Taking it to the dealer
Discussion in '2.5 Gen Tundras (2014-2021)' started by Corrosivetendency, Dec 17, 2020.
  1. Dec 17, 2020 at 11:29 AM
    Corrosivetendency
    Corrosivetendency [OP] New Member
    Nate
    2016 plain-jane d-cab
    Today, of all days, the truck will no longer go into 4lo. 2016 D-cab 4.6.
    It went it this morning to pack the 12 inches of snow down in my spot, and once more to break trail up a forest road. But after getting back down, it would not disengage from 4lo. Grinding gears, beeping. Finally got it to disengage. Read a bunch of threads, seems an actuator problem. I am still under power train warranty. Wish me luck.
    NewImprovedRon likes this.
  2. Dec 17, 2020 at 11:31 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Best of luck. Not fun. Hope you get this resolved.
  3. Dec 17, 2020 at 12:49 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Good luck! Interested to see the outcome - low/old fluids?
    Corrosivetendency[OP] likes this.
  4. Dec 17, 2020 at 2:11 PM
    Corrosivetendency
    Nate
    I have only have the truck for about 2 months and not changed it myself yet. 77k miles and original fluid maybe?
  5. Dec 18, 2020 at 1:06 PM
    Corrosivetendency
    Nate
    The service advisor and technician had me watch them engage and disengage the transfer case to educate me, because it was apparently not doing it correctly..... only for it to refuse to go into 4hi, the refuse to disengage, then work and get stuck in 4lo before I just stepped back. Then I was told it was from the ice he found packed under the truck...? Needless to say, they kept it.
  6. Dec 18, 2020 at 2:01 PM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
  7. Dec 18, 2020 at 3:09 PM
    Corrosivetendency
    Nate
    I was there. Read thru and thru. All good info. The dealership fellas didn't seem to like being asked about specifics like which oil and miles of use per month. If I can get new parts under warranty, I am not picking up a wrench.
    Huckwheat and tttrdpro like this.
  8. Dec 21, 2020 at 8:16 AM
    Corrosivetendency
    Nate
    Dealer confirmed it needs a transfer case actuator. Waiting on warranty approval
  9. Dec 21, 2020 at 8:36 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Did they say how it failed or got damaged?
  10. Dec 21, 2020 at 12:26 PM
    Tundrafan23
    Tundrafan23 New Member
    You were in neutral right?
  11. Dec 21, 2020 at 12:37 PM
    Corrosivetendency
    Nate
    No. Just telling me when under load, it fails and stops working. Warranty claim approved.
    Also telling me they have to pull the transfer case to repair it...?
  12. Dec 21, 2020 at 12:43 PM
    Corrosivetendency
    Nate
    Yes. If the truck isn't in neutral, it won't cycle to engage.
    My best guess is that it was used very seldom in the past 75k miles.
    I asked for the old actuator and any parts they replace so I could take a look at them, hoping they let me have them.
  13. Dec 22, 2020 at 8:08 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    I would say the old parts are going back to Toyota for inspection.
  14. Dec 22, 2020 at 8:17 AM
    Corrosivetendency
    Nate
    I kind of figured but no harm in asking.
