Terminal replacement/won’t start
Discussion in '2nd Gen Tundras (2007-2013)' started by brentslide, Oct 13, 2018.
  1. Oct 13, 2018 at 5:49 PM
    brentslide
    brentslide [OP] New Member
    2008 sr5 Tundra
    I just replaced the battery terminals. I have juice but just 1 click and no go when I tried starting. Tried boosting and nothing changed. Wondering if anyone had insight?
    I’m thinking the metal terminals I’m using has something to do with not jiving with the lighter metal connectors from the cables?
  2. Oct 13, 2018 at 7:17 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    I would start by making sure all connections are on and tight. If you have an alarm with starter kill, make sure it’s not armed.
  3. Oct 14, 2018 at 5:44 AM
    brentslide
    2008 sr5 Tundra
    Thanks,
    Problem solved. I used acid and then baking soda solution to clean everything off. Connections were probably not as tight as they should’ve been.
