Tailgate key
Discussion in '1st Gen Tundras (2000-2006)' started by az chip, Jul 15, 2018.
  1. Jul 15, 2018 at 7:04 PM
    az chip
    az chip [OP] New Member
    Craig
    Arizona
    2003 Tundra TRD
    I tried to lock my tailgate. Ignition key seems awkward. Is there a different key that locks the tailgate?
  2. Jul 15, 2018 at 7:46 PM
    Yoda21
    Yoda21 New Member
    Hayward ,ca
    2022 limited Trd crew max
    My 15 and 18 boh used he ignition key but I also added the pop lock so it locks with the doors
  3. Jul 15, 2018 at 8:23 PM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    My 03 uses the ignition key. If yours doesn't work try the spare key if you have one.
  4. Jul 15, 2018 at 11:28 PM
    15whtrd
    15whtrd Mr. Blonde
    Either the ignition switch has been changed or in the tailgate lock has been changed. Or it’s just really gummed up. Take the tailgate lock to a locksmith and have him re-key it.
  5. Jul 16, 2018 at 12:02 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Seems awkward? How so? Did it not turn at all? Or did it work but was hard to turn? Mine was full of dirt and grime. Soaked it with PBblaster and now it operates fine.
    15whtrd and Sunnier like this.
  6. Jul 16, 2018 at 6:58 AM
    Professional Hand Model
    Hand Protectors
    Probably your ignition key has developed a memory (worn over time) and the cams don’t match exactly with the back lock.
    Or, like others above said. Dirt and grime and rust may be the culprits. PB Blast, then add some grease to your key and work it in there. Go to go for many more years.
    Another thing you could do is remove the backing off the tail gate and grease the other points that need it.
    15whtrd likes this.
  7. Jul 16, 2018 at 9:50 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Just get the Pop and Lock. Never have to use your key again.
  8. Jul 16, 2018 at 9:51 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Ignition key
  9. Jul 16, 2018 at 12:56 PM
    Yoda21
    Yoda21 New Member
    Hayward ,ca
    I second joonbug wish they would do it stock
  10. Jul 16, 2018 at 1:57 PM
    az chip
    Craig
    Arizona
    2003 Tundra TRD
    Thanks, I will Aero Kroil the snot out of it and see what happens.
  11. Jul 17, 2018 at 3:08 AM
    East TN Yota
    East TN Yota Superhero by Night
    2006 Phantom Gray Tundra TRD Access Cab
    I didn't get any original keys when I bought the truck. Had a spare made at the dealership the other day and it looked different. Parts guy said that the new key is a master and will fit the glove box and tailgate locks even if the one I copied didn't. Might be worth a shot.
    az chip[OP] likes this.
  12. Jul 17, 2018 at 6:11 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    If it didn't work at all, does it work on the glove box? If neither you have the "valet" key. It will open doors and start engine but not open glove box or "trunk".
    az chip[QUOTED][OP] and Bbombs like this.
