Tailgate just slams down
Discussion in '3rd Gen Tundras (2022+)' started by Keeptipsup52, Jul 29, 2023.
  1. Jul 29, 2023 at 2:14 PM
    Keeptipsup52
    Keeptipsup52 [OP] New Member
    22 SR5 TRD OR
    22 SR5 OR
    Recently my tailgate lost the slow open when you open by hand or by fob. Anyone deal with this and is there a fix I can do myself?
    just had it at the dealer for oil change and don’t feel like taking it back so soon.
  2. Jul 29, 2023 at 2:17 PM
    Probably had the strut fail. Can you replace it yourself? Probably, but why wouldn't you warranty it?
    NewImprovedRon likes this.
  3. Jul 29, 2023 at 2:18 PM
    Keeptipsup52
    22 SR5 TRD OR
    Ya if it’s something like a strut fail then I’ll get that warrantied.
  4. Jul 29, 2023 at 2:21 PM
    Well, the strut is what slows it, so I would say it's probably a safe bet it has had a failure or has become disconnected.
  5. Jul 29, 2023 at 2:32 PM
    Florida AF
    Logan
    North Florida
    I would assume it would be a wear item, but with how its under warranty, let us know if they fix it. Sounds like the strut failed and it is way to early for that.
    Keeptipsup52[OP] likes this.
  6. Jul 29, 2023 at 2:45 PM
    Keeptipsup52
    22 SR5 TRD OR
    Maybe I’m dumb but I’m looking and there is no strut that I can see. Only contact points are the cables and the hinges where I assume is where the failure occurred.
    I guess I’ll be taking it back in
  7. Jul 29, 2023 at 2:54 PM
    The strut is inside the fender and connects to the hinge, IIRC. Drop under the truck and look up into the fender behind the taillight.
  8. Jul 29, 2023 at 3:09 PM
    Keeptipsup52
    22 SR5 TRD OR
    Awesome. Thanks. Yea I see it now.
    to the dealership I go!
    Mountainlord likes this.
  9. Jul 29, 2023 at 4:36 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    If you pull the tail light off it will be right there. People will be replacing these starting in 5-8 years as they start to wear out. I saw when I was installing my swing boxes.
    Hope the Dealer hooks you up :fingerscrossed:
  10. Jul 30, 2023 at 7:33 AM
    ryanjay11
    ryanjay11 New Member
    I doubt it would fail this early, so I bet it has come loose.
    Can you hear it banging around when you lower/raise the tailgate, or when driving?
  11. Aug 4, 2023 at 12:02 AM
    Keeptipsup52
    22 SR5 TRD OR
    So interesting point. There is banging when I shut doors or slam tailgate but I’ve always attributed it to the more loose tailgate cable
    On that side.
    I have some time off tomorrow and will take a closer look.
  12. Aug 4, 2023 at 12:42 PM
    BeastOfBourbon7
    BeastOfBourbon7 New Member
    2022 Grey SR5 TRD Sport
    I had the same issue with mine right out of the gate. Had to get it repaired under warranty.
