro likes this.
  29. Jun 26, 2019 at 1:10 PM
    Ntmid8r
    Ntmid8r New Member
    2018 Tundra TRD Sport
    TBA
    Pics of where they loosened up?
