Tailgate part# help
Discussion in '2nd Gen Tundras (2007-2013)' started by tuna813, Mar 4, 2021.
  1. Mar 4, 2021 at 11:17 AM
    tuna813
    tuna813 [OP] New Member
    Tuna!
    13' RCSB
    I'd like to fix this myself, the dealership wants over $250, not happening. Looks as simple as removing the screw that's leftover, maybe replacing the strip, and putting the screws back in it. Any suggestions on this? I'm sure I'm not the only one who ran into this before.
  2. Mar 4, 2021 at 12:25 PM
    XSPman
    XSPman New Member
    Manny
    ON, Canada
    2007 XSP DC 4WD
    front levelling, 34" tires, billet grill, tonneau, Nova
    Here's what I find. That plastic clip(4) that holds the protector on, you just pop the centre outwards and you can remove it from the hole. Putting it back in, have the centre pulled outwards about 1/8 inch, insert into the hole, then push the centre in which flares the body of it and holds it in place. If you need new ones they are called clip and part no. is 521602020(3 bucks) . That top piece is called a protector and part no. is 657170C051(150. bucks or so U.S.). If it was me and just that one hole(or 4) is ripped a little, I would do a few turns of electric tape on the tear, and put it back on. You could also run a bead of silicone along the top of the tailgate to help hold it on(after cleaning it up good, both surfaces), so silicone sticks. If it flys off, then go get a new one.
    tuna813[OP] likes this.
  3. Mar 4, 2021 at 12:56 PM
    idiggplants
    idiggplants New Member
    PA
    2013 DC 4wd
    5100 fronts middle setting 5100 rears 3rd gen offroad wheels softopper ditch lights
    yeah, $150? screw replacing that thing. if anything id pop out the plastic rivets and when i put them back in, do so with some silicone. and if that failed, id drill holes through the top of it, and put those screws in the top of the tailgate through it, maybe with a washer or something.
  4. Mar 4, 2021 at 1:38 PM
    TheBeast The Beach
    bought a knock off replacement on ebay for $40 iirc. It will get beat up again so no need to go oem.
  5. Mar 4, 2021 at 1:39 PM
    TheBeast The Beach
  6. Mar 4, 2021 at 6:11 PM
    Slayer
    Slayer Member
    Slayer
    silicone it & call it a day
  7. Mar 5, 2021 at 7:46 AM
    tuna813
    Tuna!
    13' RCSB
    That's some good feedback, thank you guys for saving me some $!
    TheBeast likes this.
  8. Mar 8, 2021 at 9:48 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    I changed my beatup tailgate cap last year sometime. Got it off eBay. Super simple to change.
