Temporary LBJ Fix
Discussion in '1st Gen Tundras (2000-2006)' started by itsWarrior, Oct 24, 2023.
  1. Oct 24, 2023 at 12:01 PM
    itsWarrior
    itsWarrior [OP] TEQ_Toothless
    Luke
    North Georgia
    Toothless the 06 Tundra SR5 DC RWD
    Bilstein 4600s, Leveled, LT265/70R17 A/T Tires, Lighting, Cosmetic stuff, Stickers and Morale Patches, Recovery Gear
    Hey everyone!
    I installed a 2 inch level on my 06 Double Cab yesterday in my college parking lot. When I was finished I drove my truck around the parking lot to make sure everything was working correctly. Then as I made my final turn (my wheels at full lock), I heard a loud crack that shook the steering wheel. I parked it and checked the LBJ, which I believe is the culprit, since they have never been replaced at 231k miles. I'm scared to drive it because Im afraid that the LBJ will fail but I also need it to get to work by this Thursday. I impulsively ordered Duralast LBJ at 2am as a temporary fix. Anyways, do yall think its okay to run the Duralast LBJ for a couple months until I can get OEM? Its my daily driver and I drive about 100 miles a week.
    I appreciate any input and responses.
  2. Oct 24, 2023 at 12:05 PM
    CCE525
    CCE525 New Member
    Chad
    2000 SR5
    None
    I wouldn’t be off-roading or anything but if they were that bad then they’d have had to quit making them and been sued into oblivion by now. I’m 100% in favor of OEM and you’ll be able to see and few the weight and quality difference between them but short term you should be fine.
  3. Oct 24, 2023 at 12:05 PM
    Yes. Just make sure you torque the bolts appropriately and make sure the LBJ is greased up. Some do not come with grease in them. And no wheelin your newly lifted truck till you get some solid ball joints. Replace the bolts for the LBJ as well. Might as well do both...
    Mr.bee likes this.
  4. Oct 24, 2023 at 12:32 PM
    shifty` Animals and insects don't do drugs
    Also a YES here.
    However, did you happen to install SPC upper control arms with your lift? You gave zero details about that. If yes, I had a similar *CRACK!* sound when I backed out of my driveway because I failed to torque down the top balljoint nut enough on the SPC UBJ, and it slid in the UCA's balljoint slot!
    Tundra2 likes this.
  5. Oct 24, 2023 at 1:33 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 51k mi
    Who else here was expecting OP to be asking about a literal parking lot fix, like "are these broccoli rubber bands good enough or should I go with zip ties?"
    rock climber and Nicklovin like this.
  6. Oct 24, 2023 at 1:34 PM
    itsWarrior
    Luke
    North Georgia
    @KNABORES thank you for the input. very much appreciated.
    @shifty` no sir i didnt change anything with the UCA.
    Do you guys think it could be the tie rods or anything binding?
  7. Oct 24, 2023 at 1:36 PM
    itsWarrior
    Luke
    North Georgia
    that’s hilarious! There are a lot of zip ties on this truck lmao
  8. Oct 24, 2023 at 1:40 PM
    Nicklovin
    Nicklovin Yap Yap
    Nick
    Huntington Beach, CA
    00’ 4.7 AC 4x4
    100% what I expected to read :rofl:
    Zip ties and bailing wire hahaha
    Like the others have said, you should be alright daily driving, just no wheeling really. If you have a floor Jack do yourself a favor and Jack the wheel up to check for any play in the LBJs. Fairly easy to do by trying to move the top and bottom of wheel by hand and seeing if the lbj budges.
  9. Oct 24, 2023 at 2:01 PM
    itsWarrior
    Luke
    North Georgia
    @Nicklovin Just checked lbj and no play but I’ll still pick up replacements. Just in case. lol the zipties only hold on my corner markers
    Nicklovin likes this.
  10. Oct 24, 2023 at 2:27 PM
    Nicklovin
    Nicklovin Yap Yap
    Nick
    00’ 4.7 AC 4x4
    When you do pickup some replacements try using ToyotaPartsDeal.com , might find a better price then your local dealer
  11. Oct 24, 2023 at 2:45 PM
    itsWarrior
    Luke
    North Georgia
    Alright everyone thank you so much for the input. I figured out that its my tie rod and steering rack. Its leaking and needs to be replaced. I just returned the duralast LBJ and I’ll be ordering OEM steering rack, outer tie rods, and LBJ in the next couple of weeks. Money is tight at the moment
  12. Oct 24, 2023 at 3:23 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Just curious what caused the crack? Is the tie rod end broken?
    A leaking steering rack isn't a crucial replacement, meaning if money is tight you can wait a bit on that.
  13. Oct 24, 2023 at 3:39 PM
    itsWarrior
    Luke
    North Georgia
    I believe it was from the tie rod twisting suddenly. Ive been driving for about an hour and have had no clunks or pops. It has a torn boot and has ps fluid build up everywhere.
  14. Oct 24, 2023 at 5:08 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    They make seal kits for the PS rack. There’s an episode of All Girls Garage where they rebuil one
  15. Oct 24, 2023 at 7:16 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Did you get longer sway bar links for the lift? I didn't at first and that was the source of a loud pop sound after I leveled my truck. Bent one link in a couple thousand miles.
