Tailgate latch options
Discussion in '1st Gen Tundras (2000-2006)' started by Hooptytrix, Nov 8, 2019.
  1. Nov 8, 2019 at 9:05 AM
    Hooptytrix
    Hooptytrix [OP] Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    I broke my cheap oem plastic tailgate latch. My buddy has broken his at least 3 times over the last few years. Has anybody found a tailgate latch that is more durable?
  2. Nov 8, 2019 at 7:19 PM
    Deslock23
    Deslock23 New Member
    2003 Tundra SR5 AC 4wd
    5100’s at 5th notch, Add-a-leaf, diff drop.
  3. Nov 8, 2019 at 7:36 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  4. Nov 9, 2019 at 12:00 AM
    deke1691
    deke1691 New Member
    NorCal
    2000 AC V8 2wd
    Also make sure the mechanism is clean and lubed. Reduces stress on the handle.
    tvpierce likes this.
  5. Nov 9, 2019 at 5:30 AM
    Hooptytrix
    Dirty South
    I was hoping someone found something not made completely out of plastic.
  6. Nov 9, 2019 at 5:44 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I got that same one off Amazon. It feels cheap and like it's about to break. I think I read that the more expensive option off rockauto is pretty good.
  7. Nov 9, 2019 at 7:45 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @Hooptytrix I have this OEM one I dont need. It came off my 02. If you want to pay shipping it's yours.
    SouthPaw, Hooptytrix[OP] and bmf4069 like this.
  8. Nov 9, 2019 at 10:26 AM
    Hooptytrix
    Dirty South
    That is all kinds of generous. PayPal ok?
    SouthPaw likes this.
  9. Nov 9, 2019 at 10:57 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    If you don't have Venmo PayPal is fine. PM me your address and I'll send you my PayPal info. It may be a few days before I can ship it.
  10. Nov 10, 2019 at 6:47 AM
    JQ3
    JQ3 2005 XSP rwd
    My clips on the inside (the orange and purple clips in the pic) kept breaking. I replaced them with some thicker better made clips from Advance Auto. Those made a noticeable difference in the feel of the handle when opening the tailgate. Handle’s still plastic tho☹️
  11. Nov 10, 2019 at 7:16 AM
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    3.5" Lift, ICON Extended Travel 2.5" Coilovers, Camburg Upper Control Arms, Total Chaos Steering Rack Bushings and Differential Drop Kit. Rear ICON Add-A-Leafs, ICON 2.0 VS Extended Travel Shocks. 16x8 SCS Ray10's and BFG All Terrain KO2's 295/75/16s
  12. Nov 10, 2019 at 7:20 AM
    JQ3
    JQ3 2005 XSP rwd
    MDobb79[QUOTED] likes this.
  13. Nov 10, 2019 at 12:24 PM
    Professional Hand Model
    Hand Protectors
    Good call on these. Never knew they were sold separately. I need some for my front hood latch rod. Wonder if they’ll fit?
  14. Nov 10, 2019 at 12:33 PM
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    For $4 it's worth a shot, worst case scenario they don't work but you'll have them for the tailgate when that comes apart.
  15. Jan 30, 2020 at 1:57 PM
    NWTundra06
    NWTundra06 New Member
    06 Tundra AC TRD
    I replaced my tailgate latch and installed stronger rod clips at the same time. My tailgate would unlatch smoother but still wasn't latching properly with the access panel closed. Further inspection revealed that my tailgate issues were cause by bedliner overspray on the rods. Once i removed the extra material, my tailgate works perfectly.
  16. Jan 31, 2020 at 3:33 AM
    foxtrapper
    foxtrapper New Member
    2003 SR5
    My tailgates tend to need a hammering to re-flatten them every few years. The tailgate inner cover tends to get caved inwards, binding the various bits of the latch mechanism. The various moving and sliding parts of the latch also get cleaned and lubricated then, which also makes it work better. If I do this, the tailgate latch releases easily and the plastic handle is sufficient for the task.
  17. Feb 20, 2020 at 6:31 PM
    Hooptytrix
    Dirty South
    This makes sense, I'm going to try and get in there for spring cleaning
  18. Feb 23, 2020 at 11:33 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I need to replace mine too. The trim on top of the actual handle is broken. It still works though. Replacement is cheap, thanks for the link. I may go ahead and order one and a camera since that's where I wanted to mount the backup camera anyway.
    Speaking of tailgates, does anyone have a recommendation on a strut to add to the tailgate? I added a Dee Zee one to my F-150 and now I can just pop the handle and let go of the tailgate and it comes down really nice and slow on its own. I'd like that on my 05 DC. That sucker is heavy compared to the one of my aluminum body F-150. Thanks.
  19. Feb 24, 2020 at 4:11 AM
    Hand Protectors
    Check out my build page. Mine is mounted like it is on my build page because there is not another way to do it. It won’t work in the tuck position. It works very well. Good luck.
  20. Feb 24, 2020 at 5:04 AM
    Hand Protectors
  21. Feb 24, 2020 at 6:53 AM
    JQ3
    JQ3 2005 XSP rwd
    @Professional Hand Model...Which Dee Zee truck model did you buy? I have a 2016 Ram kit that I never used before I got rid of the Ram. The tailgate is pretty heavy on my truck.
  22. Feb 24, 2020 at 1:27 PM
    Hand Protectors
  23. Feb 25, 2020 at 3:57 AM
    foxtrapper
    2003 SR5
    As similar as the tailgate design is to Fords, I'm not sure you couldn't simply fit the Dee Zee one to the Tundra.
    https://www.youtube.com/watch?v=HH0sTo5n_zw
    There's also this, which is similar.
    https://www.siraweb.com/ez-down-dz4...MI9Lniy9Hs5wIVA6SzCh3Y4ALdEAQYBSABEgIhRPD_BwE
  24. Feb 25, 2020 at 5:48 AM
    Hand Protectors
    Not enough room between the gate and latch frame to fit the strut. If there was I would have done it.
    The allowable strut would need to be half the diameter of most designs currently available. This equals weak strut.
    Or, one could cut into the tailgate and fab up a way that allows the aftermarkets strut to ‘tuck’ into the recess. Not worth it in my opinion.
    Somebody find a better way and I’ll follow you on it.
  25. Feb 25, 2020 at 6:42 AM
    artsr2002
    'Yonder
  26. Feb 25, 2020 at 6:49 AM
    Hand Protectors
  27. Feb 25, 2020 at 8:21 AM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
  28. Feb 25, 2020 at 12:51 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
  29. Feb 26, 2020 at 5:46 AM
    foxtrapper
    2003 SR5
    While I’ve no interest myself in this, I did measure the side clearances on my 03 truck. There’s a 1-1/8” gap on both sides between the tailgate and bed sides. That’s tight, but not impossible, to fit a gas cylinder into.
    The aforementioned torsion bar should also fit any of these beds and tailgates.
  30. Feb 26, 2020 at 6:11 AM
    Hand Protectors
    I think the torsion bar is the best design so far from a practical standpoint. I’d be interested in someone trying to install one on an earlier gen even though the seller/designer says won’t fit.
    Per the gap and fitting a strut: One has to consider all things. The length of strut and how it effects the open/close. Latches are in the way. Cable hold is in the way, as well. The latch and cable folded up when the gate is closed precludes any allowable space and proper operation of strut.
    NewImprovedRon likes this.
