telescoping wheel/ wiper fluid tubing
Discussion in 'General Tundra Discussion' started by seanyL, May 20, 2024.
  1. May 20, 2024 at 6:07 AM
    seanyL
    seanyL [OP] New Member
    2014 toyota tundra platinum
    Hi all,
    2 how to questions.
    1.my washer fluid tubing had a tear in one of them, will that prevent any fluid from flowing from the reservoir? When I pulled back on the washer switch on the wiper arm I could hear the motor but nothing was coming out, leaking or anything so was thinking it might be something other than the hose?
    2.my telescoping, tilt wheel under the wheel does not work anymore, would this be a fuse or something more ?
    thanks all
    2mchfun likes this.
  2. May 22, 2024 at 12:58 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    why worry about either? take it to the dealer and have them fix the issues under warranty
  3. May 22, 2024 at 7:07 AM
    seanyL
    warranty? It's a 2014, the warranty has long expired my friend
    2mchfun likes this.
  4. May 22, 2024 at 8:18 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    Lol! Call it old age, I saw the 14 and automatically thought 24. I've got 24 on the brain.
  5. May 22, 2024 at 8:25 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    The washer pump thing is an elimination process. If tank has water, and pump is working, run it and find where fluid is leaking. I’ve had to replace the “T” where it splits to both sides on my wife’s Camry and my tundra. Drip irrigation t is like $0.45 and is same size. Sometimes the hose routing is a pain though.
    For telescoping steering wheel I’m at a loss, mine tilts but doesn’t telescope and it’s manually activated with a lever under steering column.
  6. May 22, 2024 at 8:31 AM
    2mchfun
    Clean the fluid nozzles with a needle, take the hose off the tank and try to blow through it. Does fluid exit tank with hose removed?
    Sometimes constant telescoping causes the wire to pull apart and break over time. Check wire conditions at flex point. Check fuses.
  7. May 22, 2024 at 8:32 AM
    2mchfun
    BTW, welcome from OKC!
    seanyL[OP] likes this.
  8. May 22, 2024 at 8:33 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    Can you hear the pump working at all when turned on? I've had pumps go bad before. Pretty easy fix if the pump is bad. As for the telescoping wheel, could be a fuse, more than likely on a shared circuit. Probably be easiest to start pulling and inspecting one by one.
  9. May 22, 2024 at 8:34 AM
    seanyL
    thanks all, appreciate it
    2mchfun likes this.
