Taller tire
Discussion in '1st Gen Tundras (2000-2006)' started by Dpy, Mar 23, 2019.
  1. Mar 23, 2019 at 6:32 PM
    Dpy
    Dpy [OP] New Member
    Maybe a crazy idea but was thinking of ways to improve ride and had an idea that if I were to put a taller tire on truck I might improve ride a little bit . My tires are 265/65/ 17 yokohama's , I found some Michelin 245/75/17 for ninety something dollars . I already know Michelin has a good smooth ride and this size would increase the total height by around an inch and the sidewall by 1/2 inch which would be a bit more cushion and a tid bit less width. Need tires so might try this.
  2. Mar 23, 2019 at 8:24 PM
    Those are some small tires for our size trucks.
    because_wumbo-truck likes this.
  3. Mar 23, 2019 at 9:24 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    I believe he’s talking about a first gen:) and yes that size would look a little strange on a current tundra:rofl:
    because_wumbo-truck and OR18TRD like this.
  4. Mar 23, 2019 at 9:26 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Is your truck stock or leveled?
  5. Mar 24, 2019 at 4:08 AM
    Dpy
    Dpy [OP] New Member
    Stock, btw it is a 2006 double cab and the 265's are the size that are suggested on door label .
    Black Wolf likes this.
  6. Mar 24, 2019 at 6:15 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    That would take you from a 30.6 to a 31.5 inch tall. Also you'd go from 10.4 wide to 9.7 wide. I dont think it would hurt anything. Do it and get before/after pics and update on results.
  7. Mar 24, 2019 at 6:22 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    You should be fine running that size. I would do a quick google image search and at least get an idea of how that size of tire would look on your 06 double cab.
  8. Mar 24, 2019 at 6:39 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    You'll be fine, maybe a little rubbing at full lock.
    Mine had 265/70/17 which are about the same height but wider on it when I bought it with no lift.
  9. Mar 24, 2019 at 6:40 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Why not just go a true +1 with a 265/70/17?
    revtune likes this.
  10. Mar 24, 2019 at 7:22 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
  11. Mar 24, 2019 at 9:02 AM
    Dpy
    Dpy [OP] New Member
    Thanks for all input , am still deciding on exact size , the size I mentioned was a marked down tire usually priced at $150 a pop and I can get for around $ 90.
  12. Mar 24, 2019 at 9:18 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    At $90/tire for Michelins I'd run them. Only large diffference between them and the 265/70 is the 1" width which isn't a deal breaker IMO.
    lsaami likes this.
  13. Mar 24, 2019 at 9:21 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I'd go for it , especially Michelins at that price
  14. Mar 24, 2019 at 5:57 PM
    Dpy
    Dpy [OP] New Member
    I have ordered tires once on web from coker they were wide white walls for a 40 ford coupe I was building . Was kinda hard to get someone to mount them because I didnt buy from anyone locally and when I found someone to do it some jerk working at the tire shop got grease all over the white wall and it never came out, probably had some resentment .guess I can find someone or go to harbor freight and buy one of those manual tire mounting tools.
  15. Mar 24, 2019 at 6:15 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    If you have a Walmart with the TLE still they'll do them no questions.
    Aerindel likes this.
  16. Mar 24, 2019 at 6:19 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    you could go that route, but will probably end being a pain in the ass doing it like that.
  17. Mar 25, 2019 at 4:51 AM
    Dpy
    Dpy [OP] New Member
    Nah , dont really want the tire changer went back and looked and the web site list several places that apparently agree to install their tires . I have a good tire dealer here in town , great older guy where I have been buying tires for everything I have including a class A motorhome but I feel kinda bad asking him .
  18. Mar 25, 2019 at 5:14 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    I had my tires mounted by mills fleet farm. They’re a big box type store chain focused in the Midwest.
  19. Mar 25, 2019 at 9:54 AM
    Dpy
    Dpy [OP] New Member
    I looked back on the tirerack web site where I saw the tires and they give a list of local shops that has an agreement with them to mount, I called and confirmed that a shop in Lexington SC , about 18 miles away will mount them . So here goes.
    lsaami and bmf4069 like this.
  20. Mar 25, 2019 at 12:04 PM
    Dpy
    Dpy [OP] New Member
    Just placed order, $393.24 for all 4 tires .
    lsaami likes this.
  21. Mar 25, 2019 at 12:26 PM
    Casper421
    In the woods
    06 DC
    That’s the cost of 1.5 of my tires!
    TheBeast and Festerw like this.
  22. Mar 25, 2019 at 12:37 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    That's a screaming deal. If I hadn't bought tires last summer I'd pick some up.
  23. Mar 25, 2019 at 12:53 PM
    Dpy
    Dpy [OP] New Member
    Hope they are ok and not some recapped blems, just kiddin , I'm sure they are fine.
  24. Mar 25, 2019 at 1:14 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Not 100% but I think those are the "old" style LTX which are great tires. I'm assuming they're just clearing out inventory.
  25. Mar 25, 2019 at 1:40 PM
    Dpy
    Dpy [OP] New Member
    It will be interesting to see mfg date on tires.
  26. Mar 26, 2019 at 7:51 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Here they are...
    And fyi...with a $70 rebate and if you happen to live near a TireRack distribution center (I do) and can get a $40 break by picking them up, they are $277 for 4 tires...crazy...
    https://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=LTX+M/S2&partnum=475SR7LTXMS2&vehicleSearch=false&fromCompare1=yes
    revtune likes this.
  27. Mar 26, 2019 at 8:01 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    those are the tires I just took off my Tundra. Nice tires, but they've been replaced by the Defender line. I kept two of them because they were in good shape. Gonna be spares if one of my Kuhmos goes out.
  28. Mar 26, 2019 at 8:33 AM
    Dpy
    Dpy [OP] New Member
    You know, I forgot about that rebate. Btw, I sorta kinda confirmed or at least strengthened my theory of a taller narrower tire riding better. I saw an article somewhere on the web where the writer said that a taller sidewall and a narrower tread width would rice better because of a little more cushion ( more distance from road to rim) and less area contacting road because of narrower treadwidth ( actual contact to road. Adding to all of this that fact that these are Michelin tires that are rated strongly in the ride category, I hope to feel a difference . Funny thing is all my life I never really thought about the ride in a truck , I,ve drove everything , 18 wheeler ( Had CDL ) 40 ft diesel pusher class A motorhome, dump trucks, hot rods ......but as I get older I have changed my thoughts on this.
  29. Mar 26, 2019 at 9:30 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Tire rack has a reputation to uphold, you shouldn’t have any problems, unless the tires were manufactured in 2009 and they’ve been storing them in the Nevada desert:D
  30. Mar 26, 2019 at 10:44 AM
    Dpy
    Dpy [OP] New Member
    got tires already, date made code 2218 , so made 22nd week 2018.
