Tailgate removal?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Umibozu, Jun 27, 2018.
  1. Jun 27, 2018 at 3:17 PM
    Umibozu
    Umibozu [OP] New Member
    I been sniffing around and found no info on how to remove the tailgate. Was the tailgate not meant to be remove quickly?
    I ride a few motorcycle onto the ramp resting on the tailgate and no issue so far but I'll be transporting heavier bike this time so I want to remove the tailgate just be safe.
  2. Jun 27, 2018 at 3:30 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    There’s a plug that goes to your camera so unplug that then it’s just a matter of opening the tailgate and lifting it up and away (after detaching the cables on either side)
  3. Jun 27, 2018 at 3:37 PM
    Umibozu
    I saw wires going from under the truck into the bottom of the tailgate. They look well protected so I didn't mess with it.
    Guess I'll look again :) Is the plug located on the tailgate or underneath the truck?
  4. Jun 27, 2018 at 4:14 PM
    jewsNbrews likes this.
  5. Jun 27, 2018 at 4:55 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    In fact, tailgate removal is so easy and fast that there is a thriving market for stolen tailgates. Just look at c list. Replacing a late model tailgate with the camera ain’t cheap neither
  6. Jun 27, 2018 at 4:57 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yep, I lock mine after every time I use it.
  7. Jun 27, 2018 at 5:01 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I added the pop and lock, so it locks with the truck plus added a lock that goes around the removable hinge side
  8. Jun 27, 2018 at 5:06 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Gonna do both of those soon. Already have the pop and lock but need to install it. I’m sure there’s nothing to it.
    jewsNbrews and gosolo[QUOTED] like this.
  9. Jun 27, 2018 at 5:11 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    The wire colors to connect to in the cab were reversed from what they said in the instructions. Do a quick test before you commit to your final splice.
  10. Jun 27, 2018 at 5:13 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Will do, thanks for the heads up!
  11. Jun 27, 2018 at 5:13 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Takes about 45 minutes. Well worth it
  12. Jun 27, 2018 at 5:14 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Which wires did y’all tap into?
  13. Jun 27, 2018 at 5:22 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Check the YouTube video on it. They were behind passenger side kick panel in cab. I went through rubber plug in floor. Plenty of wire for it. I did reverse wires as stated above. Just swapped them at lock itself. Put some grease on it before buttoning up the tailgate panel.
    belanger9 and gosolo like this.
  14. Jun 27, 2018 at 5:23 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Cool. We installed my buddy’s AMP steps so I’m pretty familiar with the wiring behind both kick panels.
  15. Jun 28, 2018 at 9:41 AM
    rds95991
    rds95991 New Member
    2018 Super White Tundra CrewMax SR5 TRD
    Good to know about locking the tailgate.
    I found a plastic connector in my glovebox to be used when removing the tailgate to protect the camera connections.
    jewsNbrews, NewImprovedRon and ldale like this.
  16. Jun 28, 2018 at 9:51 AM
    ldale
    ldale New Member
    Txk Tx
    17' Limited Silver Sky Metalic
    Tonno Pro LowPro , TRD Sway Bar, Helwig Leaf Pack
    Yep ^^^^
  17. Jun 28, 2018 at 9:58 AM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    The Tundra tailgate is the trickiest one I've had to take off because of the damper on the driver side. Taking it back up to nearly closed is a must, it's not like other one's I've done where once the passenger side is off the driver's side slides off easy.
    ConcordCarlos and gosolo like this.
  18. Jun 28, 2018 at 10:20 AM
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    The lock for the tail gate (keep it from easily being removed) is a $2 purchase from homedepot and takes 5 minutes to install... (not sure about the size)
    you put it on the side that comes out first. the thought is crooks will not likely mess with it if they have to pull out tools - not as "easy in easy out"
    Pop lock took me about 1.5 hours total. I spent too much time routing wire under the truck...
    I always kept my tailgate locked. Which meant I'd have to grab the keys when I wanted to drop it. usually they were already in the ignition. Major point of frustration for me. $100 was well worth it!
    Wires were reversed from what the instructions say to what actually operated the actuator correctly (as gosolo said) on my 2017 SR5 CM. EDIT: It's a quick fix though, just swap the connection at the actuator Red to Black and Black to Red (or whatever colors they used)
    jewsNbrews, NewImprovedRon and gosolo like this.
  19. Jun 30, 2018 at 4:26 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    How heavy is the bike?
