Temp sensor testing?
Discussion in '1st Gen Tundras (2000-2006)' started by wiggilez, Apr 9, 2021.
  1. Apr 9, 2021 at 4:46 PM
    wiggilez
    wiggilez [OP] New Member
    2004 access cab 4x4 tundra
    Topper, 1.2-2" lift, older motorola radio
    Is there way to test the temp sensor? the needle in the cab is always in the middle from start up till I shut it off.
  2. Apr 9, 2021 at 4:58 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Does it go right to the middle as soon as you turn the truck on when it’s cold? I usually have to drive for 5 miles before it comes up to temp (in the middle) like yourself.
  3. Apr 9, 2021 at 5:46 PM
    wiggilez
    pretty much as soon as its running the gauge goes straight to the center point.
    edit: it does it even in the winter when it's -15c out.
  4. Apr 10, 2021 at 9:15 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I would not discount the temp gauge sensor which supplies temp gauge reading on cluster. If AC and DC are same, my DC has the temp gauge sensor at same location as temp sensor. It will have one lead to it sending back to gauge. Mine is located on the passenger side front of engine next to temp sensor somewhat under the black cover that says V8 4.7. I would suggest troubleshooting that item also.
    Jack McCarthy likes this.
  5. Apr 10, 2021 at 6:38 PM
    wiggilez
    I'm kinda hoping that its the temp sensor, but I'm trying to figure out if there is a way to test if the sensor to see if that is my issue or if its something more involved.
  6. Apr 10, 2021 at 7:41 PM
    Jack McCarthy
    Bill
    North of Boston
    If it’s anything like most temp sensors I’m familiar with then it’s just a variable resistance under temperature. It should be specified in the repair manual. If that’s the case, you could probably test that it reacts to temp with a simple heat gun or hair dryer and use a multimeter to measure the resistance.
    JohnLakeman likes this.
  7. Apr 10, 2021 at 10:17 PM
    wiggilez
    good enough, guess I'll spend a few hours playing with it tormmorw :)
    Jack McCarthy[QUOTED] and MS22 like this.
  8. Apr 11, 2021 at 4:41 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    "you can't always get what you want"
    Mick Jagger
    Understand fully but the reason I personally would be looking at the temp gauge circuitry(temp gauge, wire to cluster gauge and Instrument cluster itself) is because that's how we see our idiot reading. In your case the temp gauge reading is abnormal.
    The coolant temp sensor talks to the ECU.
    Question just in case we are clear. The moment you start vehicle, the gauge shows 1/2 way ?
    If you turn key to IGN ON only, does the cluster gauge show a 1/2 way reading ?
    If you unplug the temp gauge sensor and put a gnd to that conductor, does your needle go full scale ?
  9. Apr 11, 2021 at 10:56 AM
    wiggilez
    That I have not tried yet. and yes. after i start the truck a couple seconds later it rises to the center then never moves even on hot days pulling a trailer.
  10. Apr 11, 2021 at 12:11 PM
    peanut
    peanut making uneconomical choices about my truck
    2001 Tundra 4x4 V8 Access cab 222k miles
    Check the ECTS fuse in the fuse box under the hood.
  11. Apr 13, 2021 at 7:23 AM
    jggeere
    jggeere New Member
    jared
    2002 toyota tundra 4.7 4x4
    I have the same issue. I start the truck when it’s cold and it immediately goes to the middle. Replaced the engine coolant temp sensor but that didn’t work. Did you resolve the issue?
  12. Apr 13, 2021 at 7:28 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    You sure about that acronym ?
    “electronic control throttle system”....curious your thinking behind that suggestion ?
  13. Apr 13, 2021 at 7:40 AM
    peanut
    Oh hahaha my dumb ass thought it was "engine coolant temperature sensor" :playball:
    BubbaW[QUOTED] likes this.
  14. Apr 13, 2021 at 7:44 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    U may not be a dumdass after all....some do refer to it as that....just curious !
  15. Apr 13, 2021 at 2:56 PM
    wiggilez
    I haven't had time to poke around yet. I'm hoping things while quiet down in a week or 3.
    jggeere[QUOTED] likes this.
  16. Feb 7, 2022 at 5:37 AM
    Celifis72
    Celifis72 New Member
    02 Tundra /93 Sc400
    Any results on this? I just bought a 02 tundra and as soon as I start it, temp jumps to center. Very odd!!
  17. Feb 7, 2022 at 10:00 AM
    shifty` I'm having daydreams about night things
    Sounds like your sensor is shorted. Temp sensors are often just a simple device that increases output signal based on a stimulus, output is often resistance. If it shorts out, it's not uncommon across any make/model to output a constant, whether that's constant zero, constant off-the-charts, or constant middle. Sometimes where it shorts can depend on the type of sensor it is. OEM replacement sensor is cheap enough, and not too touch to replace.
    Celifis72[QUOTED] likes this.
  18. Feb 7, 2022 at 8:16 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Just make sure you are messing with the proper 1 wire sensor. Two sensors on these trucks (and most toyotas from this era) one for ECU and one for gauge. Don't cheap out on this sensor. Get a good brand or even better OEM. I put a cheap one in my 96 Camry (same sensor) years ago and the temp gauge will pretty much be at H even when it's at a normal temp.
  19. Feb 8, 2022 at 4:42 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    dinosaur and shifty` like this.
