Tech stream Gurus
Discussion in 'General Tundra Discussion' started by BlueBottle, Aug 26, 2017.
  1. Aug 26, 2017 at 8:57 AM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    Hey Techstream Guru's out there! @PMG and anyone else out there.
    I need to purchase the cable and software. I see a lot on eBay but not sure which one I need and which one works? Anyone can help out?
    Also will it work on my Windows 10 Laptop?
  2. Aug 26, 2017 at 9:26 AM
    PMG
    PMG New Member
    I don't think the cable matters much. I didn't use the drivers in the CD either... The drivers were included in the techstream file (drop box link should be in that thread) attached is the cable I got and works great. Not sure about windows 10 personally, but I do remember other members on TT having no issues when using the same techstream file..
    BlueBottle[OP] likes this.
  3. Aug 26, 2017 at 9:38 AM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
  4. Aug 26, 2017 at 9:43 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks just need to locate that file now...
    Thanks.. I like prime, easy. Did you use the same software PMG was talking about?
  5. Aug 26, 2017 at 10:07 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Just borrow mine!
    dcsleeper408 likes this.
  6. Aug 26, 2017 at 11:00 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Ahhhh now I have to go see you .... I'll buy your girls some ice cream this time!
    joonbug[QUOTED] likes this.
  7. Aug 26, 2017 at 11:02 AM
    PMG
    PMG New Member
  8. Aug 26, 2017 at 12:13 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
  9. Aug 30, 2017 at 8:40 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Does anyone have the Readme file that PMG shared from dropbox? The dropbox link is dead.
  10. Aug 30, 2017 at 8:46 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    I'm gonna see @joonbug this weekend mike I can grab his cable if u want and meet u at work Monday? I'm gonna take his radio to so I can program the channels we use in there.
  11. Aug 30, 2017 at 9:12 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks but I bought my own cable. Just need the software to work now. I'm sure pmg has the readme file I need.
  12. Aug 30, 2017 at 11:09 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    What are you doing with my radio? o_O
  13. Aug 30, 2017 at 11:10 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    or you can always just download from my disc if you can't find one.
  14. Aug 30, 2017 at 11:17 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    cool make sure you have it ready when you do my frac. and get your suspension ready! Mod day!! i'll bring some beer.
  15. Aug 30, 2017 at 11:19 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    do my fracking frac too.
    dcsleeper408[QUOTED] likes this.
  16. Aug 30, 2017 at 11:21 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    @joonbug program channels in there so you dont have to always put in frequencies. u can use mine for the mean time while i do yours.
    joonbug likes this.
  17. Aug 30, 2017 at 11:22 AM
    JMB
    Chesapeake, VA
    I don't remember what version of techstream I used. What I found was that I had to manually install the drivers for both the cable and techstream to make it work. I lifted this from the other forum.
    Quote:
    Originally Posted by charlier viewpost_3cc633680b4a016175403bd48306ebae1ed1e567.gif
    I think you misunderstood my post. The drivers for the cable were already on my laptop BEFORE I installed the cable and software the very first time. The first time I deleted the drivers from my PC, the PC automatically went to the Microsoft servers and downloaded the most current drivers again which basically screwed me because the cable will not work with those newer drivers.
    After I realized those drivers from Microsoft were not the same as the drivers that came with the software I knew I had to disconnect my laptop from the internet so Windows XP and/or WIN 7 could not automatically go to the Microsoft web site and download the newer drivers. Then I manually "selected" the drivers that came with the TechStream software and installed those drivers on both my Win XP and Win 7 pro laptops.
    Short answer to your question is DO NOT reinstall Windows 7 on your computer that is overkill. Disconnect you PC from the internet, delete just the driver(s) that TechStream needs that are currently on your computer, then manually tell Windows 7 where to find the drivers that came with your TechStream software and load those drivers. You do not need to reload Windows 7 and you do not need the Windows 7 install disk.
    ME: This is the best post here! After spending hours installing, uninstalling, changing versions I spent time reading every page here and found this. After downloading all the soft ware, disconnect from the internet and perform the installation. Once I did that I was up and running in about 15 minutes.
  18. Aug 30, 2017 at 11:26 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    into my baofeng or my truck?
  19. Aug 30, 2017 at 3:59 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Sure. I charge $100
    I already have the software installed.. Issue is its asking for a key. that key is in that readme file. The drivers are already loaded.
  20. Aug 30, 2017 at 7:22 PM
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
  21. Aug 30, 2017 at 9:23 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    thanks!!!
  22. Aug 30, 2017 at 9:35 PM
    JMB
    Chesapeake, VA
    I already have the software installed.. Issue is its asking for a key. that key is in that readme file. The drivers are already loaded.[/QUOTE]
    Yeah I understand that. I am the furthest thing from a computer guy. What I know is that I deleted everything that I had previously installed, got the install files and disconnected the internet. Then I manually installed techstream, plugged the cable in and used whatever drivers were local on my (wife's) laptop, I guess from the cable. I'm not sure if it asked for a key, but if it did I just skipped it. Worked then, and still works now, even after updating to Windows 10. A lot of other things suck, but not the cable or techsteam.
  23. Aug 30, 2017 at 10:18 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    So I did all the steps on that text file. I uninstalled everything I had first. Software runs now but when I try to connect to my vehicle it shows this. It installed the driver for the cable properly.
  24. Aug 30, 2017 at 10:19 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
  25. Aug 31, 2017 at 2:06 PM
    Skippy
    San Antonio US of A
    2016 Tundra 1794
    Sorry @BlueBottle, and wish I could help, but it would be the blind leading the blind. I thought it might be due to a diff version number, but it's not. I can upload the Techstream rar file came with the read me if you think it would help.
  26. Nov 22, 2017 at 4:55 PM
    tinyt1553
    tinyt1553 New Member
    Tom
    Cypress, TX
    2017 1794 CM - Magnetic Gray
    Exterior: POP & Lock Power Tailgate lock BakFlip MX4 Tonneau Cover Rhino Bed Liner Swapped OEM Halogen Fogs with Formula-J87 LED 6000k bulbs Rough Country 60" Tailgate LED lightbar 6" rubber stub antenna Interior: Front Emblem Camera with anytime backup cam, Crux Vimty-05 for Vehicle in Motion Override Center console wireless charging Verizon Hotspot in center console Chromecast to OEM head-unit display ESP Rear Seat 3 Compartment Storage 5% Ceramic tint on rear window and rear doors 18% Ceramic tint on front doors Weathertech rear seat cover (try to take Hank (boxer/pointer mix) with me everywhere I can) In The Works: Upgrade to 2018 OEM LED Headlights VLEDs throughout the rear (turns, brakes, highmount 3rd brake and cargo) GRT Lighting LED's to replace all interior bulbs Future Wishlist: Swap OEM Head-unit with Kenwood DNX994S and use iDataLink Maestro RR to integrate OEM backup cam, OEM USBs, OEM Aux input, etc AMP-Research Power Sidesteps Train (air) horn
    Go to the setup menu at the top of the software, click VIM select, select xhorse - mvci from the drop down, I had the same issue
  27. Nov 22, 2017 at 7:21 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I don't have that option when I go there =/
  28. Nov 24, 2017 at 5:51 PM
    tinyt1553
    Tom
    Cypress, TX
  29. Nov 24, 2017 at 5:54 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I did. That is the only option. =(
  30. Nov 24, 2017 at 5:59 PM
    tinyt1553
    Tom
    Cypress, TX
    responding via private message
