Tailgate ladder/step - which do you have?
Discussion in '2nd Gen Tundras (2007-2013)' started by JmikeLKA, Oct 1, 2021.
  1. Oct 1, 2021 at 7:14 AM
    JmikeLKA
    JmikeLKA [OP] Loving the truck
    2021 Limited
    Undercover Ultra Flex Cover, Rear Sway Bar, LED interior lights, Cargo Bars attachments, Console Safe, Husky Floor Mats,
    I’m a FOB (fat/old & bald) guy and are not enjoying crawling into the bed of my truck.
    What do you have or are considering?
    A folding step under the bumper, a ladder attached to the tailgate, nothing? Or you carry something in the bed?
    Come on, even without a lift the tailgate/bed is not a simple easy step up into while carrying items.
    76099B0E-D43F-44D2-95BE-F20764F562BE.jpg 54F96A97-B076-4166-9E45-C1DC6A375EB1.jpg
  2. Oct 1, 2021 at 7:20 AM
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
  3. Oct 2, 2021 at 2:53 AM
    CMikeB
    CMikeB New Member
    I shopped quite a bit before buying my Bestop Trek Step. It functions exactly like the "OEM" Amp Research model but has a larger step pad and is more slip resistant at a better price.0208140955.jpg
  4. Oct 2, 2021 at 7:03 AM
    JmikeLKA
    2021 Limited
    Tell me about your LED bumper lights
  5. Oct 2, 2021 at 7:09 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Amp step here. Worth every penny, and it's rock solid. I cut the bracket already on the truck, clean, quick install.
    JmikeLKA[OP] likes this.
  6. Oct 2, 2021 at 7:09 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    I just stepped up on the tire and over. Even with 34.6" tires.
  7. Oct 2, 2021 at 7:14 AM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    My tailgate step.
    grave, Pipo6007, Caliwheysted and 5 others like this.
  8. Oct 2, 2021 at 7:16 AM
    mikesTundra77
    mikesTundra77 BRAAAAP BRAAAP
    M_i_k_e
    earth, sol system
    BLOOD,SWEAT+BEERS
    4 " ready lift kit General grabbers 35" Rock warrior wheels 17" Leather Clazzio seat covers KN intake StartX remote starter HRS sequential tails Custom grille+badge ME-SO map lights+dome light Lots of CHROOOOME
    Hand made for about 15 bucks (used scrap 10 ga. And 1/2 " rebar from work and welded, only bought the paint can. Took about 3 hours)
  9. Oct 2, 2021 at 7:26 AM
    CMikeB
    CMikeB New Member
    I've had 'em for several years. They're Ridgid's D2-Dually with their Diffused Lens pattern. Came with all the hardware and really quality harness with lighted switch. So simple to wire,even I was able to do it! That first saw-cut into the bumper will have ya' sweatin' but it goes alright after that!:D
  10. Oct 2, 2021 at 7:28 AM
    W3agle
    W3agle New Member
    San Diego, CA
    2016 White Tundra SR5 TRD Off-Road
    Never seen one sold in that config. Can you walk me through the modifications you did? Or are you just from south of the equator?
  11. Oct 2, 2021 at 10:44 AM
    LittleTundra
    LittleTundra New Member
    Oregon
    I have the amp step for the rear bumper on my 2016 and LOVE IT. Almost don't want to upgrade to the an aftermarket bumper just because of the the step.
  12. Oct 2, 2021 at 10:53 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I have the OEM step that I added. It folds out in a way that it's perfectly positioned for me to use it whether the tailgate is up or down. It's perfect for my use.
  13. Oct 2, 2021 at 10:57 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    The Bedstep,? (I think can’t remember.) Amp Research. works flawlessly.
  14. Oct 2, 2021 at 11:05 AM
    Coastboater
    Coastboater New Member
    Wheels & Tires, Power Running Boards
    AMP step here.
    My previous truck, a 2013 F150, had Fords first iteration of their tailgate step which was integrated in to the inside face of the tailgate. It sucked if you were carrying sheets of anything or were trying to slide something out of the bed. Not long after Ford integrated it in to the center space of the tailgate and the inside of the tailgate, when lowered, is smooth and even with the bed.
  15. Oct 2, 2021 at 11:16 AM
    azimuth
    azimuth New Member
    2010 double cab SR5
    Amp research is what I chose. Piece of cake to install. Strong and convenient.
  16. Jan 16, 2022 at 7:05 PM
    JmikeLKA
    2021 Limited
    I searched and found this one. It’s been great. The best parts are the swivel option and the wide steps.
    279A9A52-9C3C-4489-8AD9-FC92B268A0AB.jpg 27BC8B07-8E4E-4FDD-A088-2F8DEEEA58EA.jpg 541231C2-E2FE-4E7E-AA1C-EF609390250B.jpg
  17. Jan 16, 2022 at 7:15 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Link?
  18. Jan 16, 2022 at 7:57 PM
    JmikeLKA
    2021 Limited
    Off Amazon.
    Issues were they didn’t send any instructions and short one bolt. I used my own and put lock nuts on the back, did not us the screw nut anchors they sent.8025AD08-0A83-489F-BDCC-48249829E169.jpg
  19. Jan 18, 2022 at 9:46 AM
    ARayT
    ARayT New Member
    GEORGIA
    2007 Tundra XSP
  20. Jan 18, 2022 at 9:55 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I step on the tire and also use the corner step in the RC bumper. You tire steppers could also use one of these:
    JmikeLKA[OP] and Branden like this.
  21. Jan 18, 2022 at 9:59 AM
    shawn474
    MoCo, Maryland
    I like this one but I do worry about the space it will take when folded. With the shortbed real estate is at a premium and it looks like this extends quite a bit into the bed when the tailgate is up. How far does it extend? Also, does this use existing screw holes in the tailgate or do you have to drill new ones?
  22. Jan 18, 2022 at 4:07 PM
    JmikeLKA
    2021 Limited
    I took the rear plate off the tailgate and used my drill press to drill four holes.
    I used the screw and hole already there for the strap.
    shawn474 likes this.
  23. Jan 20, 2022 at 1:58 PM
    ARayT
    ARayT New Member
    GEORGIA
    2007 Tundra XSP
    Shawn474,
    It extends about 5-6" into the bed. You will need to drill holes. I installed mine w 4 self taping screws that can be removed and reinstalled easily if need be. Make sure you mount it close to the edge or top of tailgate so it clears and will (or can) extend almost vertical when deployed, this allows for lower or uneven ground.
  24. Jan 20, 2022 at 2:06 PM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    12” Bulletproof Lift, AFE CAI, AFE Exhaust, rock lights, Fas-Top tonneau and soft topper, Dasaita 10.2” radio, light bar, ditch lights, LED headlights and fog lights, LED interior lights, Amp Research rear bumper step, dashcam, BT ODBII reader and Torque app on radio
    I’ve got a 12” lift so I went with the AmpResearch step. Only if it was power like my running boards.
