TBA straight back assist help
Discussion in '3rd Gen Tundras (2022+)' started by BigTrout, May 8, 2024.
  1. May 8, 2024 at 5:29 PM
    BigTrout
    BigTrout [OP] New Member
    2024 Tundra Platinum TRD Off Road
    I did not find what I was looking for after searching the forms and all the online videos are explaining setting up.
    Here is what I’m need help with:
    I successfully set up a utility and boat trailer. Put it in reverse and “Straight back assist” showed on the reverse camera screen. Worked great! Now, I drive home and “straight back assist” no longer shows on reverse screen. I press the trailer button and screen wants to start a set up again.
    Next time I hooked up my trailer, I am informed “trailer is detected” I make sure the correct trailer is selected and still “Straight back assist” button does not appear when I switch to reverse.
    Once you have performed a successful trailer set up and is saved and selected, do you get the straight back button to appear on the camera/reverse screen? What am I not getting here?
    Question #2
    After learning my boat trailer, I was using the straight back assist and “BRAKE” flash and my truck slammed on the brakes. I did find the “beep” silence button which is annoying that it beep every time reversing with a trailer. I would think that stuff would be off when a trailer is detected.
    any help is appreciated. Step by step for dummies?
  2. May 8, 2024 at 5:32 PM
    dklehman
    dklehman New Member
    Darin
    2024 sr5 Tundra
    Does your boat trailer have a 7 pin switch?
  3. May 8, 2024 at 5:34 PM
    BigTrout
    Both my trailers use the 7 pin plug. Has only surge brakes on boat trailer. Utility trailer has no brakes
  4. May 8, 2024 at 5:43 PM
    dklehman
    dklehman New Member
    Darin
    2024 sr5 Tundra
    So I know my truck does not recognize my 4 pin and will still apply the emergency braking but i have no issues with my 7 pin.
  5. May 8, 2024 at 6:02 PM
    BigTrout
    I found some information elsewhere that others have found that the system is not saving properly. The dealer is working to find a solution. Not super excited about that. His description of problem is identical to mine.
