Tailgate not locking or unlocking with remote
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundyFromDownUndy, Oct 7, 2022.
  1. Oct 7, 2022 at 6:11 PM
    TundyFromDownUndy
    TundyFromDownUndy [OP] New Member
    2020 Platinum Tundra
    Just realized today my tailgate hasn't been locking or unlocking with my remote. I have to manually lock/unlock with the key instead. Is there some sort of override switch I'm missing or something? Searched forums and found varying degrees of this, but not specifically my issue. Hope someone has a solution. For right now it's just an inconvinience
  2. Oct 7, 2022 at 6:13 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Unless you had a power tailgate lock installed, stock requires a key.
    Tripleconpanna likes this.
  3. Oct 7, 2022 at 6:14 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Unless you installed a tailgate lock then it doesn't lock with the remote. The OEM tailgate lock kit is a pretty straightforward install though, if you want ro add it.
  4. Oct 7, 2022 at 6:40 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If you did install a lock, you'll need to remove the tailgate cover panel and take a look to see if the actuator is still contacting your lock mechanism.
  5. Oct 7, 2022 at 6:52 PM
    TundyFromDownUndy
    I assumed the platinum would have it included. I guess not. Well that was an easy fix to my problem. Was gonna do a swap, but maybe manually locking isn't a bad thing. Will be secure even if my truck is unlocked. I kinda like that.
  6. Oct 7, 2022 at 6:56 PM
    Joe333x
    Joe333x Member
    Boston
    Buy the OEM kit, the instructions are very simple to follow. You do not need to remove the exhaust shield but wear gloves because its sharp and will cut you, which is why they tell you to remove it. The part number is PK3B6-34JS0.
  7. Oct 8, 2022 at 5:43 AM
    TundyFromDownUndy
