Techstream cost ?
Discussion in 'General Tundra Discussion' started by Scpringle, Nov 11, 2018.
  1. Nov 11, 2018 at 12:53 PM
    Scpringle
    Scpringle [OP] New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    girlfriend just got a 2015 Lexus GX 460 and was thinking Techstream would be good for both trucks . the GX you have to reset the the tire pressure via the dealer ( complete BS)
  2. Nov 11, 2018 at 2:35 PM
    tacomawv
    tacomawv New Member
    Richard
    My wife has the same car. She has had a flat tire. The light went off when I had the tire repaired. I did not have to reset anything. Are you sure the spare is not low. I have a SR double cab like you.
    Scpringle[OP] likes this.
  3. Nov 11, 2018 at 3:56 PM
    Scpringle
    Jackson MS
    @tacomawv thanks I aired up all 4 not the spare , will do that this week . I have been reading on CLub Lexus that if the TPMS light is blinking that it's the sensor . Her GX blinks then stay on .
  4. Nov 11, 2018 at 4:33 PM
  5. Nov 11, 2018 at 4:40 PM
    tacomawv
    tacomawv New Member
    Richard
    Stayed on. We were coming back home on a trip.
    831Tun likes this.
  6. Nov 11, 2018 at 4:57 PM
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    markiemark9, Jdi and Scpringle[OP] like this.
  7. Nov 11, 2018 at 5:00 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
  8. Nov 11, 2018 at 5:01 PM
    Yep, and that’s pretty cheap as well. I think a couple buddies of mine had 40.00 into their setups.
  9. Nov 11, 2018 at 5:03 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Ya, still not braking the bank ethier way.
  10. Nov 11, 2018 at 5:04 PM
    Not for a baller like yourself. ;):thumbsup:
    Thegr8punkin[QUOTED] likes this.
  11. Nov 11, 2018 at 5:47 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    "Baller" lol hell most of my 60% of my cars don't even use obd2...
  12. Nov 11, 2018 at 6:14 PM
    That’s not necessarily a bad thing...
  13. Nov 11, 2018 at 6:41 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    True, don't have to reprogram the computer when you loose all your keys...
  14. Nov 11, 2018 at 6:42 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    what all can you do with tech stream? can you get a key programmed?
    Thegr8punkin likes this.
  15. Nov 11, 2018 at 8:39 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
  16. Nov 12, 2018 at 5:15 AM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    It works for most windows. Not sure about If mac's os is supposed
    And my bad, but if you click the "size" button select Toyota
    gdiep[QUOTED] likes this.
  17. Nov 12, 2018 at 6:51 AM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Yes, you can program a key, reprogram new tmps sensors, turn off your seatbelt chime, read all codes, view live data, and a ton of other stuff.
    It also does generic obd2 code reading
    TRD-tv[QUOTED] likes this.
  18. Nov 12, 2018 at 9:14 AM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    is it rather straight forward or do i need to go to a vocational school to play with it lol
  19. Nov 12, 2018 at 10:11 AM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    It's very user friendly.
    But if you're having issues with it, it's very easy to get YouTube certified.
  20. Nov 12, 2018 at 10:24 AM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    thats where i learned everything i know. thanks so much for the info. ive looked on ebay, ive seen em from $10 -$200 which one is a reliable one? i need a cable and the program correct?
  21. Nov 12, 2018 at 10:30 AM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    I spent 22 on mine... bought the cable and downloaded the program for free from the link I posted earlier.
  22. Nov 12, 2018 at 12:15 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Ya it it blinks after the car is turned on then stays solid it's a sensor not communicating with the computer. Wether it's missing, dead, or misprogramed.
    But there are some pita things that you have to do to replace those... you have to pop the tire off the bead to replace it
  23. Nov 12, 2018 at 2:06 PM
    gdiep
    Syracuse, New York
    Thanks. I’m going to give it a shot. I only want to be able to program my tpms on winter change overs. I’ll probably pm you if I have an issue downloading the software. I’m not very tech savvy. Lol.
  24. Nov 12, 2018 at 3:45 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Your all good. And make sure you write down the codes of the sensors somewhere. Because you have to retype in the sensors to reprogram them
    NewImprovedRon likes this.
  25. Oct 17, 2024 at 4:11 AM
    537CementGrey
    537CementGrey New Member
    2017 Tundra CrewMax TRD Pro
    285/75R18 Duratracs
    Does anybody have an updated link for this software? The one provided by Thegr8punkin no longer works. My 17Pro needs me to hook up lol.
  26. Oct 21, 2024 at 5:46 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I think you can buy a disc and OBD cable on Amazon inexpensively though this never worked for me. Might've been my OS though.
