Tailgate holes, how to prevent rust?
Discussion in 'General Tundra Discussion' started by Tundra4x4rdytgo, Nov 1, 2020.
  1. Nov 1, 2020 at 12:51 PM
    Tundra4x4rdytgo
    Tundra4x4rdytgo [OP] New Member
    2020 SR5 DOUBLE CB w Bucket seats, SUPER white, V8 ,5.6, 6.5ft bed.
    Hi, I just bought a 2020 Tundra, I ended up (stupidly) drilling holes to mount a led backup bar, the plastic brackets that were supposed to hold the bar in place broke and it seems the tape holds it just fine....
    I drilled about 12 1/8th holes through the bottom of the tailgate mount. Should I go out and buy filler. Go out and buy a touchup pen or do both and apply? Will this stop rust? Any advice would be great.. This is my first tundra, thanks..
    - Matt
    YardBird likes this.
  2. Nov 1, 2020 at 12:57 PM
    Welcome from NY.
    Can you post some pictures so we can see it?
  3. Nov 1, 2020 at 1:05 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    My routine: Clean the hole well so there are no rough edges. Paint with rust paint at least two coats. Fill in with RTV silicone if it’s not easily visible.
    P-Factor and Jim LE 1301 like this.
  4. Nov 1, 2020 at 1:22 PM
    Tundra4x4rdytgo
    Sure, here you go. The LED bar in the picture blew a fuse, its supposed to be plug and play, but I guess not. Dealership was nice enough to replace my fuse no charge, even though it was caused by an aftermarket.
    Sure, [​IMG][​IMG]
  5. Nov 1, 2020 at 1:27 PM
    Do what @mountainpete said in post #3.
    Or since it's white you can get that Flex Seal rape in white and cut it to the exact size then cover it with the lightbar.
  6. Nov 1, 2020 at 1:36 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    smear a little axle grease in the holes yearly
  7. Nov 1, 2020 at 2:34 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  8. Nov 1, 2020 at 2:37 PM
    P-Factor
    P-Factor New Member
    Ditto! :thumbsup:
  9. Nov 1, 2020 at 2:42 PM
    Tundra4x4rdytgo
    I will do this, Thank you!
    P-Factor[QUOTED] likes this.
