Teeter Inversion
Discussion in 'Off-Topic Discussion' started by Trooper2, Oct 16, 2019.
  1. Oct 16, 2019 at 7:36 PM
    Trooper2
    Trooper2 [OP] Premium Lone Star Member / SSEM #13
    JR
    Houston, TX (Suburban South)
    Considering getting an inversion table, hearing Teeter are good choice.
    Middle age and poor posture over the years seem to be giving me lots of back and neck discomfort. Hoping some decompression with something like the Teeter may help out.
    Any Doctors or Health care guys have any input?
    Or anyone use something like this with good results?
    A few on C.L. like this:
    15whtrd likes this.
  2. Oct 16, 2019 at 7:44 PM
    plinyyounger
    plinyyounger New Member
    Ken
    Idaho
    2025 Tundra limited
    3-2 lift, KO3’s, Fuel wheels, tint.
    I have a teeter and have been using it for about 4 years. I only use it occasionally though. I have lower back issues and it can help with that depending on what you have going on. Inversion tables work best for lower mid back issues, not so much for neck and upper back, you just can’t get the same tension on those areas like you can for the lower back. I am glad I have it, it’s not a fix it all for me, but it has definitely relieved some pain in the past.
    Trooper2[OP] likes this.
  3. Oct 16, 2019 at 7:45 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I have one, it mostly holds clothes but when I need it, it helps.
  4. Oct 16, 2019 at 9:15 PM
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
    We have one as well, it helps when lower back hurts, but not a ton. My PT actually said it's great for short-term pain management, but don't expect any long-term fix by using it. Started doing dry-needling and it has worked wonders.
  5. Oct 16, 2019 at 9:25 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    It works for my lower back. I was taking 800mg of ibuprofen a day for almost a year before I got my Teeter. Now I rarely take anything for my back.
    15whtrd, Trooper2[OP] and YardBird like this.
  6. Oct 17, 2019 at 3:30 AM
    georgie
    georgie New Member
    I bought one around 15 20 years now. Love it use it every day. My in house chiropractor !!!! My back now at 61 is better than at 40. It has other health benefits also.
    15whtrd and Trooper2[OP] like this.
  7. Oct 17, 2019 at 4:19 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    These are great - but absolutely a temporary fix. You should be in regular PT and diligent with exercises and stretching if not already doing so.
    (this message brought to you by someone who has worked in the sports medicine field for 25 years and has a history of 14 epidural injections, a microdiscectomy, a lumbar fusion......with pending multi level fusion in the next 12-18 months).
  8. Oct 17, 2019 at 4:39 AM
    PJR202
    PJR202 New Member
    Without knowing your situation fully, I can tell you that most back pain is muscle related. Go to PT or get yourself a nightly routine of stretching and strengthening movements. Getting those back muscles strong and firing properly will take care of pain and protect your spine from incidents down the road, such as picking up a piece of paper and herniating a disc.
    The simplest answer is to start doing yoga. There are episodes you can stream on Amazon or Netflix. I like the yoga body series with Julia Marie. You can pretty much just pick whatever episode you feel like on a given da . There are core elements in each one, such as downward dog. I yoga before pretty much any physical activity now and I don't get sore the way I used to. Plus my flexibility and core strength has improved significantly. 200lbs, 40 years old and I can do a halfway decent back bridge. Ten years ago I couldnt trim the grass without spending the rest of the evening flat on my back in misery. Only one person other than my wife has taken my yoga advice, and it basically gave that guy back his ability to run. People like to complain but they usually arent willing to do anything about it.
  9. Oct 17, 2019 at 4:45 AM
    georgie
    georgie New Member
    In my case it is not a temperary fix. Fyi I go on it 3 times a day morning afrter working ou t befor bed only take 2 mins to work sometime I can hear my lower back go back in other times I can't. Big bonus takes pressure of my knee and hips that gravity pushes down on our bodies all day long. One last thing when laying sown flat like in bed there is 25% pressure still in the verts in our backs. totally up side down 0% from up to down pressure. I sound like informerical sorry just works for me !! Some don't get the same results of course. I got my ortho ok to try this. So get an expert advise that knows what issues you have !!!!!!!! Before you go totally invert.
    Trooper2[OP] and 15whtrd like this.
  10. Oct 17, 2019 at 5:30 AM
    Trooper2
    JR
    Thanks for the info guys.
    A little history: A few years back I had some numbness in my left hand and serious discomfort in the upper left arm. No MRI, but GP and PT treated for pinch nerve in lower neck, posture related. Muscle relaxers, Better posture, some stretches, and exercises alleviated the issues. 7-8 years later, I am experiencing some discomfort in the left arm again and discomfort in upper back / neck. I believe ergonomics and posture are the issue. Trying to correct both. I am doing many of the stretches and exercises that I did back then. One thing that seemed to help a lot at PT was a "Traction" (maybe calling it wrong) device, while lying down grabbed my head & pushed from my shoulders to decompress the upper vertebra for ten minutes at the end of each session. I would fall asleep sometimes; it was really relaxing. I was hoping the inversion thing may accomplish similar results. I have always heard / thought that decompressing the vertebra is therapeutic and helps with back issues.
  11. Oct 17, 2019 at 6:06 AM
    georgie
    georgie New Member
    Inversion is traction just more intense ! Helps my neck too. move my head around I can hear verts moving going to there natural place.
  12. Oct 17, 2019 at 12:31 PM
    shawn474
    MoCo, Maryland
    Again, not saying not to do the inversion table, but it IS a temporary fix. Don’t assume these issues are the same as 7-8 years ago. You owe it to yourself to get a full work up and consult to determine the cause and treatment protocol. The inversion table certainly can help supplement that course of treatment and will not hurt progress. If you want to chat off lone PM me and we can exchange information.
    Trooper2[QUOTED][OP] likes this.
  13. Oct 17, 2019 at 12:35 PM
    shawn474
    MoCo, Maryland
    My statement of this being temporary refers the the fact that the effects of an inversion table do not last. The hope is that an inversion table or traction is supplemental to addressing an actual fix to the issue - long term strengthening, stretching and other ways to actively decompress the nerve irritation. The traction / inversion is a passive addressing of the situation. An epidural may be beneficial in decreasing the swelling and irritation to get you to a point where you can effectively rehab. But certainly USE an inversion table.
  14. Oct 17, 2019 at 12:38 PM
    Grumpy Uncle
    Pat
    CO
    I've got 2 of them, 1 for home use and the other one is at my deployed location. There will be a 3rd one at our new site. My company is really good about taking care of its veterans.
  15. Oct 17, 2019 at 12:38 PM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    My Lower back is messed up.
    I use my table 3-4 times a month and Take CBD oil and it has helped me. Its not a fix but it helps me a bunch
    Dont go buy one, I see them all the time on craigslist, I got mine for free
  16. Oct 17, 2019 at 12:41 PM
    Grumpy Uncle
    Pat
    CO
    Keeping your core strong is very important when you have back problems.
    I use my inversion table frequently, core excercises and Meloxicam for pain management.
  17. Oct 17, 2019 at 10:59 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I’ve been thinking about getting one. I have responded very well with the traction machine my PT has me on. He says an inversion table can help just like the traction.
    I’ve got 2 herniated discs in my lower back (L4-L5 and L5-S1) and have been down for 6 months now. I’ve had 3 epidural injections and 1-2 visits to my PT every week since my injury.
    It’s been very frustrating but I’ve made a ton of progress in the last 2 months since my 3rd shot.
    Integra Physical Therapy in Pflugerville, Texas is awesome. Great people and the PT Isiah Martinez is awesome at what he does and is very passionate about his work.
    I agree getting checked out again would be a good thing. I had a similar back injury 3 years ago so this time I started the exercises again before getting checked out. Definitely wasn’t a good idea.
  18. Oct 19, 2019 at 6:14 AM
    e30cabrio
    I just used mine. I hurt my back lugging my 60lb spring compressor inside Thursday.
    The back feels 100% better. I also put the clothes that were on it away.
    lol
