Tailgate lock
Discussion in '2.5 Gen Tundras (2014-2021)' started by kelbro, Aug 26, 2024.
  1. Aug 26, 2024 at 2:43 AM
    kelbro
    kelbro [OP] New Member
    2021 1794 CrewMax 4x4 in Wind Chill Pearl
    2̶0̶2̶2̶ ̶1̶7̶9̶4̶ ̶C̶r̶e̶w̶ ̶M̶a̶x̶ ̶4̶x̶4̶ ̶w̶i̶t̶h̶ ̶A̶d̶v̶a̶n̶c̶e̶d̶ ̶P̶a̶c̶k̶a̶g̶e̶
    2021 1794 model. Should the tailgate lock when you use the fob t lock the doors?
  2. Aug 26, 2024 at 3:03 AM
    It depends on if it has the electronic tailgate lock. It wasn't a standard feature. It was an option, so some have it and others don't.
    bulldog93 and Retired...finally like this.
  3. Aug 26, 2024 at 4:17 AM
    Retired...finally
    Yep. Port installed option. My 21 lowly SR5 has one.
    To answer your question, yes. it locks and unlocks with the fob. One slight difference: Once the tailgate is opened you still must open a door to prevent the timeout feature that relocks the doors after the timer runs out.
    BravoDeltaRomeo likes this.
  4. Aug 26, 2024 at 4:23 AM
    The answer to the question is only "yes" IF the truck is equipped. His may not have it.
  5. Aug 26, 2024 at 4:26 AM
    Retired...finally
    That's why I quoted your post. Yes, you must have that option. What's this aftermarket solution? Pop n lock or something like that? The harness must be there for it to be a port installed option.
  6. Aug 26, 2024 at 4:28 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I added this feature after I got the truck. Search this forum for ways to do it either with the OEM kit or with aftermarket parts.
  7. Aug 26, 2024 at 4:29 AM
    Retired...finally
  8. Aug 26, 2024 at 4:31 AM
    Right, I just didn't want the OP to misunderstand your answer of "yes" to think that all 1794s or 2021s should have it. Maybe it's my graveyard brain, but your post looked like it could be misinterpreted.
  9. Aug 26, 2024 at 4:34 AM
    Retired...finally
    Or maybe my graveyard brain!
    GODZILLA[QUOTED] likes this.
  10. Aug 26, 2024 at 5:03 AM
    kelbro
    Thanks. I've seen some with the option and was surprised that mine did not work that way. Didn't know if something was wrong or if it was never installed.
  11. Aug 26, 2024 at 5:14 AM
    Retired...finally
    Do you have your window sticker?
  12. Aug 26, 2024 at 5:27 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    If you take off the panel on your tailgate, you'll be to see if there is lock mechanism installed. My 2020 SR5 trd sport did not come with one. I installed the OEM version which was pretty easy and plug and play.
  13. Aug 26, 2024 at 5:30 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  14. Aug 26, 2024 at 5:46 AM
    kelbro
    I do not. Purchased used.
  15. Aug 26, 2024 at 5:47 AM
    kelbro
    I'll do that. Thanks
  16. Aug 26, 2024 at 5:47 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Pop N Lock is the way to go. Spend the money and it’ll work flawlessly. I know others will suggest otherwise, but the convenience factor of having the lock and being able to install it easily is a win win.
  17. Aug 26, 2024 at 6:48 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Open up the little panel on the tailgate and look to see if there is an actuator on the locking mechanism. Just a couple of screws to take out to check.
    If you don’t have that option pop n lock is an easy install. Mine has been working flawlessly since 2018.
  18. Aug 26, 2024 at 7:38 AM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    When I bought my OEM one back in 2020 it was $135, but it appears they have just about doubled in price. I would probably choose aftermarket too or just follow this: https://www.tundras.com/threads/diy-pop-and-lock-for-a-fraction-of-the-cost.28693/
    Additionally, if it helps at all, I attached the OEM install instructions that came with my kit. It shows all the steps with photos, all the components (which you could buy separately aftermarket), part number, what tools and socket sizes you need, even torque specs (silly for this really).
    Just pick a nice cool day and take your time. It is a piece of cake. It is probably the most useful add-on I did to my Tundra. Pretty stupid that Toyota didn't include that as standard equipment with the 1794 on that gen IMO.
    Robway0323, kelbro[OP] and bulldog93 like this.
  19. Sep 2, 2024 at 12:44 PM
    dadrocz
    dadrocz New Member
    Ny
    23’ TRD Pro. 18’Platinum
    I got mine right from Toyota. Best mod. It was a pain locking that thing manually all the time.
  20. Sep 2, 2024 at 3:10 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    The only PITA is running it all the way under the vehicle to the passenger footwell. But all in all, this is a mod everyone should have if not pre-installed through factory.
